Question about Franke VNX-120-45 Vision Double Bowl Undermount Stainless Steel Kitchen Sink
We purchased a franke double sink at lowes for $108.00. we cannot get the basket to stop leaking, we've used plumbers putty as suggested but its not working and the sink still leaks. what can we do
  • 43,501 Answers
Take it back out and clean all of the plumbers putty off. make sure that the bottom of the sink and the basket is clean and dry. Take a good quality silicone caulk and make a 1/4" bead all the way around the basket where it meets the sink. Tighten the basket nut till it gets nice a snug but not os that you spin the basket much. Then let the caulk setup over night. Trim away the excess with a sharp knife from the top and hook up the drain. This will seal a basket everytime. I never use plumbers putty anymore.
Posted on Nov 14, 2009
  • 82 Answers
Crazy not to use putty. The problem is the nut below the sink - it wasn't tightened enough.
Posted on Nov 27, 2009
Hi When I push down the Franke Strainer Basket in order to fill the sink basin, it appears to leak in the cabinets below. With out pushing down the strainer basket whilst tap is running there is no...
More than likely it's leaking from where the body meets the sink. U might need to pull it apart, clean it up, and re apply plumbers putty to the sink and re apply the body. If you are doing this I would recommend buying a new basket assembly from the hardwear store. Just makes more sence than re using the old one. That is enles it's new. Hope this helps
Mar 29, 2011 | Franke 900SN Strainer Basket: Satin Nickel
I installed a black granite sink, but the BASKET STRAINER is leaking. Do I need to buy a specific Basket Strainer for the Granite sink and take model # of the sink.Or can i just buy any basket...
Hello.
You shouldn't need a special strainer.
Where the strainer meets the sink surface, ( the lip of the strainer ), should have plumber's putty.
Take a chunk of plumbers putty and roll it out like a snake and then stick it under the lip of the srainer all the way around. Set the strainer in the hole and then on the bottom side add the rubber seal, then the cardboard, or metal glide ring and then the nut.
As you tighten the nut it will squeeze out the excess putty and allow you to remove it.
1. Sometimes people try to use the rubber seal on the top side of the sink, but it goes on under the sink.
2. The cardboard/metal glide ring prevents the nut from tearing up the rubber seal so you can really tighten it.
I hope this helps you!
Thanks, Donnie
Mar 25, 2011 | Franke Kindred DP2233/90/1 Granite Double...
Moen basket strainers for Corian sink Use plumbers putty and no rubber gasket
I'm not sure what your question is, or if you are posting information.
Plumber's putty is purchased at local home center, hardware, plumbing outlet.
Container is smaller than coffee cup, and 3 times heavier.
Material is gray and thick and slightly oily and not sticky on the fingers.
Clean sink opening.
Apply fairly thick amount of putty completely around sink opening. About 3/16" thick.
Putty should extend wide enough so sink basket sits entirely on top of putty.
Push sink basket down into putty.
Tighten sink basket very firm from below.
Wipe away excess putty inside sink bowl with finger, and then a paper towel or damp sponge.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 15, 2011 | Moen 22036 Stone Stainless Steel Sink...
The gasket coming out of bottom of our sink erator was leaking and spewing. when we replace the washer before bolting on the gasket do we use plumbers putty?
Plumbers putty is for setting sink basket into sink.
I use rectoseal on all tubular washers and joints,
Smear it on thick and then assemble parts, and rectoseal ensures nothing will leak.
Dec 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Two rubber gaskets and a fiber gasket came with new strainer. do i use all the gaskets? what about plumbers putty
You are attaching sink strainer to sink opening.
1) Use plumber's putty. Finger-size roll of plumbers putty is applied around opening from top, or applied to the bottom of strainer basket. (Some sinks require silicone. Do not use silicone unless required by the sink manufacturer.)
2) Sink strainer is pushed into the sink opening, making sure it is centered and level.
3) From below, the rubber gasket is applied first, and then the paper gasket is second, and then the basket locknut.
4) Tighten locknut very firmly.
5) Wipe away excess putty on bottom.
6) Push down stainer from top again, and tighten nut some more.
7) Wipe away excess putty around bottom and top.
8) The cardboard washer lets the locknut rotate easily.
Dec 18, 2010 | Moen 22036 Stone Stainless Steel Sink...
Badger 1/2 hp in sink erator (garbage disposal) steady stream leaks from the bottom near the reset button. It appears to be coming from a drain outlet (a small hole, dia. approx size of smallest screw ),...
You might be able to buy time filling hole with epoxy or silicone caulk and let dry for 2 days.
10-year old garbage disposal had a good run.
Disposal will need to be replaced at some point.
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket.
How to: Disconnect p-trap and tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Before installing new disposal.
Attach electric wire to new disposal.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Use new connector washer.
Re-assemble tubular pipe.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image below, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Apply good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Nov 26, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Use foam gasket on sink strainer along with plumber's putty?
Usually the gasket is not foam but black rubber. There may have been a piece of foam as packing to protect the stainless. You would apply the plumber's putty directly to the sink. Insert the strainer directly into the putty, compressing the putty. Under the sink, remove the excess putty that extruded through the opening. Apply the rubber gasket to the bottom of the sink, and then the nut (sometimes a "cup" and then the nut) .When the nut is tight, remove excess putty inside the sink. LEAKPROOF!
Jul 06, 2010 | Franke Strainer Basket Sink Hardware
I have a kohler cast iron enamel sink. The
ALL BASKET STRAINERS ARE PRETTY MUCH THE SAME. PLUMBERS PUTTY WORKS FINE. I BELIEVE ITS THE ORDER OF INSTALL THAT IS CAUSING THE LEAKS. STRAINER AND RUBBER GASKET GOES IN FROM THE TOP. IF NO RUBBER GASKET IS PROVIDED, THEN PLUMBERS PUTTY WILL SUFFICE. UNDERNEATH, ANOTHER RUBBER GASKET AND/OR PAPER GASKET, THEN THREAD ON THE NUT. TIGHTEN IT SNUGLY.
Dec 25, 2009 | Plumbing
Rust around the drain in the larger of the two sinks
You will need to reset the basket strainer using plumbers putty. Is there a garbage disposal installed? You will need to remove it to get to the basket strainer.
Mar 31, 2009 | Franke VNX-120-45 Vision Double Bowl...
What to use plumbers putty or silicone on strainer basket rims installed on granite sinks
you always use plumbers putty on the strainer baskets. you can never use to much just remove the access when tightened. If you use silicone you will have leaks withen a year.
Mar 24, 2009 | Pegasus Technologies Pegasus 25 In. Black...
Franke VNX-120-45 Vision Double Bowl Undermount Stainless Steel Kitchen Sink Logo
550 people viewed this question
Top Franke Home Experts
Donni Steen
Gil Shultz
Freddy
Are you a Franke Home Expert? Answer questions, earn points and help others
