Bad diode BYT56J EADA and need to replace it but cannot cross reference the number to get a new one
  • 5,603 Answers
The part is a fast recovery type. It is a BYT56
Mouser.com says to call to order it:
http://mouser.com/Search/Refine.aspx?Keyword=byt56
Posted on Nov 14, 2009
  • 405 Answers
Here is some data: http://www.datasheetcatalog.org/datasheet/vishay/86032.pdf
Nothing special. almost any fast swithing 600V 3A diode will do.
Behringer 1320D monitor sudden death
I am sorry but the only repairs of behringer stuff has to be by them. This manufacture has most part numbers custom design so that the technicians can't look up the specs to get accurate value replacements. I have never found a behringer part number in any cross reference I have seen yet.
Mar 04, 2014 | Music
Tip
Magnavox TB100MW9 DTV Converter repair
After a close-by lightning strike, my Magnavox TB100MW9
Digital TV Converter box stopped working. I took it apart and found a
shorted diode (the fat one on the power side of the board)
marked with the number SB340. From the NTE cross-reference
web site, I found a replacement diode, NTE586 (Si, Fast
Switching, Schottky Barrier Diode) that cost me $2.40 at
a local electronic parts store. I replaced the diode and
it works fine!
on Apr 27, 2015 | Magnavox TB100MW9
Need to replace a diode/numbered Q701 on the powerboard and the numbers on the part are useless in finding the replacement could i get a schematic for the montior's power board if possible
q is the reference for a transistor..not a diode....what is the part number on the part? You can try to cross it to NTE by going to NTE.com
Dec 21, 2011 | ASUS Computers & Internet
Need replacement diodes for Hobart model # RC-256 input volts230/460 3 negative 3 positive total of 6 per welder.
Are there any numbers on the diodes. If so, do a web search to find cross reference and supplier. You can use any brand diode if it matches current and reverse voltage specs.
Sep 12, 2011 | Hobart Welding Tools
Picture is too large for screen
You did not specify a brand, or model number. In any case there is a pincushion problem. Sometimes a bad ground, or leaky diode in the horizontal section. It may be a bad resistor or retrace capacitor. It may be your switching transistor (NTE 2361, see cross references) next to the horizontal transistor. Could be an open coil etc. There are many possibilities. You must narrow it down in the horizontal deflection are of the TV main board. Sorry I cannot be definite in my answer. A TV tech always appreciates a brand and model number. Thanks for asking and show all hands of support!
May 20, 2011 | Televison & Video
All funtchions work except it dos'nt heat up anything Light comes on, turntable works, timer works. But no heat
I tried the ICE60705 number and it did not cross http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=IEC60705
Is that a serial number by chance?
To do any of the below the chassis cover must be removed.
To perform a diode resistance check you must first ground the high voltage capacitor several times to avoid a nasty shock.
To check the Diode you have to disconnect one side if the diode before reading resistance. Read the Diode on R X 1000 and then reverse the meter leads is should only ONE way. IF it reads both directions or not at all then it has failed.
To check the HV Capacitor (After grounding) you reverse the leads repeatedlyand watch for a momentary jump on an analog meter EACH time the leads are reversed. No jump of the meter needle = bad Capacitor.
Diodes can be found here:
http://www.appliancepartspros.com/Appliance-Parts/?keyword=Diode%2c+Sharp
I know that this is an 850W free standing Microwave. I just can recall the model number from memory.
If you find either one of the 2 parts bad I recommend contacting a LOCAL appliance parts center with parts in hand for the simple fact the model number is not crossing.
Just make sure they failed per directions above before replacement.
Thanks again for choosing FixYa.
Kelly
P.s. If the above parts check out good then that leaves the door switch or the magnetron as possible failures. If the Magnetron has failed you may want to evaluate repair vs total unit replacement cost of the microwave.
Aug 19, 2010 | Sharp R-1480 Microwave Oven
I have a burnt diode D4 on APC BE500U UPS, what are the diode specification/part number?
D4 part number is EGP20D, which is a diode for Ultra Fast Switch. 200V, 3.0A. You can find more details in this site: www.nteinc.com
Go to the cross reference and type this number.
Nov 22, 2009 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
NGK-6000H Generator Field Coil Diode
If the doides have a number on them, goto www.nteinc.com and cross reference them to a good number. Then you can find a dealer on the web site also.
May 11, 2009 | Honda Mmd 5000 Watt Generator W/ Engine...
Components in 1983 datsun/nissan a11-652-805 ecu
Have your tried the factory service manual: http://www.xenons130.com/reference.html
Hope this helps!
Todd in Idaho
'69 510
'83 280ZXT
'91 300ZXTT
Oct 20, 2008 | 1983 Nissan 280ZX
Televison & Video Logo
239 people viewed this question
Top Televison & Video Experts
