Question about Polaroid FLM-2632 Television
Why my screen on my tv won't stay on and goes black
I have a Poloriad flat screen that I replaced the compactors on the power supply but the tv will come on for about 3 seconds and then the screen will go black and but the power button still stays on?
  • 11,361 Answers
If you get steady 24vdc from the power supply which is used for the inverter board afterb the bad capacitors are replaced, then you may problem with the inverter board that is damaged by AC from the power supply when the capacitors went bad, capacitors were filtering out the AC. There are surface mounted fuses on the inveter board also. Please post back what you find.
Posted on Nov 15, 2009
Testimonial: "Thank u so much I will let u know what happens when I try it. Again Thank U"
Comes on fine, good picture and sound. After about 15min. sound stays on but picture goes black
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jan 27, 2016 | Syntax Olevia Lt30hv 30-inch Hd-ready...
I got a Samsung HDTV model LN40E550F7F.TV will not power on. The Power light is flashing First flash is bright and flash following is dim then back bright then dim.etc non stop.i looked at power supply...
Hi Ricky, Power supply card seems to have gone bad in this case.If you are technical, try replacing power supply board or consult someone qualified to handle your set.
Aug 24, 2014 | Televison & Video
I have a Olevia lt37hvs, When i plug it in the blue(olevia)light comes on then goes off and the screen will be blue for 5-6 second then go black for 1-2 seconds then screen goes blue again and it just...
tried to connect again the supply for main board and disconnect the supply for the inverter board of back light. and turn on the tv, if the indicator stay the inventer board was the cause of voltage drop at the power supply board.
Sep 08, 2012 | Olevia LT37HVS 37 in. LCD HDTV
When turning the tv from stand by to on the red light goes green but but the screen stays black
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care in solving the problem....
Jul 06, 2011 | Televison & Video
When i turn the tv on it comes up the main screen like,tv, hdmi,1 exc.then with in secounds it goes to a black screen it will not let medo anything unless i turn off and does the same thing i need help...
You have a power supply problem. Within about 32 seconds the picture drops out because the backlite transformers shutdown. Yoy will have to find a new power supply or have some one fix yours.
Mar 20, 2010 | Element Electronics FLX-3211B 32 in. LCD...
My LCD HDTV screen keeps going black.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 14, 2009 | Westinghouse 26" LCD Flat-Panel HDTV
Syntax Olevia flat screen tv video goes off then on
Hi, Replace the bulging capasitors on the main power supply board. Thanks.
Sep 22, 2009 | Insignia 37" LCD Flat-Panel HDTV
Sanyo ce32ldy1b lcd 160gb black screen with sound
It sounds like you have a power supply problem, this powers the inverter! Where you just replaced the inverter, we could assume it is good! Look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain). The power supply can fail on some output and be good on others. Was the back light inverter new? If all else fails, see if you can return the back light inverter and get another! I hope this is helpful!!
Mar 01, 2009 | Sanyo DP32746 32 in. LCD Television
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Polaroid FLM-2632 Television Logo
313 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
