Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool 9100 will run diagnostic test but will
Whirlpool 9100 will run diagnostic test (C:00 codes) with no faults but will not start normal wash cycle. Selector lights flashing, New User control, machine control, & door swith
  • mark_morr692 Nov 17, 2009
    Cut power to the washer. It started working normally.
5 Suggested Answers
SOURCE: flashing code F-6
F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Posted on Apr 12, 2009
  • 73 Answers
SOURCE: washing machines door open light is on, but door is shut
Found it for myself - F7=motor fault. New motor brushes fixed it. This error code will come up if the motor fails to turn on demand at any point in a program, be it filling, in a wash cycle, or spinning.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
Posted on May 23, 2009
  • 56 Answers
SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Posted on Feb 11, 2010
KevinWhite
  • 1902 Answers
SOURCE: F35 ERROR IN DIAGNOSTIC TEST C:00 I have been
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Posted on Oct 15, 2011
I have a whirlpool awm8121 washing machine. It starts to fill then stops itself and drains. Ran diagnostic test and it has fault code 1. Inlet hoses and filter are clear. Any ideas appreciated thanks
Hello: Fault detected malfunction code 1 for your model states
"Water not entering or not detected". Check inlet tap, cold inlet valve, pressure switch. Sounds like you said water is going in and has good flow, but may not be "detected". Could be a sensing problem like pressure switch.
Dec 16, 2016 | Whirlpool Washing Machines
F26 code change door lock code came back when it time to spin i did a diagnostic test c:00 came up
C:00 is the beginning of diagnostics cycle need to let it finished. It will chime when completed
Jan 06, 2016 | Whirlpool duet Washing Machines
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
How do I run diagnostic test
Washing Machine Diagnostic Test & Error Codes (Cabrio ...
? 1:29
https://www.youtube.com/watch?v=yoCTzbl4FPs
Nov 22, 2010 - Uploaded by applianceassistant
Washing Machine Diagnostic Test & Error Codes (Cabrio, Bravo, ..... What can i do? ... I tried to put it in ...
Fix and Diagnose Kenmore Oasis / Whirlpool Duet hE Washer
? 7:21
https://www.youtube.com/watch?v=8Z1JdsJYa14
Apr 24, 2011 - Uploaded by Alprazolam
Tried to do the diagnostic test and it still won't do anything. ... If the latter, and it won't run any diagnostics ...
How do you do a diagnostic test for a Whirlpool Cab
My whirlpool cabrio washer doesn't work, I ran diagnostic test and I get a series of lights flashing but don't know where to find the code bases on the pattern of lights flashing.
go google and type in -- fault codes for whirlpool cabrio washing machine --- and there will be a pdf version for down load
or you can go google and type in --workshop manual for whirlpool cabrio washing machine --- and there will be a manual in pdf version which will have trouble shooting section in it with the codes as well
Oct 15, 2015 | Whirlpool Washing Machines
Why washer will not do diagnostic test or erase E38 error code
[PDF]Fault Code Bible v1.2 - ResearchGate
www.researchgate.net/publictopics.PublicPostFileLoader.html... ResearchGatesimple, clear instructions on how to read the faults or use the diagnostic routines. .....Resetting the error indication does not rectify the fault but only erases from .... E53 Input circuit EMC errors Displayed as error code, washing machine start ... if you choose position 10, 11 or 12, the test will terminate without pressing.
Sep 16, 2015 | Washing Machines
F13814978
Try this diagnostic cycle operation to reset.
To start the Service Diagnostics Cycle, press the
following keys, in order, in less than 6 seconds, while in standby(power on but unit off):
Heated Dry, Normal, Heated Dry, Normal
To Rapid advance one interval at a time, press the Start key, noting that
unlike Standard cycles, the Diagnostics Cycle automatically resumes
after door openings and does not require pressing Start to resume.
Once the diagnostic cycle has run and shut off, run a normal wash cycle, empty and with no detergent, to reset the control to factory "normal" operation. Make sure there's plenty of hot water.
Feb 14, 2014 | Whirlpool 24 in. GU3200XTP Built-in...
I have an arrow code f 26 on my duet washer
Drain pump triac failure This error code is displayed when the main electronic controller fails to detect the triac that controls the outlet drain pump during the wash cycle.
  • Check pressure switch contacts and connectors
  • Failure of the pressure switch or level sensor can also give rise to this fault code
  • Run test program
  • If failure persists after test and verification of pressure switch, replace main controller
Dec 27, 2013 | Whirlpool duet Washing Machines
Code F 35 i cant find my manual
christydubar --
Whirlpool Duet GHW91000 Technical Service Manual does list F35 error code. Try running the diagnostic test below and then write back with condition indication code. -- SWT
DIAGNOSTIC TEST
The control must be in the OFF state before pressing the touch-pad sequence to start the test.
Starting the test mode
Close the door.
Press the Control On button.
Select the DRAIN/SPIN cycle.
Select NO SPIN by pressing the SPIN SELECT button, as needed.
Push Prewash Option button four (4) times within five (5) seconds. C:00 will show in the display.
NOTE: If Model does not have PREWASH Mode as an option, press RINSE/HOLD.
If the Starting procedure fails, push PAUSE/CANCEL button. Then repeat the starting sequence.
Test Program Control during Execution
To advance to the next step of the test procedure, push Prewash Option button two (2) times.
Indications
C:00
C:01
C:02
C:03
C:04
C:05
C:06
C:07
C:08
Aug 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool calypso clothes washer stuck on the "FL" for overfill code - will not reset after hitting stop/cancel or after unpluging - one year ago the customer service for whirlpool gave us the...
Try pressing the following key pad buttons within 5 seconds - PREWASH OPTIONS - WASH TIME, PREWASH OPTIONS - WASH TIME, in this sequence and allow the washer to run. The LED display will start counting down as the washer begins a sequence of short diagnostics tests. If no error is present, the washer will return to standby. If the error persists, you may have a blockage in your drain pump. Please run the test and let me know the results. Total test time is about 1 minute 40 seconds. I hope this helps you.
Jul 24, 2008 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
180 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
