Question about iRiver PMP-120 Digital Media Player
Boot failure system file has an error connect to computer refer to trouble shooting on the manual
    Problem Solver:
  • 6 Answers
1st go to I and dload the version you want to run. My PMP shows 1.23 but I couldn't find that version so I now run 1.24.. Save the dloads in a new folder on your computer.. There should be (7) items that dload to your computer.
*** I have found that just copying the files to your PMP Player will NOT work.***
I had to delete ALL (7) of the system files and folders.
1.) BMP folder
2.) etc folder
3.) system file
4.) (4) "Version-[0x..... " files..
So there were (7) items I had to delete. Once deleted go to the folder you saved the dloads to. I had to click and drag each item to the drive your PMP player is connected to. Once all (7) items have been placed on your PMP player disconnect it, turn off the power, wait a minute and turn it back on. These steps worked PERFECTLY for me. Please let me know in this forum if this helps..
Posted on Jan 10, 2008
Error 0xa0000001 in window
Possibly but it may be caused by many other issues.
This is from Microsofts web answer;
There are many reasons why your system may crash due to these stop errors. The most common scenarios are: Faulty drivers, Hardware issue (especially RAM) or Anti-virus software problem.
You may want to try the following and check if it helps.
Method 1:
Run Memory Diagnostics test to check for any memory problems. Refer the following link for the same.
How do I know if my computer has a memory problem?
Method 2:
Update the chipset, video card, display and network adapter drivers to the latest by visiting the computer manufacturer's website.
Update a driver for hardware that isn't working properly
Update drivers: recommended links
Method 3:
A clean boot helps to verify if any third party application services or startup item is causing this issue.
You may refer the following KB article to put the computer in clean boot:
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
After the trouble shooting steps please refer to clean boot link to put the computer back to normal start up mode.
Jan 20, 2014 | HP Pavilion Computers & Internet
Error Code Trouble Shooting
The Boot Sector was damaged and the startup files are missing. May need factory service.
Dec 11, 2013 | Dedicated Micros Digital Sprite 2 RS Video...
I have a w3622 and put in a new hard drive and tried to use the OS disk that came with the computer. what I get is PXE-E61: media test failure. check cable. Disk boot failure.insert system disk.
Sorry to hear about the trouble you are having. Try the following tips and lets see if we can get it up and running.
-Set the boot order in BIOS to boot from the disk drive first. In order to get to the BIOS, you will need to select BIOS option or Settings when the machine is booting up.
Most often, the above error is caused due to incorrect BIOS settings or a faulty hardware, such as hard disk. Sometimes, the error may also occur if the computer tries to boot from a device, on which it cannot find the required boot files. An improperly connected hard disk is also known to cause the same type of issue.
You should follow the below steps sequentially in order to isolate the cause and solve the issue:
  • Verify all the cable connections of the hard disk. An improper or loose connection is likely to be the reason, in case the hard disk has been recently installed or moved.
  • Check if no other storage device is connected to the computer. If it is, remove it.
  • Enter the BIOS setup when trying to start the computer and see if hard disk has been correctly setup and detected in BIOS. If the hard disk cannot be detected due to any reason, you should consider the next suggestion as it might be physical failure.
May 09, 2011 | E-Machines eMachines Desktop PC
15" Dell monitor is blank-connected
there can be many issues why there is no screen on this other computer.
1. video card failure
2. No system boot "bios issues"
3. Cables not connected correctly
4. Bent pins
First you want to do some trouble shooting. If this monitor works with a computer and not working with another then obviously there are some issue with the computer itself.
Have you check the resolution that Windows is putting out?
Try booting in SAFE mode this will set the computer's resolutions to the lowest so you can see a image. Most monitors in this caliber cannot handle certain high resolution signals.
We are here to help please update us with any more information you may have such as:
Are you see-ing any boot up screens?
Do you hear the system actually boot?
Thanks for using I do hope this was very helpful information for you.
Nov 30, 2010 | Dell E153FP 15" LCD Monitor
My dell laptop gives me a error code of 0146 amd keeps rebooting
Error Code 0146 refers to failure to find or load NTLDR files, needed to run your operating system. Place your Restore disk in the DVD drive, power up the computer, hold down the F12 key till boot screen shows up. Boot from DVD and run Repair to restore these files.
Sep 25, 2009 | Dell Inspiron 1525 Notebook
Ink System Failure on HP Photosmart c5180
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
Failure to boot after several hours of operation
assuming you set the date and time, the error message checksum can refer to incorrect memory timings along with the front side bus speeds, so check the processor bus speed eg 533MHZ or whatever and check the memory speed as if they are different you wont get it to boot, you will need to reset the bios if you cannot get it to run at all.
Sep 09, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Boot failure
Dead Hard Drive. Thats all i can tell you. Did you hit a huge pothole or drop it today? With the way firmware is today you'll juest need to send him in. Sorry to say it, but that's the solution! thanks! Let me know of any followup needed
Jun 23, 2007 | iRiver PMP-120 Digital Media Player
Iriver PMP-140 boot failure message
when i turn on my Iriver PMP-140 it comes up with a message reading
Boot Failure
System file has an error.
To solve the problem, connect the device to computor.
(refer to 'trouble shooting' on the manuel)
Filmware Ver. 1.24
I dont have a manual though.
May 13, 2007 | iRiver PMP-140 Digital Media Player
iRiver PMP-120 Digital Media Player Logo
238 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
