Question about Texas Instruments TI-84 Plus Calculator
Combinations graph My calculator can not use nCr functions in the y= screen. The table of said formula will result in errors and the graph will not appear. This is consistent for using Y= B nCr x and y= B!/(x!(B-x)!) I need to find a way to get a graph and table for the following formula, where every variable can be changed prior to calling it: Y= ((a ^ x ) * ((c-a) ^ (b - x)) / c ^ b) * b nCr x
    Sniper:
  • 73 Answers
You need to follow your user guide for calculaing nCr function
Posted on Nov 16, 2009
How can I calculate combinations with fx-991ES PLUS?
Use nCr (the shifted function of the divide key). For example, to find the number of combinations of five things taken three at a time, press 5 SHIFT nCr 3 = and see 10.
May 03, 2014 | Casio FX991ES Scientific Calculator
My MS Excel vlookup function ASCII type table contains both upper case and lower case letters, characters like ( and % or *, and numbers. It seems to return the numerical equivalent of upper case letters...
Correct a #N/A error blueup_clv.gifShow All bluedrop_clv.gifHide All This error occurs when a value is not available to a function or formula.
  1. Optionally, click the cell that displays the error, click the button that appears ooui1_za06043871.gif, and then click Show Calculation Steps if it appears.
  2. Review the following possible causes and solutions. blueup_clv.gifMissing data, and #N/A or NA() has been entered in its place
    Replace #N/A with new data.
    Note You can enter #N/A in those cells where data is not yet available. Formulas that refer to those cells will then return #N/A instead of attempting to calculate a value.
    blueup_clv.gifGiving an inappropriate value for the lookup_value argument in the HLOOKUP, LOOKUP, MATCH, or VLOOKUP worksheet function
    Make sure that the lookup_value argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) is the correct type of value — for example, a value or a cell reference, but not a range reference. blueup_clv.gifUsing the VLOOKUP, HLOOKUP, or MATCH worksheet function to locate a value in an unsorted table
    By default, functions that look up information in tables must be sorted in ascending order. However, the VLOOKUP and HLOOKUP worksheet functions contain a range_lookup argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) that instructs the function to find an exact match even if the table is not sorted. To find an exact match, set the range_lookup argument to FALSE. The MATCH worksheet function contains a match_type argument that specifies the order the list must be sorted in to find a match. If the function cannot find a match, try changing the match_type argument. To find an exact match, set the match_type argument to 0.
    blueup_clv.gifUsing an argument in an array formula that is not the same number of rows or columns as the range that contains the array formula
    If the array formula (array formula: A formula that performs multiple calculations on one or more sets of values, and then returns either a single result or multiple results. Array formulas are enclosed between braces { } and are entered by pressing CTRL+SHIFT+ENTER.) has been entered into multiple cells, make sure that the ranges referenced by the formula have the same number of rows and columns, or enter the array formula into fewer cells. For example, if the array formula has been entered into a range 15 rows high (C1:C15) and the formula refers to a range 10 rows high (A1:A10), the range C11:C15 will display #N/A. To correct this error, enter the formula into a smaller range (for example, C1:C10), or change the range to which the formula refers to the same number of rows (for example, A1:A15).
    blueup_clv.gifOmitting one or more required arguments from a built-in or custom worksheet function
    Enter all arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function.
    blueup_clv.gifUsing a custom worksheet function that is not available
    Make sure that the workbook that contains the worksheet function is open and the function is working properly.
    blueup_clv.gifRunning a macro that enters a function that returns #N/A
    Make sure that the arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function are correct and in the correct position.
Oct 31, 2008 | Computers & Internet
How do i solve this factorial equation? 8!/5!x3!
How to calculate 8!/(5!3!)?
For small numbers (8,5,3) you can use the factorial function key (I will tell you later how to access it) and enter 8! divided by 5!, divided by 3! For numbers greater than or equal to 70 you cannot calculate the factorial: the result is too large for the calculator's memory.
However the formula you wrote is an instance of a combination 8C5 or 8C3 (they have the same value.
Most scientific calculator have three functions: the n Factorial n!, the Combination function nCr and the permutation function nPr.
  1. Turn Calculator ON
  2. Select the Run icon and press EXE.
  3. In Run Screen Press the OPTN key
  4. Press F6> to pan to the other tabs
  5. Press F3:Prob
The first tab (F1) is marked x!.That is the factorial.
The tab (F2) is marked nPr is for the permutations
The tab (F3) is marked nCr and it corresponds to the combinations.
