Question about Mitsubishi WS-65809 65" Rear Projection Television
Bad timer maybe timer light flashes and TV will not turn on
  • Mitsubishi Master
  • 5,138 Answers
Replace Both of your STK ICs they are Big Black ICs will have Part Number on them example STK392-570 go by # on yours Call Mats 1-800-638-3328
Posted on Nov 18, 2009
Green light flashing won't turn on
Likely has bad 1000UF capacitors on DM module. this will prevent rebooting.
Apr 08, 2014 | Mitsubishi WS-65611 65" Rear Projection...
Tv comes on with sound no picture,timer light stays on for about 20secs,then lamp light comes on stays on as tv shuts down,we are stomped,cant fix prob with no screen.
The first question i need to ask is Have you removed the bulb to check to see if it has blown. If there is no visable signs that it is bad then replace it and make sure the door is secure. Secound thing you can do is retrieve the error codes. To do this press and hold MENU and INPUT button on the front of set. The timer light will flash then pause then flash again denoteing a 2 digit code. this will maybe point the way to possible problem
Apr 22, 2011 | Mitsubishi WD-60735 Projection Television
I have a mitsubishi tv model wd-52525 and the green timer light is flashing and it will not turn on. Just bought expensive bulb and replaced it and still blinking
Probley should check the DM board for bad capastors. DM board is inside of a metal case should be on left side of tv when looking from rear capastors should be marked 16v 1000 uF on them should be 4 of them about 1 inch tall green or black or blue or brown maybe even yellow in color if bulage on top then then thay are bad if not still could be bad common problem need to check may or may not be your problem does couse the power light to blink non stop.
Oct 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Sony WEGA Fails to Turn On Stand-by Timer Flashes 7 Times
IC/high power transister(s) and/or other componentshas gone bad gone bad - usually from a power surge. These will have to be replaced. A technician should check these out for you.
Jun 03, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Replaced lamp, still having picture problems.
take it to an authorized samsung service center, your color wheel may be broken or your dmd maybe damage.
Apr 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
The TV turns itself off after 14 minutes
Sounds like maybe you have a sleep timer activated?  There should be an option to reset the tv back to factory reset, this might help you.
Dec 12, 2008 | Toshiba 42HL167 42 in. LCD Television
Timer light is flashing but tv wont turn on!
When the timer light stoped flashing the remote control would not turn on the TV. The next time the light quit flashing I held the power button in on the TV for about 5 seconds and it came on and has had no problems since then with the remote or the local TV power button.
Greg Allen
Aug 29, 2008 | Mitsubishi Televison & Video
Panasonic PV-M2738 flashing light
A BAD PCB (power control board) maybe cheaper to buy new combo
Jan 17, 2008 | Televison & Video
I just replaced my lamp
which light is flashing?? there are two green lights. the timer light and the lamp light.if the lamp light is flashing you have a bad lamp or a bad HV-Starter.Could be a bad DMD-Board as well
Jan 11, 2008 | LG RU-52SZ51D 52" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
54 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
