Question about HP Compaq Presario V2000 Notebook
Main board troubleshooting with processor no displal..only power come and same moment offf.......only light blink for 1 sec.of power and hdd... whn main board open then remove processor power remain on board.....so is it problame with processor??
  • 5,603 Answers
Battery is first suspect.
Posted on Nov 14, 2009
LG 47LN5200 no picture led blinks then shuts down
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board
Mar 08, 2016 | LG Televison & Video
How do I fix my Sharp Aquos LC-42D62U TV?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 06, 2015 | Sharp Televison & Video
Solid Amber Light on Motherboard/No Beeps
Below is a copy of the diagnostic manual. According to it, I think it's the power supply.
http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/trouble.htm
Jun 09, 2012 | Dell Inspiron 530 Desktop Computer
Blinking amber power button light on Optiplex 990
It seems you have a problem with your Processor regulator that is why your computer sending an amber message.
This problem always happens to Dell Optiplex mostly and there is no solution for this except replacing your Motherboard.
To verify this problem unplug yellow (2 yellow and 2 black cables) cables near the processor and then try to turn it on when you see the fan processor can run smoothly and the power light getting green that is the sign that your processor regulator having some sort of problem.
Hope this will answer your problem
Apr 30, 2012 | Dell OptiPlex 990 SFF 1 x Core i7 2600 34...
I am not sure if this is a problem with power supply. Yesterday suddenly my machine stopped working. I wasnt using it. It just shut off. Now when I started the cpu, I see one green LED on the mother...
the problem is in your motherboard..this most cause unregulated flow of power from the source electric..but if the green led is off so its the processor.try to test it with a motherboard tester..or get another board that same spec with the you have,and transfer the processsor if it is working
Feb 10, 2011 | Cooler Master RS-400-PSAR-J3 400W ATX12V...
Thethe tv will not come on and power and theopc is flashing.
Ok This is how to troubleshoot the TV, there are lights on the front and you are mainly concerned with two of these lights (the power light and the OPC light). I) If non of the lights come on then this is a AC Power failure (There is a loose connection or you need to check the Power/Inverter unit or the Main unit) II) If the power light is blinking at a rate of one blink per min and the OPC light is off (then there is a CCFL backlight problem) III) If the power light is blinking at a rate of two times per min and the OPC light blinks at a rate of one time per min (13V/UR10V failure you need to check the Power/inverter board or the main board). IV) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of two times per min (3.3V Main Failure check power/inverter board or Main board). V) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of three times per min (UR6V failure check power/inverter board or Main board). VI) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of Five times per min (Panel 5V failure check LCD control unit or control panel).
Sep 07, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Wont boot
In that case, looks like you have a faulty motherboard (video chip) chip-set. Remove motherboard from the casing and apply thermal paste. Also clean-up the whole board. I hope this will help you.
machinetosh of (tipidpc.com) site
look for kuya boy laptop
Global PC Laptop Professional Services
09126888500
Apr 01, 2010 | Toshiba Satellite 1905-S303 Notebook
When I power up my PC, the red LED HDD light is solid red (no blinking) and then after a couple of minutes or so, it goes very dim and I cannot get the monitor to turn on. Is this a HDD drive issue or is...
i believe that it is a motherboard issue (video card, processor or RAM) but not the HDD. you can get into bios without hard disk or even if its not detected. so the major problem will be the four hardwares.
Feb 05, 2010 | Office Equipment & Supplies
No picture and the led ligth is blinking panasonic veita 52
If you have the flashing red light of death you can use the chart below, and call Panasonic to have it replaced. At the bottom is the list terms.
BLINKS PROBLEM MALFUNCTIONING PART
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Panel = Plasma Display Panel (Plasma Glass)
D Board = Format Converter / Plasma AL / Sub-Field Processor
DG Board = AC-DC Converter / Digital Signal Processor / Full HD
Microcumputer HDMI Interface / Peaks Lite 2
H Board = Speaker Out / Sound Processor
AV Terminal / AV Switch
P Board = Power Supply
PB Board = Fan Control
SC Board = Scan Drive
SD Board = Scan Out (Lower)
SS Board = Sustain Drive
SU Board = Scan Out (Upper)
Jun 11, 2009 | Panasonic (TH-50PZ700U) Television
Panasonic TH42PA20 - No Picture
If you have the flashing red light of death you can use the chart below to see what the blinks indicate and call Panasonic and have the part replaced, at the bottom of this page is the meaning of terms.
Apr 13, 2009 | Panasonic (TH-50PZ700U) Television
HP Compaq Presario V2000 Notebook Logo
144 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