To use nPr or nCr you enter the larger number n, you press the F key under nPr or nCr. If you press F2 you see a fat P, if you press F3 you see a fat C. Complete by entering the value of r (the smaller number)
If your problem corresponds to Select 8 objects, 5 at a time regardless or order (combinations) you type 8 F3 5 and EXE Result is 56.
Aug 31, 2012 | Casio CFX 9850GA Plus Calculator
When you graph a function,where can I find the table??
I find it easier to generate the table then look at the graph. Here how you go about it, illustrated with screen capture taken from the newer version of the calculator. k24674_7.jpg
Press the MENU button.
Use arrows to highlight the TABLE application (1st screen).
Enter a function expression in Y1=
And press the function key F6 under the TABL menu tab. (2nd screen)
A table is generated (3rd screen)
Press F5 (G-CON) for a connected graph, or F6 (G-PLT) for a dotted graph.
The graph is shown (4th screen).
Use the Zoom function (ZoomAuto) or any other Zoom or change the window dimensions to suit your needs.
Jan 19, 2011 | Casio FX-9750GPlus Calculator
When i enter the binomial probability formula into the casio fx-115es it will not operate. it says that the problem lies in the (n-X)!X! part of the formula. I'm writing everything exactly the way it is in...
You may be writing the expression as they appear in the formula, but the problem stems from the fact the factorial function increase rather rapidly and you cannot calculate the factorials of numbers larger that 69 which is the limit of the calculator.
However if you use the built in Combination function nCr, you will avoid the problem. In the binomial function, the n!/(r!(n-r)!) factor can be replaced by nCr or nC(n-r).
Do not use the explicit form with the factorials because you will get an overflow.
Nov 09, 2010 | Casio FX-115ES Scientific Calculator
Fibonacci formula won't graph, but will show table
Fibonacci sequence is the series of numbers 0, 1, 1, 2, 3, 5, 8, 13, 21, 34, ...
At first type Fibonacci equation in Y editor with condition x>=0 and then graphing it. See captured images with enlarged form of graph
Apr 11, 2010 | Texas Instruments TI-84 Plus Silver...
Some y values in my table say error when i graph logs
That is normal behavior. The log functions are not defined if the argument (x value ) is negative.
Mar 23, 2010 | Texas Instruments TI-83 Plus Calculator
A Committee has 19 members, of which 10 are Democrats and 9 are Republicans. A subcommittee is going to be formed with 3 Democrats and 3 Republicans. How many possible subcommittees can be formed?
How many ways can you select 3 members out of 9 republicans: nCr (9,3)
How many ways can you select 3 members out of 10 democrats: nCr(10,3)
For each single choice of 3 reps you have 1*nCr(10,3) possible subcommittees.
Hence the total number of possible suncommittes is nCr(9,3)*nCr(10,3)
Explictitly
# of possible subcommittees is [9!/(3!*6!)]*[10!/(3!*7!)] or 10080
To calculate you can use the explict formula above or use the nCr function of your calculator
To access the nCr( function press [2nd][5] (MATH) [7:Probability][3:nCr]
You can also just type the name of the command respecting the case ( C must be upper case)
Jan 31, 2010 | Texas Instruments TI-89 Calculator
Graphing Feature error message
This usually happens after the statistical graphs have been used. You should deactivate them. Press [2nd][Y=] (STAT PLOT). Select [4:PlotsOff] [ENTER]. Calculator echoes Done on main screen.
Restart your graphs.
Dec 28, 2009 | Texas Instruments TI-83 Plus Calculator
Binomial function
The binomial probability distribution is defined as
P(r;p;n) =(nCr)(p^r)*(1-p)^(n-r)
where n is the number of trials, p the probability of success, and r the expected result.
Let n=20, r=7, p=0.15 ( I do not know wether this exemple has any meaning in the context of your problem, but you have to enter values that mean something to you. I am only showing you the key strokes
To enter 20C7 you press 20 [SHIFT][nCr]7 ;
To enter 0.15 to the power 7 you type 0.15[X to ] 7 the key is between
[x²] and [log]
To enter (1-0.15) to power 20-7, you type 0.85 [X to] 13
With [*] standing for multiplication key , and [X to] the raise to power key, the exemple above can be entered as
( 20 [SHIFT][nCr] 7) [*] ( 0.15 [X to] 7 ) [*] ( 0.85 [X to] 13 ) [=]
Here is a screen capture to show you what it looks like. However on this calculator the combination 20 [SHIFT][nCr] 7 is represented as nCr(20,7).
Hope it helps
Nov 12, 2009 | Casio FX-115ES Scientific Calculator
Texas Instruments TI-84 Plus Calculator Logo
103 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
