Question about Denon Audio Players & Recorders
My dad has a Denon Al24 processing receiver. We have had the receiver about three years. The problems I have found so far are that the sub channel coming out of the receiver has continual hum that is louder than the music. Also it''s very very quiet. When we first got it half way was really loud, but know you have to crank it all the way and it's still really really quiet. peace, matt
  • thetoadstick Nov 14, 2009
    Oh I checked with my own receiver and the sub works fine, but thanks for the post. Also I found the mute button on the romote and it doesn't do anything it says when it is on or off, but it doesn't change anything. Maybe the mute got stuck on in the wiring inside?
    Genius:
  • Denon Master
  • 1,667 Answers
First check to see if the sub woofer itself is not defective.
There are components in the various associated circuits that are failing. I realize the receiver and sub woofer are not old, but this is very possible.
You will have to determine which of the units is defective, then you can call the manufacture to find out who their authorized service rep is.
From experience, I have seen electrolytic capacitors of various types cause these types of faults. The service work is time consuming, but can be achieved. The labor cost for the time involved to troubleshoot the unit will be more expensive than the parts themselves.
Jerry G.
Posted on Nov 14, 2009
My denon reciever is stuck on mute.
Posted on May 04, 2010
Connecting a passive subwoofer to a denon 2113
you need another reciever/amp to power that sub, because that denon reciever is designed for a powered sub,. if you have another old reciever/amp laying around, you can connect the sub out from the denon into an auxillary input of any old reciever/amp, (switched to that input) with speaker wires from old reciever/amp to the passive sub
Mar 05, 2013 | Denon Avr-2113ci 7.1-channel Home Theater...
How to wire sw8mk2
Does the receiver, Have a (RCA) Jack on the back of the unit ,Where it is written sub out,If it does, You need what is called a sub conecter patch cord to hook up the sub.If it is a powered sub, If the receiver does not have a sub jack you can not hook up a sub to it.
Oct 11, 2012 | Denon AVR-1612 5.1 Channels Receiver
Hi, I have a denon AVR 889 about 4 years old and the subwoofer suddenly stopped working,how can i check if its the amp or the sub thats the problem?
A Denon AVR 889 is not a sub so we don't know anything about the sub in question.
Maybe the existence of the sub is no longer set in the AVR. Look at the speaker definitions first before going to wild.
Try another cable to the sub.
OR, run the sub's signal supply cable to one of the Tape Outs on the receiver and tune in something on FM. If that works a) it will be loud, and b) go back to the SUB settings on the AVR.
Crack the sub open and access the terminals on the speaker itself. Disconnect them from internal components and run one of your amp channels directly to it. If it works, the amp or signal path are dead. If it doesn't work, it's a dead driver.
May 19, 2011 | Denon AVR-889 Receiver
I just received a Denon AVR-4308ci receiver. I have two passive subs in my system. The receiver only has one powered output. Since I am not using the surround back speaker outputs can I use these for the...
Sure, if you want to hear Surround Back program material coming from the subs without midrange or tweeters. (Sarcastic) Of course, the LFE program material will still be going into a black hole somewhere.
Run the subs in series with each other -
Sub Amp negative to 1st speaker negative;
1st speaker positive to 2nd speaker negative;
2nd speaker positive to amp positive.
Run the speaker level adjustments routine and enjoy.
Just for giggles, try what you were thinking about. You won't hear much from the sub(s) unless you programmed the Surround Back channel as full-range and then have something like the Apollo 13 launch for program material. Normal audio won't send much low-frequency material to those channels. The optimal place for subs is on the LFE or sub channel.
Nov 17, 2009 | Denon AVR-1507 Receiver
MK Sub woofer to Denon AVR
you caan either buy a SPLITTER OR JUST RUN A SINGLE LINE OUT OF THE RECIEVER INTO THE SUB. BOTH DONT NEED TO BE PLUGGED IN. SUBS ARE MONO NOT STEREO. THERS NOD IFFERENCE IN SOUND
Apr 10, 2009 | Onkyo TX-SR875 Receiver
Denon avr 2802 can't get subwoofer to work all else fine
in the Denon setup under speaker configuration set the sub to LFE+Main
Jan 02, 2009 | Denon AVR-2802
I don't have a powered sub! +other problems.Denon 2308
Unhook the sub ! center speaker is for front sounds like the people talking. and a sub is for the bass like a bomb going off SO hook your sub to the sub out on your reciever. As far as the vcr..are the vcr inputs on the denon yellow? if so thats a video in (or) out but if its red or white thats for the vcr sound .
Nov 26, 2008 | Denon AVR-2307 Receiver
Hi from the Philippines
as far as DSP surround processing is at question, yamaha will do best but when you ask for audio performance, output clarity and performance.... Denon or HK.
Feb 17, 2008 | Yamaha RX-V661 Receiver
AVR 810 Denon Receiver Sub Woofer Hookup?
Denon AVR-810 was a quite out-dated model. I had owned since 1992. It shown 'Protection' on the screen for 2 months ago and not yet been fixed. Better to replace a modern one or repair it at a reasonable costs.
Dec 28, 2007 | Denon AVR-2106 Receiver
284 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
