Question about Craftsman Garden
How to put c ring on starter for lawn tractor
2 Suggested Answers
  • 109 Answers
SOURCE: The electric Starter motor will not stop running
If the starter continues to spin after the engine is started..replace the key switch, it is bad
Posted on Apr 16, 2009
JD LA110 lawn tractor with briggs engine cranks over with spark plug removed, Plug installed locks up when cranking ,
probably not the starter unless there is a bent pinion shaft in the starter, damaged ring gear teeth or something in the ring gear teeth
turns over good with the plug removed indicates incorrect plug in use and it is protruding into the cylinder and the piston is hitting the plug
the tread of the plug should be the same length as the thread in the head
May 04, 2017 | Cars & Trucks
My tractor dies when I put it in gear.
solenoid only engages the starter nothing else .it could just need the carb cleaned
Apr 16, 2016 | Garden
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Replacing starter bendix
If the ring is of round section (like an "O" ring) then use a flat bladed screw driver ,place the blade between the ends of the ring and twist the driver. The ring will ride up in the groove and out. Use a second screw driver to prize out of ring as you work around the ring. Once you have the ring all out simply place an open ended spanner that fits around the shaft but the ring will not pass through and tap the spanner to push the ring off the end of the shaft
Aug 09, 2013 | John Deere Starter For Kubota Tractor Lawn...
Can not remove starter
You mean you cannont physically take it out. Is the starter drive bound up with the ring gear? If thats the case put the tractor in high gear and rock it by pushing on a rear tire to unstick the drive... Need more info.
Aug 20, 2010 | Ford 8n,9n,2n, Tractor Starter With Drive
42 in. Deck 19.5hp Lawn Tractor: Craftsman Lawn tractor my engine clicks but will n...
battery has a low charge or the starting gear on the starter is bad. just remove cover and see if the starter ingages and cranks the fly wheel. look at the gear itself to make sure the teeth are good ,if not replace the plastic gear. takes 5 min.
May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Model #917.270810 riding lawn mower. Turns over then quits and just makes a ratcheting noise, won't turn over or start. Thought it might be the starter?
not a expert just trying to help,,sounds like the starter gear has gone out,, need to replace,, most of them have either pin to knock out,or a ring that has to be froced off .. hope this help
Feb 13, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Deere 318 with Onan B43G won't start w/ starter engaged, but if the engine "catches" when I turn off igniton, it runs fine. I can only get it to start by pulsing the starter on and off--only starts when...
318's are known to have flywheel problems and poor engagement of the starter due to incorrect alignment of the starter to the ring gear.To check either of these things you need to take the motor out of the tractor to look at the ring gear,starter drive and starter aliggnment.Before you go through this pain replace the ignition switch or have it tested.p.s deere only supplies a replacement flywheel but a ring gear can be ordered through a case dealer if you get it for a stinner with the onan engine.
Nov 14, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftman Lawn mower continues to burn oil at a fast rate
Are you getting a lot of smoke? If so the oil is getting past the rings and burning.
Jun 23, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
