Question about HP vp6320 Multimedia Projector
Hp projector projector lamp starts fine after 1-2 minutes the light flickers after another 1-2 minutes the light goes out after it is shut off and cooled down it can be restarted and 1-3 repete lamp is 2000 lumin purchased for school 9/27/05 less than 500 hrs of use
  • 1 more comment
  • Mindbender Mar 17, 2008
    1. projector lamp starts fine
    2. after 1-2 minutes the light starts flickering
    3. after another 1-2 minutes the Lamp shuts down
    4. after lamp shuts off and cooled down it can be restarted and 1-3 repete
    5. was purchased used for business use 12/27/07 with less than 800 hrs of total use
  • ThunderSlap Jan 17, 2009
    I have the same problem. someone help me. just bought a projector on ebay. it turns on.. starts fine. after a few minutes.. it begins to flicker and change colors, then the lamp powers off. after it cools down. it'll work again for a few minutes. 325 hrs of use
  • Anonymous Mar 18, 2014
    The projector has worked fine, but suddently is overheating after about 10 minutes. Once I power down, it will start up fine and run for another 10 minutes. The bulb is about 40% used.
    Problem Solver:
  • 18 Answers
This is caused by the color wheel sensor failure. The sensor is mounted very near the lamp and suffered extreme temperature. This problem can be corrected by installing the redesigned color wheel sensor. You also need to refocus the sensor due to different focal length. HP also recommended to replace the temp sensor cable. If you still have the projector, I can fix the problem for you.
Posted on Nov 30, 2008
Just replaced the lamp in an XD520U and am having the same problem, but not hearing any high pitch noise. The Lamp has been reset correctly, and checking the info screen verifies it, but still after a
Have you used a genuine replacement lamp? There are some clones coming from oriental sources that do not accurately match the specifications of the original, and it's possible this may be the cause of the problem...
Was the old lamp still working when replaced? If so, reinstall it teporarily and see if the problem has gone. If so, it's the new lamp that's the cause of it
Mar 26, 2014 | Mitsubishi XD520U DLP Proj XGA 2000:1 3000...
Mitsubishi HC2 projector
Was the prvious lamp still working?
Jul 16, 2012 | Mitsubishi HC2 Multimedia Projector
Canon LV-S1 projector keeps shutting down after a minute or less
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Jul 15, 2012 | Canon LV-LP12 Projector Lamp for LV-S1,...
Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Apr 01, 2009 | Mitsubishi HC900 Multimedia Projector
Microtek cx6
I've had the same problem with my projector three times (usually whenever there's a sports championship). You just need to call optoma, get an RMA number, and ship it to them. Theoretically they'll fix it under warranty and send it back free.
May 02, 2008 | Optoma HD72 Multimedia Projector
Microtek cx6
Hi there
Firstly check when the Projector is switched on , if all the fans are running.
If they are , then it can only be one of two things - either the Powersupply or the Ballast that has gone faulty.
Is there any indicator lights on the unit that flickers , and also what colour ?
Take out the lamp and check for any irreugularities on it like discolouration ( vein like looking marks in either white or black ) or if there is any bubbles on the shaft of the lamp. In which case the lamp will be at fault and will need replacement !
Apr 17, 2008 | Microtek CX6 Multimedia Projector
Green light flashing and then shuts down
Hi Gary
Have you resetted the lamp timer ? It must be done when a new lamp is inserted into the unit.
You can reset the lamp timer by holding the up arrow key on the Projector in until a online message appears. Then just follow the on-screen instructions.
If the problem persists , you will have to replace the Ballast wich is the lamp's power supply.
Mar 16, 2008 | BenQ MP610 Multimedia Projector
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
Projector shuts down after only a few minutes.
I'm having the same problem. My Model is PB8253. Projector started, then afer a couple minutes it goes off with the red lamp led flashing.
Just replaced the lamp, but the problem persists. Tried to remove all connecting cables, except for the power, but still the same problem.
Anyone with similar problem or solution, please contact me at
Jan 19, 2008 | BenQ PB6100 Multimedia Projector
HP vp6320 Multimedia Projector Logo
287 people viewed this question
Ben Johnson
