Question about Car Audio & Video
The display on our VW Passat is showing PHONE KEY 103 which is the radio station. the radio is very faint even when up full. When ignition is off the radio appears to be off as it has no display but you can still hear it and it does not switch off.........any ideas? We have just had a new motor fitted for the heater but the radio did not develop this problerm for 24 hours after the repair. There is a phone connected but never been used. One of the settings on the radio is 'phone' and the setting are accessed by holding in the TP button for more than 2 seconds but this does not work! Nothing is moving on the display.........help!!
Sorry no solution but i do have exactly the same problem! If i find a solution i will post it here. If you work it out i would appreciate a tip off. Cheers.
Posted on Feb 04, 2010
Immobilizer active reset on 2006 volkswagon passat
First of all you need to programm all ignition keys using suitable diagnostic equipment (VAS, VAG-Com) connected to the data link connector of the car.
You have an electronic immobilizer key recognition problem. Now your key chip is not recognized by the transponder antenna fitted on the ignition switch barrel.
This warning lamp indicates that the engine is locked by the immobilizer system, and the engine start sequence must be repeat again.
From year 1995 in Audi-VW (VAG) cars is used engine immobilizer. The VAG group immobilizer system consists of an immobilizer ECU which controls the recognition of keys and the Engine Management ECU system. Immobilizer is activated when the ignition key is removed and, together with the engine control unit, largely prevents unauthorized starting of the engine. The system uses a transmitter and receiver unit in the ignition key (transponder). Whenever an attempt is made to start the engine, it transmits a new code to the car's electronics. The immobilizing is only cancelled and car motor electronic receives permission to start engine if the key sends a right authorization code.
Oct 12, 2011 | 2006 Volkswagen Passat
I need help unlocking my 99 vw passat stock radio, changed the battery and now my radio won't turn on.and i do not have the radio code..can anyone help me
IMPORTANT NOTE:
You must have the security anti-theft code for your VW radio from the car manufacturer, or from a VW dealer!
You can find the radio code at: http://www.radio-code.co.uk/
The sequence of programming for a 1999 VW Passat radio is:
1. Simultaneously push "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
For example: we have the security code "5079". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted.
7. Then simultaneously push again "SCAN" and "RDS" keys to confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready to use!
Sep 21, 2011 | 1999 Volkswagen Passat
I have a 98 passat and the radio says save how do i get it working thanks
IMPORTANT NOTE:
The sequence of programming for 1998 VW Passat radio is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready for use!
Apr 17, 2011 | 1998 Volkswagen Passat
How do you use radio code for 1995 vw passat to get radio out of safe mode
IMPORTANT NOTE:
The sequence of programming for 1995 VW Passat radio is:
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
Mar 17, 2011 | 1995 Volkswagen Passat
I have passat 1.9 tdi variant,2001. year.my batery is dead.when i take a new batery i was missing code for radio in car.type of radio is vw gamma.when i switch radio on, on the display write safe.please...
How to exit the 1998 VW Passat radio out of SAFE mode:
IMPORTANT NOTE: You must have the security anti-theft code for your VW radio from the car manufacturer, or from a VW dealer!
The sequence of radio programming is:
3. By the #1 key you will set up the first safe code digit.
4. By the #2 key you will set up the second safe code digit.
5. By the #3 key you will set up the third safe code digit.
6. By the #4 key you will set up the four-th safe code digit.
Dec 05, 2010 | 1999 Volkswagen Passat
Entering radio codes for a 1998 passet
If you don't have MODE and SCAN buttons ( I didn't ) you can try as above but with TP and TA - they worked for me.
Feb 22, 2010 | 1998 Volkswagen Passat
1995 V.W PASSAT
If I understand your post right, you have the code but need the procedure on how to input/enter it into the radio. To my understanding, a 1995 Volkswagen Passat would have a non-BOSE unit with or without CD changer controls. It was a premium sound system with anti-theft coding.
Pls try:
1. Power the radio ON till "SAFE" is displayed;
2. Press the AM/FM and SCAN buttons simultaneously till display shows "1000". (In some versions, it is the seek and the two scan buttons);
3. Release the AM/FM and SCAN buttons;
4. Enter your security code using the first four station buttons on the radio;
5. The first button changes the first number of the four digit code;
6. The second button changes the second number and so on and so forth;
7. Once the proper code has been entered press the AM/FM and SCAN buttons at the same time and hold until the radio accepts the code;
8. You have two tries before the system will lock you out for an hour;
9. Should you happen to have a three digit code, pls make the first digit a zero;
10. The first digit can only be 1 or 0 (the 0 will not show up so for a zero, push the button until the 1 disappears).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 08, 2008 | Audio Players & Recorders
Car Audio & Video Logo
93 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
