Question about Logitech MX1000 Laser Cordless (097855023933) Mouse
When i left click to drag it is glitchy it will drop the window i am dragging then i have to pick it up again
  • 788 Answers
This is a wireless mouse and if dropped a few times, will run out of alinement.
Make sure that your mouse reciever ( plugin is not behind the unit and on one side or the other.
Also, you may have a reset button underneith the unit. If so, push the reset button and try it out.
Posted on Nov 14, 2009
    Master:
  • 956 Answers
Make sure batts are not low/
Make sure your micky mat is clean. A grubby mat will cause a similar prod.
If this fails, uninstall/reinstall/restart? Good Luck.
Having a problem transferring my music from my LimeWire library to my Music library on my computer to download to my RCA MP3. Can you help?
open Windows Media Player then syc with your sansa or media player then load songs to it........Drag and drop is the easest way simple Left click hold Drag Release Drop
Jul 04, 2010 | RCA OPAL M4001 MP3 Player
Tip
Copy & Paste - Drag & Drop of Files and Folders
Do you find it difficult to drag and drop? Copy files from one folder to another OR move a file from one folder to another? Try this:
  • Open the Windows Explorer. How? Hold down the [WIN] key together with E key. Make this window size in between MAXIMUM and MINIMUM.
  • Open one more window and size it medium as before.
  • Adjust the positions so that you can see both windows side by side
  • Select a drive and folder from one window.
  • Slowly drag it and drop it to an empty space in the other window.
  • If you hold down the [CTRL] key while dragging, you will get a duplicate in the second folder.
  • OR highlight a file from one window , right click, then click on COPY; Now click into the next window, right click on an empty space and click on PASTE
Have a Good Day!
luciana44
on Dec 19, 2009 | Computers & Internet
How do i combine my C drive with my Wd my cpu is full and my wd is empty I wanted to know if its possible to combine them so i dont have to keep moving everything after it installs
It is easier, and safer to just move all your documents,videos and music to the WD HDD.just drag and drop from 1 to the other.
click on my computer and open the WD Hdd. create a folder named "My Documents"
click on my computer again, leaving the 1st window open and select drive "c" or "my documents" on drive "c" anad literally drag and drop the folders accross by left clicking on the folder and dragging to the wd hdd and relasing the button.
Feb 17, 2010 | Western Digital 320GB MyBook External USB...
How do i get music on to my sansa clip+?
Loading Music
You can transfer music from your computer to the Sansa® MP3 player using the drag-and-drop method or using music management software like Windows Media Player.
Drag and Drop (Windows)
Follow these steps to drag-and-drop music to your Sansa® Clip+ MP3 player:
1.
Connect your Sansa® Clip+ player to your PC.
2.
Select Open device to view files using Windows Explorer on initial connection or by going to My Computer.
3.
Double-click on the Sansa Clip+ MP3 player.
4.
Double-click on Internal Memory.
5.
Double-click on the Music folder.
6.
Drag and drop music files from your computer to the Sansa® MP3 player’s Music folder.
You can also drag and drop files to a microSD™ card inside your player by going to My Computer > Sansa Clip+ > External uSD Card.
Feb 07, 2010 | SanDisk Sansa Clip MP3 Player
How to create playlist on e260 sandisk sansa pm3 player
this is from sansa website FAQ... check it too for ur other concers... well i hope this is what ur looking for...
How do I create and transfer playlists into my MP3 player using Windows Media Player 11?
STEP 1 – Create a playlist
  1. Run Windows Media Player.
  2. Click Create Playlist located in the top left corner.
  3. Type in the name of your playlist.
  4. Drag and drop music files into the Playlist Window.
  5. Click Save Playlist to save the list.
STEP 2 – Transfer the playlist to your device
  1. Click the Sync tab on the top bar.
  2. Drag and drop your playlist from the left window into the Sync List window on the right.
  3. Click Start Sync.
Sep 13, 2009 | SanDisk Sansa e260 MP3 Player
Unable to drag and drop files
let me whether u r not able to drag it from a folder to another or drag it to a start up or quick launch .
1. if you want to drag to startup grpoup or quick launch then go to :-
a. Right click on the task bar goto properties , select it
b.select start menu tab select customize
c. Again select advance tab and check the option Enable dragging and dropping. pls find it. it is in the second line .
now u will be able to drag and drop .
Jun 17, 2009 | Computers & Internet
Wireless Optic Logitech mouse performace
I had the exact same problem with my original Logitech wireless mouse that came with a wireless keyboard. I eventually figured that the button component inside the mouse wasn't making consistent contact causing unintended double clicking or dropping while dragging. I fixed it by doing some soldering to switch the left mouse button with the right mouse button, since I didn't have to use double clicking or dragging with the right mouse button. It worked pretty well for several months until the switched left button started showing the same problem again. Now my newer Logitech mouse (it's more expensive Nano wireless mouse) is having the same problem after about 1 year using it. I think there's a serious durability problem with the button component that Logitech is putting on their mice. I may do the same trick again on this mouse, but now I don't consider Logitech as a good mouse manufacturer anymore. They used to make good quality hardwares but I guess they aren't that good anymore with all those cheap Chinese suppliers for their parts. :(
Apr 28, 2009 | Computers & Internet
I cannot transfer photos onto my memory stick from windows photo gallery on vista home premium. I right clicked on the folder name looking for either ''send to'' or ''save'' so I could transfer the whole...
Drag and drop. open my computer and select source file, then click my computer again and select the memory stick ( you should have 2 open windows, best if minimilised ) then just drag and drop. Mouse over, left click and hold the left button drag the picture(s) to the stick and let go of the left button.
Apr 26, 2009 | Computers & Internet
Left Mouse Down Doesn't Maintain Selection
Check the CCORNELL posting for the solution. Your mouse is double clicking when it should be only single clicking.
Dec 06, 2008 | Logitech Cordless Mouse
Cannot minimise yahoo messenre window
Click middle icon in top right corner until only 1 rectangle shows
Drag the whole page to the left by grabbing the top border and dragging and dropping the page until you can access the right hand border
Drag and drop the right hand border to the position you want.
Do the same with left hand border
Check default by maximiize & restore down
To increase page size Crtl & + ( in stages )
To decrease page size Ctrl & - ( in stages )
To restore default Ctrl & 0 ( zero )
Dec 05, 2008 | Yahoo Messenger
Logitech MX1000 Laser Cordless (097855023933) Mouse Logo
490 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
