Question about RCA L32W11 32 in. HD-Ready LCD Television
RCA HDTV, indoor antenna and Dish Receiver 311
What cables are needed to connect my new RCA HDTV to an indoor antenna and Dish Receiver 311, in order to get local channels in HD.
And, into where does each connection go? Help.
Thank you.
  • JeffSp Jan 03, 2009
    I am also want to better understand how to connect an indoor antenna with my direct tv system to get local HD over the air. I got a switch similar to this http://www.amazon.com/gp/product/images/... at Lowe's for about $5. It works but I have to always get up and slide the switch from watching direct tv to local HD channels. Is there a better way to set this up to create a more integrated experience? Any suggestions where else to go to get easy to follow instructions on how to best set up an indoor antenna along with direct tv? thanks in advance
  • Anonymous Feb 23, 2009
    i have old 50 inch sony projection , i also have dish 311 for asian program how can i connect my air antenna to receiver and get local digital signal
I want to use two (2) 311 dish receivers with only 1 outside antenna.
Posted on Jan 24, 2009
Will a 7yr old dish receiver work today on dish satillite
With an antenna that is pointed correctly to satellites 110 and 119, the receiver will function, but will not have access to paid channels without authorization from DISH (which you can get by calling 1-800-333-3474). You may have to run a check switch test after connecting to antenna by accessing the menu, system set-up, installation, check switch.
Jan 27, 2013 | DISH Network 311 DTV Receiver
Sd dish reciever not recognized by hdtv tuner
Hey dgrines81!
I would need more information to provide an accurate solution including what model of receiver, but it sounds like you have an SD receiver hooked up to a HD TV.
Our SD receivers can show picture on an HD TV, they just need the correct cable. If your TV has the spot, I would recommend using RCA (Red, Yellow, White) cables. Plug those in to the receiver and the TV and then change the input. If the problem continues feel free to reach me here, or at thomas.faust@dish.com.
Tommy Faust
DISH Social Media Representative
Feb 12, 2012 | DISH Network 311 DTV Receiver
I got dish net work installed yesterday and it worked fine but when i turned the tv on the next day it was nothing but static and i cant figure out how to fix it so whats wrong and how can i fix it?
Guest,
The static you are getting on your TV is because the TV is not on the correct channel or input setting. With the 311 receiver, there is either a coax or an RCA cable (yellow, white, red) going from the receiver to the TV. If you have a coax cable, the TV should be on channel 3 or 4 (usually channel 3). With the RCA cable, the TV should be on an input setting. You'll need to go through your input settings until you find the picture. Of course your DISH receiver needs to be powered on. I hope this helps.
Ray Calo
DISH Network
May 20, 2010 | DISH Network 311 2-Room System DTV...
Indoor antenna problem with Magnavox LCD TV Model 15MF605T/17
I have found most of these indoor antennae to be ineffective and a waste of money, however, I do not know anything about this particular antennae. I to have a Dish DTVpal, which I love! It's ugly and probably won't fit in your kitchen, but the best solution is to make your own "bow-tie" antennae, mount it indoors or on the roof and run a cable to the kitchen. Directions can be found on You-Tube. I live in SE Idaho (Pocatello) and can get 13 channels, most without having to adjust the antennae.
May 27, 2009 | Philips Televison & Video
Dish net 311 no power
Dish Network (Echo Star Communications) is a problem company. The best solution to your problem is to switch to cable or Direct-TV.
Dish Network should be avoided at all costs.
May 06, 2009 | DISH Network 311 DTV Receiver
TV ''Dish'' not working on second TV
check sat in cable, if cracks or breaks in line can cause sfss. also on back of receiver you want to make sure that sat in cable has a little copper wire sticking straight up and that its getting a good connection on the back of the receiver.
Apr 23, 2009 | RCA DISH Network(r) 311 Satellite System
Sat signal reaches only 1 cable outlet
you need to split the line at the receiver box. The signal from the Dish needs 18vdc to the receiver or you'll get NADA.. If I understand you correctly???
Mar 07, 2009 | RCA DISH Network(r) 311 Satellite System
Dish Network 311 Help!!!!!!!!!!!
the only way to unlock it without the code is to contact dish network
Jul 22, 2008 | RCA DISH Network(r) 311 Satellite System
Dish 500 and receiver 311
100% yes. that's what it is supposed to be connected to.
Jan 27, 2008 | RCA DISH Network(r) 311 Satellite System
Dish network 119
you cannot satellite sginal from a splitter you will need dp 34 switch or quad LNBF DP HOPE THIS HELPS.
Jan 12, 2008 | RCA DISH Network(r) 311 Satellite System
RCA L32W11 32 in. HD-Ready LCD Television Logo
679 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
