Need manua lkenmore vacum whispertone 200
Need manual
  • Washing Mach... Master
  • 8,404 Answers
Please visit the manufacturers web site. I think you want a Kenmore. If not, cont follow this link. http://www.kenmore.com/shc/s/c_10154_12604_Kenmore_Washers+&+Dryers?adCell=WH
Thanks for your interest in FixYa.com
please vote
thanks
a
Posted on Nov 14, 2009
Manual for kenmore whispertone 300
Which specific model in the WhisperTone line do you have? The manual may be available from Sears Parts Direct. Start here: http://www.searspartsdirect.com/partsdirect/user-manuals .
The manual for the Kenmore 116.27512790 canister vacuum is available here: http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0807641.pdf . This may be useful if the vacuum is similar to yours.
I hope this helps.
Dec 21, 2014 | Kenmore Vacuums
Sears Kenmore Whispertone Vacuum Problem:
If you push inwards on each side of the light cover on top you can remove it. With the light cover removed remove the (2) access screws. Now you will be able lift of the entire top cover from the base. You will then see the belt and roller brush, remove the old belt and replace with a new one. You can get the replacement belt you need here:
Kenmore Whispertone Replacement Belt
Oct 28, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore whispertone 100 model 116. powerhead no
  • The motor / cord compartment cover must be removed to access the cord reel. There are four screws that hold the cover to the chassis. Two of the screws are found under the cord-retractor-foot-pedal on the top back of the canister. To access these screws the pedal must be removed. To do this, press the pedal down and look (from the top) for the four plastic clips that attach/hold the pedal hinges to the cover. There are two at the end corners and two in the middle. Using a long, thin flat-head screw driver (or similar instrument) press each clip to unhook/popout the hinges. Note: the foot pedal spring will also come out when the pedal is removed.
    The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw
Jul 18, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
My kenmore vacum wont start
Hello, I'm sorry, but please post additional info such as any symptoms prior to not working, will it make noise, does it do anything. It can possibly be your fuse, but we need more info provided to be able to help you.
Thank you
-Chris
May 03, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Push the reset button
Sounds like a problem I had. However, I took the vacum head apart were the belt is to get to the switch that was sticking. the model # on this part is:
Mel Rain/littel fuse
742332
11200000-04
HOLD 2.0 A.
125 V.D.C. / A.C. 60Hz
I took the two connectors of and carfully removed the part. After removal I took apart with a small flathead screwdriver and reset but this is a quick fix and my vacuum begin to work again!
Aug 03, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Whispertone powerhead handle release replacement
Use a flat blade, it just prys off, a new on will press on.
May 24, 2008 | Kenmore 23313 Whispertone Bagged Canister...
My vacum power head wont work
fan belt might have snapped.  take off top by snapping out plastic over light.  good luck!
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Vacums
check belt not broken - could have happened when you caught tassle in head
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
