Question about Sew Smart Compact Cordless 17390B Sewing Machine
How to thread sew smart sewing machine - Sew Smart Compact Cordless 17390B Sewing Machine
bargainbox
  • 1388 Answers
SOURCE: i need a copy of the instruction manual for the Sew Smart Compact Cordless 17390B.
If pictures are helpful, take a look here
This is for a front loading bobbin
You have not mentioned the machine or model, so if this is not like yours, it will be a top loading or drop-in bobbin.
In either event, the idea is to pass the thread thru a small slot and thereby between a tensioning spring......your Instruction manual will have details for your model, tho' with a little thought, any manual for a similar machine (top or front loading) should give you the basic idea.
If you still have troubles, let us know the make & model.
Posted on Feb 10, 2008
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
SewExpress
  • 41 Answers
SOURCE: Sew Smart Bottom Threading Problem
There seem to be a number of folks with the same machine - same problem - stitches won't form. Unfortunately, this many of the same machine with the same problem would tell us to return it and look for a different brand/model. We can only suggest the same - but have posted the following for you all to try (posted individually for another reader earlier this morning - just discovered the multiple same issues):
A few things to try:
  1. Loosen the needle screw, make sure the needle is fully up in the needle hole and re-tighten the screw. Vibration can sometimes cause the needle to slip...and the needle not fully inserted can cause this problem.
  2. Make sure the bobbin is turning the proper direction. If your machine has a standard bobbin case that comes out of the machine, turn the case so the bobbin is facing towards you. Pull the thread tail and make sure the bobbin turns clockwise. If it's turning counter-clockwise, flip it over and try your machine again. If your machine has a drop-in bobbin, double-check your particular machine instructions to make sure it's going the right direction (clockwise or counterclockwise depending on the machine).
  3. Make sure you have tension on the upper thread. Do this by lowering the presser foot (make sure the thread tail is NOT under the foot) and give the thread a tug. You should feel tension on the thread. If not, the thread isn't fully down in the upper tension disks. You should be able to give it a further tug to pull it down into the disks. No tension on the upper thread can cause the stitches to not form.
  4. If none of the above seems to help, you'll need to get your dealer involved (provided you purchased your machine from a sewing machine dealer). They can determine if it's just something happening during threading or if the machine is out of timing. They are there to help you before AND after the sale and should be willing to take care of whatever is happening.
  5. If you did NOT purchase your machine from a dealer, and the store you purchased from does not have a sewing machine technician, we would suggest that you return/exchange it for a new machine and see if the new machine has the same problem (most department/big box stores that carry machines have a very liberal return policy since they do not have personnel dedicated to sewing machines).
  6. If the new/replacement machine has the same issue, we would suggest you return it (no sense frustrating yourself) and perhaps find a local sewing machine dealer to purchase a machine from. Authorized sewing machine dealers are geared towards providing machines and service (before and after sale) and are worth the extra $ for the peace of mind and knowledge that you'll have someone local to call on for help.
Best of luck with your machines - we hope it's something minor and you're up and sewing soon! Don't hesitate to reply to this post if we can offer further help, ideas or suggestions.
Happy sewing,
Kim & Linnette
www.sewingexpressions.com
Posted on Jul 23, 2008
  • 323 Answers
SOURCE: Threading my sewing machine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Aug 27, 2008
I need a picture to thread my sawing machine
What machine?
https://www.bing.com/images/search?q=thread+sewing+machine+diagram&qpvt=thread+sewing+machine+diagram&qpvt=thread+sewing+machine+diagram&qpvt=thread+sewing+machine+diagram&FORM=IGRE
Sep 29, 2016 | Sewing Machines
How can I thread?
there are some threading diagrams on sewusa.com
Feb 19, 2016 | Sew Smart Sewing Machines
How do I thread a sew smart
as per the instructions in your manual.
Jan 16, 2015 | Sew Smart Sewing Machines
When i thread the sewing machine and sew, the stitches do not stay
Possible
you need to change the needle, if it is a little broken at the head, it's not grabbing the underthread.
goog Luck
Jun 23, 2011 | Sew Smart Compact Cordless 17390B Sewing...
Bobbin
this is some ******* ****!
Mar 22, 2008 | Sew Smart Compact Cordless 17390B Sewing...
I need a copy of the instruction manual for the Sew Smart Compact Cordless 17390B.
Feb 09, 2008 | Sew Smart Compact Cordless 17390B Sewing...
Threading a sewing machine
Damn machine!
Nov 07, 2007 | Janome Mini Compact
Threading sewing machine
use this link to their downloadable free guide http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html
Jul 17, 2007 | Brother LS-2125 Mechanical Sewing Machine
Happy sewing,
Kim & Linnette
Nov 17, 2006 | Sew Smart Compact Cordless 17390B Sewing...
Sew Smart Compact Cordless 17390B Sewing Machine Logo
1,165 people viewed this question
Top Sew Smart Sewing Machines Experts
ray gallant
R.A. Ellis
R.A. Ellis
Debbie
Are you a Sew Smart Sewing Machine Expert? Answer questions, earn points and help others
