Question about Dryers
Fan not turning on dayton heater 2e439
I have a discontinued dayton heater 2e439 and the fan will not turn as it should?
it will get a half turn and then kind of hum.
  • Dryers Master
  • 43,501 Answers
The best thing for you to do is to call Grainger repair parts at 1-888-361-8649 If the part is avaiable they can help you. If they don't have a part they can help you find a replacement.
Posted on Nov 14, 2009
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
Electric Heaters and Accessories - Grainger
www.grainger.com/.../electric-heaters-and.../heaters/.../N...
W. W. GraingerCount on Grainger to supply high-quality electric heaters and accessories for ...Electric Wall Mount Heaters ... Electric Space Heater,Fan Forced,120V, ... SearchQ&A ... This fuse is used on driers heater elements, I'm unable to locate these in .... in Ask and Answer are not intended to replace or supplement any professional, ...
DAYTON Electric Space Heater,Fan Forced,120V, - Portable ...
www.grainger.com/.../DAYTON-Electric-Space-Heater-...
W. W. GraingerShop DAYTON Electric Space Heater,Fan Forced,120V, (3VU33) at Grainger. ... Item # 3VU33; Mfr. Model # 3VU33; NSN # ... Country of Origin China Country of Origin is subject to change. ... Alternate Search Terms ... I need a replacement fan motor .... Where can I find parts for Dayton fan forced wall heater mod.5ZK54D.
Dayton Industrial Fan: Amazon.com
Dec 21, 2015 | Dayton Heating & Cooling
Have Dayton 3e227a gas heater fan has quit, need new motor, can you supply source to buy? Tim
Dayton is a Graingers Brand. Go to the site below and I'm sure you can find your part. Put in your Part Number...Jim
http://www.grainger.com/Grainger/rp_parts_home.jsp
Feb 18, 2011 | Dayton (3E227) Gas Radiator Heater
I have a Dayton 3VU32 heater. The fan does not turn when the switch is on fan or the other 2 heat settings. The heater does produce heat. Is there a solution, are parts available and where?
Dayton is a Graingers brand. Please contact Graingers at the web site below to see if parts are available. It may be cheaper to just buy a new heater. Hope this helped you...Jim
Feb 12, 2011 | Dayton Heater,Space,120v
Have a dayton 3e240e heater and the fan does not work, pilot light works and main burner work as well. no fan.
Had a similar problem where the fan wouldn't turn on but everything else worked. If you can verify that your fan isn't kaput, it's most likely the "Fan Time Delay Switch."
After a few hours of searching, you can find them on Grainger. This should be the one for your heater: http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=1vld6&op=search&Ntt=1vld6&N=0&sst=subset&typeaheadSearch.x=23&typeaheadSearch.y=3
It's located in a electrical box behind the heater under the relay (at least it was on mine). Hope this helps!
Feb 06, 2011 | Dayton (3E379) Heater
Have 30,000 btu Dayton heater m#3e3665 when reaches temp. fan
Hi blow heater out with air line flame sensor could be dirty check out pressure switch jump this out see if it lights
Feb 09, 2010 | Dayton (3E379) Heater
Dayton heater Model 2E400. Does the fan draw the air in and than blow the heated air out of the botton of the unit? Does fan turn CCW or CC.
yes, you have the direction of flow correct. The rotation of the fan will be marked on the motor of the fan
Jan 07, 2010 | Dayton Electric Heater
I have a Dayton gas heater Model 3E225
Does the main blower fan kick on? Also, if the heater is vented outside via a flue pipe, there may be a small (about 3 or 4 inches in diameter) vent fan that kicks on to ensure the exhaust fumes are evacuated through the flue pipe. If there's a problem with that fan, the burner won't light either.
Nov 20, 2008 | Dayton (3E379) Heater
My Dayton garage heater model 2E636B does not heat up.
These heaters are the same as the marley heater, the element never gets red hot. the unit is set up so the fan kicks on after the element has heated to a certain temp and turns off after the element has cooled. It is common for these heater fans to cycle on and off quite often untill the air temp reaches about 55 degrees and then will operate normaly. If the fan still cycles too often you may have to replace the fan control and high limit switch. These are not very expensive and easy to replace yourself. they arte usualy attached to the back of the element with clips. The luke warm air is what these units put out. I have an equivelent to the dayton G73 and it heats a 24' X 30' garrage all winter in central Minnesota.
Nov 17, 2008 | Dayton G73 Utility Heater
Capacitor
Here is a link to a distributor with fan specs : http://www.grainger.com/Grainger/wwg/productIndex.shtml?search_type=keyword&QueryString=3C325B&operator=refineSearchResults&originalValue=Dayton+Fans&searchIndexId=1&typeOf=
I do not know which specific motor is used on that fan ( that fan has been discontinued) however you can check out this link http://www.emotorpro.com/index.asp?PageAction=VIEWCATS&Category=280
and have a representative that sells Dayton products answer your question... Hope this helps you...
Sep 09, 2008 | Dayton Permanent Split Capacitor Motor Fan
Dryers Logo
167 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
