Question about Sony VAIO VGN-CR190E/L Laptop PC Notebook
My computer does not have sound unless it's plugged in
  • Sony Master
  • 497 Answers
First check if the Vista Service Pack 1 or 2 is installed in the Computer and what is the version of the BIOS installed in the Computer.
To check the information about the Service Pack installed in the Computer:
Click on Start, type WINVER in the Search area and then press the Enter key.
Or
Please goto Start Menu, select 'All programs', select 'Accessories' to access 'Run' option and enter 'WINVER' and check whether Windows Vista SP1 or 2 is installed in the Computer.
To check the version of the BIOS installed in the Computer:
Click on Start, type MSINFO32 in the Search area and then press the Enter key.
In the System Information window check the BIOS version.
If the installed BIOS version is not R0231Q0 or higher then install the BIOS update in the Computer from this Link.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCR190E&upd_id=3745&os_id=28
This is a known issue with a VGN-CR series Computer when Audio may not work properly after installing Microsoft Windows Vista Service Pack 1 (SP1).
Installing the BIOS update should resolve the issue.
If the issue still persists after installing the BIOS update then you may try installing the Audio Driver from this Link.
NOTE: Please first go for the BIOS update as it is a well known issue with a VGN-CR series Computers.
If the issue still persists, follow the steps as mentioned on this Link to resolve the issue.
Good Luck!!!!!!!!!!!!!
Posted on Nov 18, 2009
Speakers not working
Check the easy stuff first: make sure the volume is at a reasonable level and play sounds from multiple sources like pandora, youtube, a local mp3 etc to make sure issue is consistent.
Next make sure the one or more wires are plugged into the correct ports. Or at the very least the green wire is plugged into the green plug on the computer (unless they're USB speakers?).
You could always look at the sound settings of Windows and see (if your sound card has multiple plugs) if the plugs and assigned different functions (base speaker versus microphone/headphone etc.). Hope this helps!
Jun 03, 2010 | Logitech X-530 Computer Speakers
Wont turn on unless plugged into computer
Hi it very much sounds like the on board batttery is not charged up, (not charging) hence when you plug into the PC it gets it supply from the USB 5Volts and plays as normal
Apr 15, 2010 | SanDisk Sansa Clip MP3 Player
I have a Boston BA745 sys where can I download a
you should'nt need a driver for the speakers, you just plug it in the sound port, unless you dont have a sound card driver, let me know weather you need a sound card driver , cheers
Dec 12, 2009 | Boston Acoustics BA745 Computer Speakers
I have a labtec surround sound system and need help with installation
Hi , whats the problem bud?..
1st: make sure it is plugged into a wall socket correctly , to gain sufficient amount of power.
Then correctly , plug the green color coded wire , into the Green input jack on your PC at the back , into the motherboard unless you have a sound card...
It should work perfect then :)
Happy new year :)
Dec 06, 2009 | Labtec Pulse 420 Computer Speakers
No sound from my ipod using headphones or car kit
sounds like your headphone jack might be out unless the sound is comming out from the headphone jack when plugged into the pc
Sep 19, 2009 | Apple iPod MA446LL/A MP3 Player
I HAVE A DELL OPTIPLEX 170L WITH BA735 SPEAKERS BUT i HAVE NO SOUND
Make sure you have a sound card installed
    • you think you have a sound card installed but you don’t see it under the Sound, video and game controllers category, expand the Other devices category and check any devices listed there.
  1. If there is a yellow question mark next to the name of the sound card, there might be a problem. Right-click the name of the sound card, and then click Properties.
  2. Make sure your speakers are plugged into a working power source and turned on.
  • Make sure your speakers are correctly connected to the computer.
    On your speakers, find the cable that plugs into your computer. Make sure that the speaker cable is plugged into the speakers and the correct jack on the computer. For example, if the cable is a 1/8 inch cable, there should be a round jack for it on the back of the computer. If it is a universal serial bus (USB) cable, it will plug into any USB port on your computer.
  • Make sure your headphones are not plugged into the line out (headphone) jack of your sound card or computer (unless you want to be listening with headphones rather than speakers). When you plug in headphones, most computers automatically cut the sound to the speakers.
If these steps don’t solve the problem, check the information that came with your computer and speakers or go to the manufacturer's website.
Aug 17, 2009 | Audio Players & Recorders
Problem with Dell AX510 Soundbar
in order for your sound to work you have to disable the on board sound in the bios . unless you already did the , then i would return it and get a different one.
Apr 20, 2009 | Dell ADA745 Computer Speakers
Speakers don't work after getting unplugged once! Light doesn't turn on, etc.
Well it sounds to me like you got them in the wrong plug try a diferent one it wont hurt
Dec 01, 2007 | Dell A215 Computer Speakers
Sony VAIO VGN-CR190E/L Laptop  PC Notebook Logo
107 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
