Question about Onkyo TX-SR875 Receiver
Firmware Onkyo 875 1.04
Let me know if you can reach me at my email the update 1.04 of the amplifier onkyo 875.
Thank you in advance.
Best regards.
jeesusfreek
  • 18 Answers
SOURCE: Onkyo TX-SR500 loosing settings
Turning any receiver off will erase the settings - there is no backup battery (Onkyo uses Battery Free Memory Backup) and the length of time depends on the capacitor charge. Why not just leave the receiver plugged in? Stand-by mode uses a negligible amount of power - enough to keep the capacitors charged and the LED on the front panel on.
Posted on Jan 28, 2008
SOURCE: Code for Sony BDP-S300 Blu-ray player on Onkyo remote
Player can be made to work without remote. But it is a pain.
You need to press pause then play in the right combination.and you can get both DVDs and Blu Ray disks to work. I bought a store floor model that did not have a remote. I went through the same problem when I would lose the remote for the HD-DVD player. My four year old daughter knows this trick pause pause play for DVDs and pause play pause play for blu
Posted on Sep 21, 2008
  • 4 Answers
SOURCE: 875 onkyo dead display
The 10 Ohms resistor R9304 in series with the the 44V display power supply was open.
How to find it:
Remove the to cover.
On the right hand side of the front panel you will see on the side a wide white flat cable going toward the back of the receiver.
Beside it is a 4 black wire band connecting the front panel to a 3x4cm power PCB which is parallel with the front panel inside the receiver (attached to the front frame).
It has visible on the left side a diode bridge and a fuse - above the fuse you can find the R9304, a SFR16 package (1x3.5mm) marked BrownBlackBlack.
Check continuity.Replace if open wit a 1W resistor
Good job ONKYO, save 1/3 of a penny...
For the DIY:
As an added step I replaced the R9304 with a 2W 47R resistor, replaced the series transistor regulator Q9301 (tall TO92) with a bigger package (isolated TO220) and one of the two series 22V zenners from the base - D9310 - with a 10V one.
Output voltage drops from 44V to 34V, display is slightly dimmer but overall stress is down.
Posted on Oct 09, 2008
  • 15 Answers
SOURCE: onkyo HT-R500 amplifier protection circuitry activated
u have a short.
remove all speakers cables and turn it on, if remains on and u can up the volume do the next.
1: turn it off.
2: connect only 1 speaker cable (each time to see if the short is in one speaker or cable)
3: turn it on, up the volume.
this way u must be able to see what cable or speaker have the problem.
if still the same prob the short is inside.
i put a answer of a prob where cant up of 41 check the cleaning method.
Good luck
Posted on Jan 12, 2009
SOURCE: onkyo Remote Controle Codes for XBoX 360
Try 32083 or 30522.
Posted on Jan 26, 2009
Have a Onkyo TX-RZ710. Fail to do firmware update. Try to do using USB, now Recovery:NET display. Dont know what to do?
Hello, I am sorry for your issue. The update may have stopped due to a power loss or another reason. The receiver needs to be sent to a service center. I have included a link below to search for a center. Thank you, Onkyo USA.
http://www.onkyousa.com/Support/servicecenterLocator.php?source=globalnav
Mar 19, 2017 | Onkyo Audio Players & Recorders
Onkyo NR5010 receiver select usb input and the now initializing do not display. some options are missing,only "setup" can be selected, "net" and "usb" and "firmware update" can not be selected.
Hello, I am sorry about your issue. Please email me at askonkyo@us.onkyo.com with your serial number and I will check on your options. Thank you, Onkyo USA
Mar 04, 2017 | Onkyo Audio Players & Recorders
Onkyo sr313 amplifier has arc arc is on tv but i cannot get any screen setup or sound from tv
Hello, please confirm that HDMI Control RIHD is turned on in the receiver programming. Thank you, Onkyo USA
Feb 24, 2017 | Onkyo Audio Players & Recorders
Onkyo reciver powers on but no sound
most likely a bad digital board. onkyo has a problem with one of the chips on the board having bad solder joints causing the firmware to not load correctly
Feb 11, 2017 | Onkyo Audio Players & Recorders
No sound onkyo 807;
Hello Richard, please email your serial number to askonkyo@us.onkyo.com and I will check on your options. Thank you, Onkyo USA
Oct 01, 2016 | Onkyo Audio Players & Recorders
Onkyo tx-nr509 Receiver not talking to Panasonic TV TX-L42E31B
Hello, I am sorry about your issue. If the cable is long from the receiver to the TV it may cause video issues. Please try a reset of the receiver by pressing and holding vcr/dvr and then on/standby. When display shows clear let go. The receiver will shut down. Turn back on and test. This procedure will take the receiver back to factory defaults. Thank you, CB
Mar 24, 2017 | Onkyo TX-NR509
Hello, i have a problem with my Onkyo receiver. Every time i put it out, it has lost all his institutions. I don't know why this is happens. Every time i have to install the whole receiver again. Do you...
It will help diagnose problem if you provide the model no. of the Onkyo receiver.
Normally the settings are stored in a flash memory device (EEPROM). It is possible this is failing.
Have you recently updated the firmware of the unit? If you know how to run to reset the receiver then try it and see if holds the settings after that.
Oct 24, 2010 | Onkyo Audio Players & Recorders
Onkyo M-282
check your amplifier output speaker impedance requirements..
example: 8 ohms...build a speaker 8 ohms in parallel or series connection..
check the impedance using ohmeter ..you must reach the required impedance..
use 1 cell battery to check if you speakers are in-phase...if one speaker did not ..reverse connection and check again ...to give the good sound...hope you understand my english..:)
May 24, 2010 | Onkyo M-282 2-Channel Amplifier
Open Questions:
See all Onkyo TX-SR875 Receiver Questions
Onkyo TX-SR875 Receiver Logo
418 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
