Question about Sharp R-1492 Microwave Oven
I have a Sharp micro wave model R-1492. It turns on, but nothing cooks. Do you think I may need to replace the magnatron
    President:
  • Sharp Master
  • 1,922 Answers
First before you replace the most expensive part of the unit,check the h.v. diode and h.v. capacitor, the thermistor on the magnetron tubes outer case side, you will need to remove the top cover to accomplish these things
Posted on Nov 14, 2009
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
Oct 16, 2012 | Sharp R-1510 Microwave Oven
Micro wave will not heat has a picture of a little micro wave on the screen
Either the power board to supply the magnatron or the magnatron is defective.
Check or have someonr check the output of power supply. If ther is a hi reading, then change magnatron
Aug 05, 2010 | General Electric Microwave Oven
Oven appears to function normally but doesn't cook at all.
With micro waves, this could be a number of things. They are hard to diagnose using this forum but I'll try. There are three things you can check. One being the thermal fuse. On some models, when it goes bad it put some things out. with others it puts every thing out.
if it's good, check the mag tube (Magnatron). Most of the time, it will be burned on the end if it's bad. tube. The last thing would be the fuse. It is made of ceramic and is a 20amp. It looks like a old round car fuse but it's not. It's made just for micro waves. Honestly, if the thermal fuse and the round 20 amp fuse is not the problem, you may be able to replace the micro wave cheaper than replacing the parts.
Thermal fuse $28.99.
Round 20amp fuse $1.53
Transformer $100.00.
Mag tube $87.00
Capacitor $45.00
Go to www.appliancepartspro.com and enter your model number. This will pull up every part in the micro wave and their prices. Then you will ba able to decide if you want to replace the parts. With yours being one that's built-in over the stove. These cost more and are worth putting more into. If I can help any more comment back and I'll do what I can.
Please rate solution
Sep 07, 2009 | Maytag MMV5186A Microwave Oven
Micro wave broke
open the door and look on the middle top right inside the microwave is it burned or blackend?You have a faulty magnatron.if it is.
May 19, 2009 | Magic Chef MCD1311ST Microwave Oven
Oven lights, turntable turns, motor runs, NO HEAT
this sounds like either a capacitor, transformer, or magnatron. Mags unually don't go bad. Either one can go bad and blow a fuse or other safety device. If one shorts, it could burn a section of the circuit board.
I would think about calling a tech and have him diagnose the problem. Tell him you can't fix it now but will in a month or two. Have him write down the things you need so when you do want it fixed, you do not have to start all over again. Then order the parts and fix yourself.
Micro waves can be dangerous and cause burns, so if you think this is not for you, go buy a new one.
Feb 07, 2009 | Sharp R-306LK Microwave Oven
I have a sharp micro wave oven. Occasionally, when some foods are cooked or heated, you can see small bursts of blue flame. What I should do ? I only use microwave safe containers.
You probably have a burnt wave guide cover. Look inside the microwave either on the side or on the top, it's a square piece of mica board, and you should see a burnt spot on it. You should be able to replace it fairly easy with the model number I can check on a replacement for you.
Jul 09, 2008 | Sharp R-220HW Microwave Oven
Microwave made a loud pop,won't heat,sounds like it's only on half power, makes a low intermittent hum
This is almost certainly a blown high voltage diode.
Please reply back with your brand and model number so we can help you.
May 31, 2008 | Microwave Ovens
Buzzing Microwave
the buzzing is the magnatron tube juicing too thousands of volts before emmitting the micro-wave radiation to what your cooking that turns molecules 180 degrees around... guess that friction is what really heats it.
radar ovens is what they use to call em and even people would stand in front of big ones to warm up long ago...lol canibles will love that.
Jan 11, 2008 | Panasonic NN-T990SA Microwave Oven
Sharp R-1492 Microwave Oven Logo
109 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
