Tech manual for Asus Z96J lap top. need to replace the dc power jack how do I access the power jack?
    Novelist:
  • 111 Answers
For all the function and portability laptops provide, there are also some drawbacks. The biggest problem with laptops is with battery life. To get constant battery power, the laptop has to be plugged into a wall outlet. The wall plug then connects to the DC jack in the back of the laptop. The DC jack is no more than a little piece of metal that conducts the electricity for the computer. These DC jacks are known to be fragile and break off easily. If this happens, you can open the laptop and replace the DC jack yourself.
  1. Step 1 Remove the internal battery pack from your laptop. Flip the laptop over and locate the release button for the battery pack. Hold the button in to slide the battery pack free. It is important that you remove the internal battery pack as well as unplug the power cord from the wall outlet to prevent risk of shock while working inside the laptop.
  2. Step 2 Unscrew all of the screws on the underside of your laptop. The number of screws will depend on the model of computer. There should be one at each corner and then one or two screws that hold the hard drivetech manual for Asus Z96J lap top. need to replace - mag-glass_10x10.gif cover in place. Once the screws are removed, take out your computer's hard drive. Newer-model computers will have a hard drive that slides out of the side of the computer.
  3. Step 3 Locate the two screws at the back of the computer that hold the laptop screen's hinges in place. Once these two screws are removed, gently pull up on the screen until you clear the silver pegs from the holes in the laptop's body. Two wires lead from the screen into the computer, so ensure you do not pull so hard that you disconnect them. Carefully set the laptop screen aside so it does not get damaged while you work inside the computer.
  4. Step 4 Separate the two halves of the laptop's body to expose the computer's internal components. Flip the keyboard on its face, making sure not to disconnect the keyboard's connector. Underneath the keyboard will be a metal plate that covers the computer's motherboard. Unscrew the screws that hold this plate in place and set it aside.
  5. Step 5 Locate the DC jack for the laptop. Most all laptop's DC jack outlets are located at the back left corner of the computer. Using your tweezers, remove the old DC jack. Identify the slot in the motherboard that the old DC jack came out of. If the DC jack was loose before you removed it, there will be a small slot at the base of the opening in the back of the computer that the DC jack pops into. Using the tweezers again, slide the new DC jack into this slot until you hear a clicking sound. To hold it in place you can solder the new jack to the motherboard, or simply superglue it in place. Don't use too much superglue or you will risk losing the ability for the jack to conduct electricity.
Posted on Nov 14, 2009
Power jack broken. will not charge.
Most sockets are wired away from the motherboard so if it is, purchase one through fleabay and fit it. Otherwise get someone who knows to fix it.
May 04, 2016 | ASUS R510LA-RS71 15.6" Notebook - Intel...
"k55A" dc jack replacement
Hello Kenneth,
The dc jack replacement cable connects from the white connector to system board and the connector where you connect the adapter lay on the edge of board usuallyc6c10d03-2117-4a84-8cc2-a16171601653.jpg
I like to use a litte bit of super glue to keep it held in place on the board.
Gotta remove some components to access it .
Mar 12, 2014 | ASUS Notebook K55A-DB51 15.6inch Core...
Asus 1025c won't get any power
did you try another power adapter? If it's not the problem of the power adapter, you might need to check again the power jack, Asus uses a very small power jack for EEE PC series, it is easy to loose on the motherboard..
If a power jack needed, check this page: http://www.lapdiy.com/asus-eeepc-eee-pc-1025c-netbook-dc-power-jack-socket-p-42259.html
wish this can help you.
Jan 16, 2014 | ASUS 1025C-MU17-BK Eee PC Flare 1025C...
Hi, the charging connector is broken, can it be replaced easily? If so , how do i get to it? the lap top is a TJ74-RB-050UK. Cheers
the dc jack (charging connector) can usually be bought for about 5 pounds or less from ebay. As far as fitting it goes it depends how confident you are. You will need to disassembel your laptop and remove the broken jack from the motherboard and then solder the new one on.
Jul 15, 2012 | Packard Bell (190169) Power Supply
Broken power plugin port
The power plug in port you refer to is the DC Power Jack.
The AC adapter (Charger) converts AC electricity into DC electricity.
DC electricity has two poles. Positive, and Negative.
(Just like on a D cell flashlight battery)
The center pin of the DC Power Jack is the Positive connection.
The outer metal spring-like pieces, on the inside of the cylindrical shape surrounding the center pin, are the Negative connection.
(The pieces of spring-like metal, all connect to the Negative connection in the DC Power Jack)
Example of a replacement DC Power Jack, for the Asus Eee PC 1005HA Netbook,
http://www.batterysupport.com/asus-eee-pc-1005ha-jack-p-303527.html
[ Note*
Cannot agree with the replacement instructions they offer, at the bottom of the page.
Not everyone has access to a hot-air gun. A 25 Watt soldering iron, and Desoldering Braid, is better, and more easily accessed ]
A few articles dealing with replacement of a DC Power Jack,
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
http://www.laptoprepair101.com/laptop/2006/01/28/toshiba-satellite-m35x-a75-power-jack-problem/
http://www.laptoprepair101.com/laptop/2006/05/27/failed-laptop-power-jack-workaround/
1) Remove ALL power. Remove the AC adapter, (Charger), and Battery.
2) Observe Anti-Static Precautions. Buy, and use an ESD wrist strap.
Electro Static Discharge.
(Average cost is from $3 to $6. Connect the alligator clip to a good ground source.
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
If you wish to proceed in replacing your DC Power Jack, and need guidance, post back in a Comment.
Regards,
joecoolvette
Dec 01, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
When plugged in the unit starts to smell hot like an electical burn,
Turn it on turn it over and see if the fan is operating. If not power your lap top off and replace the fan. You may have to not use this computer until the fan is replaced it is advisable not to. The smell you have may be dust smell when it gets hot. Clean throughly and make sure that all the dust is out of your computer. Also recommended a lap fan also which goes underneath the laptop to assist with cooling.
Lap tops are very touchy and need to be kept cool at all times otherwise you will be purchasing a new lap top if you do not take care of the cleaning or the cooling or the fan not working or spinning slowly. Check all this out. Critical if you do not understand what I mean take your computer to a local shop for immediate care. I hope this assisted you. John
Feb 01, 2011 | Toshiba Satellite P205D-S7802 Notebook
Asus f80 can't start. when connect to power adapter no activity on notebook, no power led etc. led on power adapter ok.
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 21, 2010 | ASUS F80Q-X2AM Notebook
The DC Jack seems to be loose, I've tried two different AC Adapters and discovered that they are in fact not the issue. The screen will show constant switching between power mode and battery mode at times,...
More likely than not the DC jack will need to be desoldered from the mainboard and replaced or the whole mainboard replaced.
Without warranty coverage you're looking at around $75 for a qualified tech to solder a new DC jack in or the full cost of the computer (replacing the whole system) as parts for the Eee PC's are prohibitively expensive and motherboard/mainboard replacement not really an option.
Jan 22, 2010 | ASUS Eee PC 1000HA Notebook
Computers & Internet Logo
574 people viewed this question
David Payne
David Payne
