Question about Kenmore Washing Machines
I have a Kenmore top loading washing machine model 92529110. My wife has been noticing that the tub leans toward the front causing the water to hit the back edge of the tub instead of running straight into the tub. She can push the tub toward the back and it runs in fine. What would be the cause of this?
  • 4chilesa Jun 16, 2010
    I found out the springs on the tub had come lose causing it to tilt toward the front. The machine itself was level.
    President:
  • 2,976 Answers
The machine needs to be leveled. Unscrew the front legs until the machine is level. If there isn't enough screw, or if your floor is really uneven, put a board under the front legs. After you get the front level, lean the machine toward you, tilting it front, until the back feet are about 3 inches off the floor. Let the machine drop. This will set the back legs into position. They are self leveling.
Posted on Nov 14, 2009
Water leak at bottom of Whirlpool Estate washer. Removed the cabinet. No leaks from the water pump, hoses or inlet valve. The tub leans a little toward the front of the machine. When filling/rinsin
It is common on Whirlpool models for the water to splash out the top when filling especially when sheets or nylon cloth is loaded in the washer. Air fills the cloth and balloons the garment up this caused water to bounce off the garment and splash out the back. This is the most common reason for those mysterious leaks. Lowering the water pressure coming into the washer can help prevent this.
Jan 25, 2015 | Whirlpool Washing Machines
Inner tub does not sit corrects and water is leaking bad when run
There is 6 springs? And all of them are on right? Sounds like one of the back springs came off or broke. You should be able to shake the whole thing around and it should center up. Take the top of the washer off. Remove the cover on the control panel then unplug the wire harness and pull the fill switch hose off of the switch. There is two screws holding the top on at the side panels in the front. then lift it up and slide it forward to release the back hinges. Then you should be able to see the back ones.
May 31, 2010 | Kenmore 22932 Top Load Washer
While my kenmore top load washer is pumping water into the tub, water is splashing from the rim of the tub and leaking behind the tub onto the floor. If before I turn the washer on I push the tub towards...
if it keeps failing into that position
then either your machine nneds to be releveled or there may be someting wrong with the suspension but with this model i would have to believe your machine is out of balance tword the front
relevel and try that.
Oct 27, 2009 | Washing Machines
Describe your Kenmore 24032 \ 24036 Top Load
MAke sure that the cothes are not unbalancing the tub. Iv seen this happen where the clothes are unbalancing the tub and it moving around and the when the water for the rinse is coming out its not getting in the tub its splashing on the top of the tub ring due the the unbalanced spin. does this happen when you wash a heavy load? do you notice it not doing that when you washer a light load?
Jul 26, 2009 | Kenmore 24032\24036 Top Load Washer
Tub wont sit level
What is the model number of the unit?
Feb 26, 2009 | Kenmore 22422 Top Load Washer
Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Feb 23, 2009 | Kenmore 46462 Front Load Washer
Washer leaks from rear. The hoses are perfect.
Hi .If you look, the tub is leaning towards the front . Theres a counter balance spring that has fallen off. remove the cabinet, to gain access, and replace the spring
Dec 23, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Wahing Machine Motor Overheating
...same problem here. any answers?
May 02, 2008 | Washing Machines
Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
May 19, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
193 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
