Question about Hotpoint First Edition FEW12 Front Load Washer
How do I clean the filter on my Hotpoint First Edition FEW12? Do I have to take off the whole big black pipe at the back, under the drum? There is no filter at the fron
  • Hotpoint Master
  • 3,463 Answers
Yes, remove lower rear cover.
Remove large black hose from bottom of drum.
Clean the filter inside the hose.
Please rate my solution.
Thanks.
Posted on Nov 14, 2009
Testimonial: "Easy to understand"
This is correct i have just had this problem myself, i took the back off removed the large black rubber pipe which is held on with a jubilee clip took out the filter and cleaned out put back in ... job done... ps remember to put the white ball back into the filter before re fitting
Posted on May 09, 2010
Where is the elusive filter located? I thought it was hiding under the flap thing at the bottom but I can't for the life of me work out where it is
If you were to Google "Hot point first edition FEW manual" using Firefox, the results will lead you to "for Hotpoint FEW washer - Laundry Appliances Manuals" at "laundry.manuals online.com>....> Hotpoint Washer".
Download a free copy of the instructions for Installation and Use for Hot Point First Edition Range User Manual.
I have looked through the manual and there is no direct evidence of a filter as such (common to other machines), but there are details of what maintenance should be followed to clean the machine - not too user friendly but may help.
If you do go to the manufacturers website (Hot point is an Indesit company) you will find that previous buyers have asked the same question as you)
Nov 16, 2013 | Hotpoint First Edition FEW12 Front Load...
Where is the filter?
theres no filter as such you have to do whats called a maintance wash tells you in the instrutions just a boil wash to clean filters some hotpoint machines have a filter access point under the kick plate at the front bottom of the machine
May 20, 2010 | Hotpoint First Edition FEW12 Front Load...
My filter!!
First of all,lay the drain hose down to floor level and let the water run into a bucket or similar, this will empty the washer of water.
the filter is inside the large black hose on bottom of drum.
Undo hose, remove and clean filter
Refit filter and hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve your problem.
Good luck.
Jan 03, 2010 | Hotpoint First Edition FEW12 Front Load...
My machine won't drain and I can't find the
After having removed back panel, locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump and check for blockage or obstruction here as well.
Hope this helps you.
Jan 02, 2010 | Hotpoint First Edition FEW12 Front Load...
Where is the filter on Hotpoint first edition washing machine ?
Hi.
Some of these models, I believe, had a filter behind the front plynth. If nothing there then you will have to get to the back of the appliance.
Disconnect the power supply and remove the bottom back plate.
You will see a black hose that connects to the bottom of the drum and the other end connected to a drain pump.
With a few towels handy (make sure washing machine is empty!) unscrew the large clip holding the hose to the outer drum. Indide this hose you will find a filter. Remove, clean and refit.
Make sure hose is pushed firmly back on the outer drum and the clip fully tightened.
test with a small amount of water in the drum to make sure there are no leaks.
Hope this helps
Aardvark Repairs
Nov 18, 2009 | Hotpoint First Edition FEW12 Front Load...
Where is the filter on my hotpoint few12 can i clean it myself
Hi.
If you cannot find a filter at bottom right of washer, then remove lower rear cover, locate and remove large black hose on bottom of drum, you will find the filter in there.
Thanks.
Oct 21, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint FEW12 washing machine chews up clothes
If you check the door sal and there is any play in it then it needs replacing. Mine had two saggy indent bits and needed changing..no more ripped clothes
Apr 10, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint few 12 first edition
Its either behind the kick plate or in the pipe which runs from drum to pump at the drum end.
Dec 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint first edition few12 wont fill
hiya
if your machine wont fill it will more than likely be a faulty inlet valve.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Jul 07, 2008 | Hotpoint First Edition FEW12 Front Load...
Not draining and flooding my kitchen!
hiya
first off norah, you will need to check the pump filter as there is probably a blockage in there.
secondly guest, sounds like a faulty pressure switch or even a small hole in the pressure pipe, thats why your machine will not stop filling.
hope these help
Jun 09, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint First Edition FEW12 Front Load Washer Logo
634 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
