Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Drum for Image Runner 2200
Is there someone who can instruct me on how to change the drum on image runner 2200.
  • fionaco Mar 05, 2009
    replaced the drum but when I go to press "ok" at the end of the introduction it won't respond??
  • Canon Expert
  • 287 Answers
Hi Deborah.I can tell you. Open the front cover,drop/release the transfer unit located directly below the drum.To the right of the drum is the develpment unit. Use the handle on the dev unit to cam it away from the drum. Now there is a "thumb" screw on the front of the drum unit, its almost like the knob on a gumball machine as you are gripping a slotted "knob".turn it counterclockwise and remove it (you will use it to install the new drum).Now slide the drum unit straight out toward you, noticing the rail/track the old drum is riding on along the top edges.Then follow the instructions enclosed within the box for the new drum.I will attempt to describe it in case you have bought a 3rd party drum that may not have the instructions. Obviously remove all the packing materials mindful that the "greenish/gray" roller is the drum and is fragile and is sensitive to fingerprints and such. Use common sense as you remove the pressure release blocks at the front and rear of the drum, since they will seem difficult to remove but you can do it. :-) Install the drum in the reverse order followed to remove the old one.Once installed,you will need to enter "service mode". This is done in a 3 step process. Look at the operator control pad and to the right of the display you will see a button that says "additional functions". Press additional functions>>>next press the numbers 2 and 8 AT THE SAME TIME>>> next press the additional functions button again. If done properly a new screen will appear that will have "blocks".Press "Copier". Now a new screen appears with tabs at the top. One of the tabs says "FUNCTION". Press that tab. Once again a new menu, but this time the focus is on the new tabs in the main viewing area. Find "DPC" and press it.In the lower right corner of the display you will see "OK" .Press it and you will have successfully introduced the new drum to the copier (or visa/versa) and 1 sheet of paper will exit the copier.It may look nasty but that is normal. Congrats!!!!!! You are a drum professional !! I hope I helped walk you thru this adequetely and helped you. Take care and GFL :-)
Posted on Jan 19, 2008
Just replaced mine 10 minutes ago.
Open front cover, drum is at the top on the left. You should find a smaller size grey knob to unsrew and release part of the drum. Next you'll want to release the blue lever on the right, shifting the toner roller to the right. You will also want to release the feed tray by pushing the green lever on the left back to the left. At this point you should be able to pull the drum free, carefully. (Grey pull grip)
When you install the new drum be sure to hold back the black bar with the spurs on it. Slide in slowly, resting on the metal guides. Replace the grey mounting screw and put levers back into position.
You should be good to go.
Posted on Apr 14, 2009
  • Debi Tucker Nov 18, 2011
    do you have to enter in anything like what jeff said to do? I got all the way to hit ok and when I hit ok nothing happens? Its copying tho
Image runner 2200 its showing code error E000007-0000 what can i do sir/madam
image runner 2200its showing code error E000007-0000what can i do sir/madam
Feb 24, 2011 | Canon (6981A002AA) for imagerunner 2200,...
I need to know what is the kind of drum a Imagerunner 1630 uses.
An OPC Drum is used, you can use Drum of these models image runner 1310, 1330. 1370, 1510, 1530, 1570
Mar 29, 2010 | Canon Image Runner 1630 Copier Copier
Blank sheets when Copying on the Canon Image Runner 1310.
Hello sir; I would like you to check the charge corona wire inside the drum cartridge or you just replace a new drum cartridge, before you change also check the discharge corona wire at the bottom inside the machine.
Sep 17, 2009 | Canon imageRUNNER 1310 Copier
Replaced toner in a Canon image runner 2200 copy comes out blank
1) you do not dump toner into the drum! Juo dump it into the toner unit.
2) didi you after replacement put the blue toner handle (right from toner unit) into the left position?
May 27, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Canon image runner 3100 - How do I remove the drum
I have error 000020-01a2 plese hel me
Thank you,Nick
Aug 16, 2008 | Canon imageRUNNER C3200 Copier
Image Runner 2200
Hi Willow. If you purchase a genuine drum fom Canon the instruction are in the box. If you have bought a drum from Katun that may not be the case. My email address is I can help you and its pretty easy with a little guidance from me or some one who does this stuff. Let me know if you have the benefit of the instructions as that would be best for you since it has illustrations which are far more helpful than the written word that I would provide you with. No matter what I will gladly help. ...........Spinal
Jan 08, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Canon Image Runner C3200 GPR 11 Drum Units
error code eo-20 on canon pc740 without replacing drum/toner unit
Nov 05, 2007 | Office Equipment & Supplies
Computers & Internet Logo
724 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
