Question about Whirlpool Duet GHW9150P Front Load Washer
I am getting a message on the washer saying "HF" what those this mean?
  • 4 Answers
Google " duetservicemanual.pdf" I see an error code "FH", but nothing listed as "HF".
Posted on Nov 15, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 8 Answers
We also had the beeping alternating F H error code. I found that the tube to the he water level switch , which is on the back upper right side ( a black plastic round with a red dots near the top) which connects the bottom of the washing drum, was rubbed through ( the retainer clip had broken). I cut it at the rubbed through portion and inserted a 1/4 inch id plastic hose into the two cut ends to re-join it. I used some black electrical tape ( for good measure) so it wouldn't pullapart , inserted it into about a foot of hose ( so it would'nt wear through as fast next time), then reattached it to the bottom back right tube ( on the drum) and the water level switch previously mentioned. Now my skinny black rubber hose could let the machine know that there is (was) enough water in the drum after filling. Since the plastic clip was broken, I taped the repaired rubber tube to the back of the blue corrugated drain tube to keep it from rubbing and moving too much. As a bonus, I no longer have leaking water on the floor (from the broken water tube).
Posted on Aug 02, 2012
3 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Code
"F/H" this indicates that either have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on (not trying to insult your intelligence, but I've seen it happen).
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub check the following:
- Make sure you don't have a siphoning problem. Click the following link for intructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls that explains all the error codes and how to troubleshoot. It also explains how to perform diagnostics and where to locate certain components.
I hope this provides you with some aanswers. Please post back if you can't find the tech sheet and/or need further assistance.
Posted on May 13, 2008
  • 127 Answers
SOURCE: my washer keeps flashing and
Check to make sure you are getting a good supply of water to the washer. Remove hoses at the washer and make sure the filter screens are not clogged.
Posted on Jun 07, 2011
Testimonial: "thanks it was the water supply"
What does the F and H mean
Do you mean "HF"?
According to the manual HF means water inlet problem.
-Select PAUSE/CANCEL twice to cancel the cycle. Unplug washer.
-Are faucets completely turned on?
-Are screens at inlet hose connection clogged?
-Are hoses kinked?
-Are inlet hoses frozen?
Plug in washer, re-select cycle and press START. If the problem remains, call for service.
Or you can post the problem at Repair Clinic. They might be able to help further, and they sell parts if you need.
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Mar 10, 2015 | Kenmore HE2 Plus Front Load Washer
Hf-360 leaking at cutoff valve
Hi
Going to the manual...it says if you have a leak like you are describing then you need to call tech support. this filter has a 5 year warranty. call 1-800-721-9243.For parts you can call 1-888-777-7962. Check out your manual here at http://www.culligan-store.com/pdfs/HF-360A_Rev_A-Manual.pdf Good luckne10810a
Feb 19, 2015 | Culligan HF-360 Whole House Water Filter...
Whirlpool duet washer fills with water washes for about 12 min then code hf
The FH error code means that the washer has not detected any water entering it. This tip i wrote relating to the FH code covers what to checkto fix it.
http://www1.fixya.com/support/r10423905-fh_code_means_duet_epic_front_load
GENE
Oct 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer keeps flashing and saying FH or Hf ... what does this mean?
Jun 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
WHAT DOES HF MEAN
Hello
FH or HF error is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
Nov 17, 2010 | Kenmore Elite 45986 Front Load Washer
Hf error message
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to www.applianceaid.com where they have very good and complete trouble shooting and repair information on front loaders. You can search for the meaning of the error code on the site. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 25, 2009 | Washing Machines
What does a flashing code HF mean? This is a kenmore elite HE3t washer. thanks
That is the code for a water inlet issue.  Meaning "no or insufficient water supply" according to the manual. It says to hit PAUSE/CANCEL twice to cancel cycle. Then unplug unit and check for:
Are faucets completely turned on? Are screens at the inlet hose connection to washer clogged? Are inlet hoses kinked? And last...Are inlet hoses frozen? After checking all those it says to plug back in, re-select cycle and press START. If problem still comes up call for service. I remember on another site someone had the same code coming up, all the inlet suggestions checked out OK and they had to call for service as it was something in the control panel/computer of the unit.
Hope your issue is something simple as suggested by the manual. Take care ; )
Dec 07, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite washing machine
This code means its not getting a sufficient water supply. I was doing a cold wash and noticed it was sucking down some hot water, so shut off the hot. MISTAKE, after a little bit the HF code came up. Apprently it likes to decide for itself just how cold is cold. Darned Computers.
To make a short story long, when I shut off the hot, it apparently shredded the washer and sent the remnants down to the little filter thingy at the washer itself, whereupon they reassembled themselves into a clog, once again giving me the HF code.
(Check your user manual Troubleshooting section. I think it says to press Pause/Cancel twice)
Mar 30, 2008 | Kenmore Elite 45986 Front Load Washer
A display of hf, and the water intake piece
no way to unclog other than removing sedimet from screen assy. internally nothing need to replace.inlet watervalve 1 piece for both hot and cold water.
Mar 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
793 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
