Question about Bernina Sewing Machines
Bernna bernette serger
How to replace upper blade
The gearin my serger broke and i cant get the gear
Posted on Jun 24, 2008
How do I change the lower blade on my Juki MO-816 Serger
Usually, the lower blade should be changed by a technician. The upper blade can be replaced by the user, but the lower blade requires some minute specifications that use special tools.
Dec 19, 2016 | Juki Sewing Machines
How to set Bernette serger 203 for rolled hem
Be sure you have the proper foot for your machine to make a rolled hem.
Bernette 203 How to use rolled hem foot have the one page manual but it...
Sew Inspired Serger Rolled Hem Tips
In case you don't have a manual, you may be able to glean some information here:
Sergers Overlockers
need manual for the Bernina Bernette 203 overlocker
Aug 31, 2016 | Bernina Sewing Machines
I am missing an accessory for my bernette 334ds serger
try this link for parts Bernette MO334DS Parts
or check with a bernina dealer
Mar 10, 2014 | Sewing Machines
How to replace the upper cutter on the baby lock? which screws to release the old blade?
I also have a babylock eclipse BLE1DX serger & here's how my book says to do it
to replace the upper cutting blade the front panel
2.remove the screw holding the upper blade
remove the upper blade
3.position the new blade in the blade slot, replace the you tighten the screw, hold the blade up in it's highest position
4.close blade cover. close front cover
hope this helps you
good luck
Sep 12, 2011 | Baby Lock Eclipse Serger
Bernette 43D Serger knives upper and lower. where to buy
try these website for the parts
Aug 27, 2011 | Bernina Sewing Machines
How do I change the stitch width on my Bernette serger?
You move the top blade to the right to trim less so stitch forms wider and use left needle. Or both needles for 4thread seam which is more for knits. Blade has a knob usually to adjust it's position. You should test on scraps of your fabric as the weight of the fabric will also determine width of the seam. Adjust top and bottom looper tensions to encase cut edge neatly.
Apr 23, 2011 | Sewing Machines
I have a Bernette 335ds serger and one of the needles fell out (plus I need to take the second needle out. The thread has broken in that needle a dozen times, also. I can't find my manual, and don't...
I have a Bernette 334D serger - I'll make a guess that your 335DS is similar.
There is a manual for your model for sale on right now, item number is 150565998515.
Assuming your needle assembly is the same as mine, you switch off the engine, turn the flywheel until needles are at the highest point, then take the green small straight blade screwdriver from your machine kit and use it to unscrew (righty tightly, lefty loosey) the needle screws a little (never unscrew all the way out!!!) so you can remove the needles. I use my tweezers for this job as it makes holding the needles easier. You may also want to unclip the pressure foot and raise the upper blade out of the way for a bit more room.
Then slide a new needle into each holder, flat shank to the back and tighten up the needle screws again. Remember that the two needles sit at different heights from eachother so make sure each goes fully up into the needle seat, then retighten with the screwdriver.
I hope this helps you with your Bernette, I've had my 334D since 1990 and its still going strong.
Feb 16, 2011 | Bernina Bernette 75
Blades will not cut
A few things to check here; 1. do the blades cross over each other when the upper blade is fully down - if not make sure lower blade is flush with top of needle plate and then loosen upper blade and set it so that the blades cross over for the full length of the blade when down. 2. is there any lint or thread caught between the blades - push the upper blade to the right and look between the blades and remove any material caught between them. 3. are the blades damaged - blades can become chipped from sewing over pins etc and also become dull after considerable use (replace if damaged).
Nov 04, 2009 | Brother Lay-In Thread Serger Mechanical...
Brother 1034D serger is not cutting and is binding up
This problem is usually when the lower blade drops below the sewing plate. Look at the blade in relation to the plate and see if it has dropped below the plate, then you can reset the blade. If it is not the upper blade may be too dull to cut so it will need to be replaced.
Jul 03, 2009 | Brother 1034D Mechanical Sewing Machine
Sewing Machines Logo
145 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
