Question about RCA RT2280 System
I have an lg lcd mod#lc427d hdtv how do i hook up an rca rt2280 system to it. i have a dvd player hooked up to tv now using hdmi cables, rca av reciever does not have them...
YOUR TV SHOULD HAVE A DIGITAL AUDIO OUT JUST RUN THAT TO DIGITAL AUDIO IN ON YOUR RECIEVER SET IT TO TV AUDIO MODE AND ANYTHING YOU PLAY THROUGH THE TV WILL PLAY THROUGH YOUR SURROUND SOUND(YOU WILL NEED AN OPTICAL CABLE) YOU WILL NOT HAVE TO HOOK ANYTHING ELSE TO SOUND SYSTEM JUST HOOK EVERYTHING STRAIGHT TO TV
Posted on Dec 13, 2009
You can check your dvd player for a coaxial or an optical sound output, then you can plug it directly to your receiver. Those two are the best options after HDMI. Another option is A/V RCA type cable, you´ll need 3 stereo A/V wires, in order to connect the 6 channels. Remember to uncheck the HDMI sound output option on the DVD menu.
Posted on Dec 01, 2009
I have a 39 inch Emerson hdmi led tv and it is hooked up to Directv. I'm trying to hook up my daughters DVD player it is a Sv 2000 DVD CD player e everything is hooked up we get sound no picture.
hi try using RCA cables to make sure youre connections r not the problem..plug the rca cables n the output of dvd then into tv input & set tv input to AV .good luck
Sep 02, 2015 | Emerson Televison & Video
How do i hook up a dvd player to a tv
Depending on what model tv and dvd player you have, it will be either HDMI (one cable for audio/video), RCA Yellow(video) red/white (audio), or Composite (3 for video and 2 for audio). Make sure you connect the cable you choose to the INPUT of your tv and then you have to use your tv remote to change the input (ex: hdmi 1, or aux, video 1 etc) depending on your model and input you choose.
Jun 23, 2012 | LG 42LG30 42 in. LCD HDTV
I have lost colour in my DVD Player, It's showing black and white illustration. How to fix it.
U hook it up wih a AV RCA R,Y,W cable change the cable or u used a HDMI cable,change another HDMI cable to another tv HDMI hub.
Jan 29, 2011 | Sony DVP-NS508P/S DVD Player
When i hook up a dvd player the screen is in black and white what is wrong i followed the manual?
U used the RCA component AV cable Y,R,W?Yes,the Yellow cable must have been damage,that the video out put cable.Ur DVD player have a HDMI port?Used the HDMI cable hook up for DVD player to ur tv HDMI port.HDMI cable better cable design.
Jan 15, 2011 | Sansui 19 in. LCD TV
I have a toshiba 42HL196. With HDMI cables hooked up, I have no picture when attempting to watch cable TV or use my DVD player. Everything works when I hook up using RCA cables. What is my problem?
By no picture, do you mean that you have sound? If yes then ensure that the tv and the DVD player/cable box is set to the same resolution as that of the tv. That should resolve the problem.
Dec 04, 2010 | Toshiba 42HL196 42 in. LCD HDTV
I purchased aRCA 250W DVD Home Theater System with
do you have a set of cables coming from the tv AV out to your home theater system? if not you need to you can use coax out or anolog out either one
Dec 03, 2009 | Televison & Video
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Dvd is grainy picture
You can use your old on, but I am guessing it doesn't have progressive scan. If it does, make sure to hook it to your TV using a component cable.( RED GREEN BLUE ) Then you will have to hook the audio up seperately with a standard red and white RCA cable. Do nt try to use a standard RCA video cable in the place of a componenet cable. Once you have the compnent (RGB) cable and RCA (RW) cable hooked to the TV, check the DVD menu and make sure it is set to Progressive Scan. If you want the best picture for your HDTV. I highly reccomend a blu-ray disc player. That is the highest quality. There are some prety good upconverting DVD players out there. They take the 480p signal and upconvert them to 720p, 1080i, and 1080p. These have HDMI outputs and connect quickly and easily to the TV you have. Most of them can be purchased for less than 100 bucks. But this would be your second best option. Before you shell out 400 bucks on a blu-ray player, go to a rental company and rent a blu-ray player. Once you see the quality of blu-ray, I think you will run out and buy one!
Jan 10, 2009 | Toshiba 19HLV87 19 in. LCD HDTV
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
DVD Connection and Surroundsound 7.1 Onkyo
gotta use rca audio cables in addition to the hdmi on this tv
Feb 09, 2008 | Philips 51PW9303 51" Rear Projection...
RCA RT2280 System Logo
273 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
