Question about Electrolux Kitchen Ranges
Boiled over then ceramic touch buttons all beeped. I believe default E-11. No manual what do I do and wht did a boil over leak is this not a sealed unit.
  • 6,784 Answers
HI. This E-11 Code is an indication of a failed Door latch mechanism. I would advise to inspect the latch assembly for loose wire connections at the latch, and main control board. If the wires are attached correctly, and the contacts are ok, simply replace the Door latch assembly. Once the door latch is replaced, the code will shutdown, and the unit will operate properly.
NOTE_ It would be wise to try a hard reset, before purchasing the replacement door latch. Kindly, unplug, or shutdown the appropriate circuit breaker for 5 minutes. Once the 5 minutes have passed, simply re-introduce power to the unit, and observe the actions. If the error code illuminates again, replace the door latch assembly.
Posted on Nov 14, 2009
Testimonial: "Thank you wooked perfect without replacing anything."
Losing coolant
Need to have the system pressure tested, Check oil to see if there is a brown sludge in the oil filler possible head gasket? and its boiling it in a cylinder, check carpet under dash on transmission tunnel if wet (heater leaking) Is the coolant cap seal OK (not pressurising and boiling the coolant away). That give you some ideas to go with.
Jan 02, 2014 | 2001 Chevrolet Monte Carlo
LAVAZZA EXPRESSO POINT THE RED LIGHT BUTTON KEEPS FLASHING CONSTANLTY, WHEN I MAKE THE COFFEE IT SQUIRTS OUT ALL OVER THE PLACE, IT DOENT HAVE A NICE FLOW LIKE IT USE TO
Causes:1- the 130 deg thermostat is open. 2- working thermostat, 104 deg, defective, allowing temp to rise.3- the machine becomes hot because the water valve is stock open. machine needs to be sealed so not to allow water to boil.Water boils at 100 deg Celsius. 4- valvolino or o-rings are worn out and leaking. You need a repair shop.
Guru
Sep 21, 2011 | Lavazza Espresso Point Capsule Machine
Instruction manual is in french ,need it in english
Egg Genie cooks up to 7 eggs at once-with no guesswork, no underdone or overdone eggs.
Just add the indicated amount of water.
Press "on"and your work is done.
The Egg Genie automatically steams eggs and alerts you when they're ready.
Here are the amounts in teaspoons of water:
4 tsp = 6 soft boiled eggs
5 tsp = 5 soft boiled eggs
6 tsp = 3 soft boiled eggs
7 tsp = 1 soft or 7 med
8 tsp = 6 med boiled eggs
9 tsp = 5 med boiled eggs
10 tsp = 3 med boiled eggs
11 tsp = 2 med boiled eggs
12 tsp = 1 med boiled egg
14 tsp = 7 hard boiled eggs
15 tsp = 6 hard boiled eggs
17 tsp = 5 hard boiled eggs
18 tsp = 4 hard boiled eggs
20 tsp = 3 hard boiled eggs
21 tsp = 2 hard boiled eggs
23 tsp = 1 hard boiled egg
May 22, 2011 | Emson EggGenie Egg Genie Electric Egg...
Temperture fluctation
Generally the temperature fluctuates due to a leak in the cooling system.
The cooling system operates similar to a pressure cooker, with everything sealed, for each pound of pressure on the system, the engine can increase the temperature above the boiling point by 7 degrees without boiling. This is why when a hose breaks, the temperature gauge generally goes all the way up & you will hear boiling if you open the hood & inspect the area as it occurs.
If you lose a pound (more or less) of pressure, even with antifreeze, due to the pressure the system is under, the temperature will rise.
So, when there is even a pin hole sized leak, a gasket that occasionally leaks, a radiator cap that isn't actually holding the correct pressure-all of these things will cause the pressure to drop & an immediate change in the temperature making it hotter and as it re-seals itself, the temp will decrease again. There are a lot of particles floating through your cooling system and these particles sometimes will plug a leak until pressure pushes it out later.
Generally a leak is iindicated by the temp gauge rising higher than ever before. To resolve this, a pressure test will be necessary unless you replace the radiator cap & find it is no longer fluctuating.
Also, this doesn't have to happen each time you drive. Seals leak when they want to & that's all I can say about that. Usually they will reach a point where they will want to leak all of the time but finding them has to be done while they are in fact leaking.
good luck
Feb 11, 2010 | 2005 Ford Explorer Sport Trac
Tramission is dumping fluid , the rear is not leaking, or the front seal is not leaking Sooo!what could the problem be?
it could be coming up the dip stick pipe? if the box is getting over heated becouse the oil cooler is blocked then the gear oil will boil up and in time it will cook your gear box up to the point it wont work any more
if your driving it very hard and its slipping a bit it will get very hot the oil boils away,,, as smoke!
Nov 15, 2009 | 1993 Dodge Dakota
My car has no pressure in the cooling system. It appears to be circulating, but no pressure. I had a leak somewhere around the back of the intake manifold, which i apparently fixed with a bottle of sealant...
Do you have a coolant reservoir? Does the coolant level rise as the engine warms up and lowers as the engine cools off? If so, the engine cooling system is sealed. If the system isn't sealed, when it is cooling, it can't draw coolant from the reservoir. Does the radiator have a radiator cap, with cold engine, remove the cap, can you see coolant level in radiator?
How hot does engine get in degrees F? There is your thermostat and radiator cap. Water boils at 212 degrees f atmospheric pressure. With a 16 lb radiator cap, it should raise the boiling point about 32 degrees. The boiling point should be around 250 degrees F. w/o any pressure, I would suspect it would boil over in a hurry.
Jul 18, 2017 | 1996 Ford Thunderbird LX
Well my car allways over heats and coolent leeks out of the radiator cap its not the thermostat. What can I do
If it is leaking out of the radiator cap, then that means you need a new radiator cap. Your cooling system in your car is a sealed system. Sounds like your radiator cap is not sealing properly and when the cooling system is not longer sealed then the temperatures cause the coolant to boil whereas coolant not subject to the atmosphere does not boil. Start there.
Good Luck
Oct 08, 2009 | 1998 Oldsmobile Aurora
Kettle doesn't turn off
Our first Smart Kettle was great and worked well for years, finally died so we bought another. Right from the first boil it seemed to boil for about 2 or 3 minutes before turning off and then either didn't boil or made beeping sounds when not being used so after a couple of weeks we returned it and it was replaced. Great. But now this new one seems to boil and boil before turning off so maybe they are just faulty now. Any suggestions?
Jul 04, 2009 | Breville "Ikon" Tea Kettle Electric Kettle
Kitchen Ranges Logo
167 people viewed this question
Top Electrolux Kitchen Ranges Experts
Mike Henne
Level 1 Expert
Dominic
Dominic
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
