Question about 2wire 2700HG-B Router (2700HGB)
Have my desktop connected wireless 2-wire 2701HG-B. works fine. trying to hook up a laptop. shows to be connected but will not connect to the internet. any suggestions?
  • 68 Answers
Check settings in comp and router.
Posted on Nov 14, 2009
I want to know if my 2wire 2701HG-B supports WPS or AOSS? I'm trying to connect my laptop to my wireless printer but it goes through a Wireless Network which is my 2wire router obviously. If my router...
As long as you do not have your laptop set up on teh 2701HG-B's DMZ everything should work. I have the 2701HGV-B, almost the same except my can do VoIP, and I have my laptop running wirelessly and I can connect to the network printer.
Make sure the printer has a static IP address for your local LAN, which should be in the 192.168.X.X scope, or the printer will change IP addresses every time it resets and that will cause you to lose connection to it from the laptop.
As for WPS, there should be a sticker on the side of teh 2-Wire that has a 6 digital key number, all numbers no letters, that will be the WPS key.
Hope that helps.
Jun 04, 2011 | 2wire (2701HG-B) Wireless Router
Im trying to hook my desktop up to the wireless router so that me and my dad (both with laptops) will hook up wirelessly. I tried reseting Linksys Broadband Wireless G Router and made sure all of the...
Try: Clarify - the desktop is connected with an ether net cable? Is working? Install router software on desktop to manage router. Trying to connect desktop wirelessly? Wireless card installed? Radio activated? Network detected?
Dec 31, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
I have a linksys wireless g router that worked fine until yesterday. Now it won't connect to the internet. I have a desktop wired to the router and a laptop used wireless.
Check if you can connect to the internet when hooked directly to the modem. If your connection works fine through the modem, then your router needs to be reconfigured.
May 13, 2010 | Linksys Wireless-G WRT54G Router
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Carl
Jun 21, 2009 | Linksys Wireless-G Broadband Router
Problem getting to internet through 2wire 2701hg-b router
how can I connect a 2wire 2701HG-B router to a motorola SB5101modem?
Apr 22, 2009 | 2wire Computers & Internet
2Wire 1800HG keeps losing connection
However as you said Desktop works fine and this seems to be issue with Wireless Netwrok card of your Laptop try to upgrade drivers of the Wireless netword card opf your laptop and this may possibly resolve the problem..
Apr 08, 2009 | 2wire 1800HG Router (RG1800HG00)
Cannot connect other devices to my router
You reset it to open, no encryption and it still didn't work? HMMM. You are able to get your PS3 online? but can't connect your laptop and desktop? Are you hard wiring the desktop to the router? or are you trying to connect it wirelessly? If you are configuring your router with either the laptop or desktop, make sure the IP settings on your connection manager are set to the correct domain under Local Area Connection Properties, like 192.168.1.226, or something similar. Login to the router with your admin credentials. Make sure in your configuration (as instructed in your manual) that you have the router time set correctly so the lease time for your devices aren't expired. Apply settings. After exiting your router configuration screen, go back to your connections manager, either wireless connection, or ethernet adapter in your network connections folder, and under the General tab of the Local Area Connection Properties, change the properties of your TCP/IP client back to "Obtain an IP Address Automatically." Click "Close" and your computer should show "Connected."
Feb 17, 2009 | Belkin (F5D5231-4) Router
Fifth computer unable to connect to internet
-- ckeck if you see 'wireless connection' in the network connections, in order to find it, click start --> control panel --> network connections and you must see wireless connection in case of win xp..
start --> control panel --> network and internet --> network and sharing center --> manage network connections and you must wireless network connection under LAN or hi speed connection... in case of win vista
--if you have that ikon that means you have your drivers installed on the computer properly
--right click wireless network connection and click "view available connections" in case of  xp and "connect/disconnect" in case of vista you must find the network and get connected..
letme know if you have problems connecting..
Jan 24, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Wireless not working
Check for the wireless security settings in your modem.. and check if your airport is connected properly, if it is connected properly, then you would get a valid ipaddress, try resetting the modem and reconfigure your wired and wireless settings, if possible , try to upgrade the latest firmware for your modem and then reconfig it..
Jan 21, 2008 | 2wire (1000-000057-000) Modem
2wire 2700HG-B Router (2700HGB) Logo
77 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
