Question about Pentax *ist DL Digital Camera
No autofocus Bought second hand, everything works but autofocus with AF lenses
    Brigadier General:
  • 11,967 Answers
Clean the contacts on the camera body and the lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Posted on Nov 14, 2009
Hi I cannot get my F80 to autofocus. I have tried all my lenses on my Brothers F80 and they all work fine on his camera. I only bought the camera second hand a few days ago and i'm 99% sure when the...
If the gears are stripped, it will require an experienced tech to repair.
That being said, there should be a small switch near the lens mount to switch between auto and manual focus mode's, be sure that that switch is pointing to A. When set to M, the little screw recesses into the mount so it doesn't try to engage, when set to A, it'll extend very slightly.
Also, Nikon has manufactured two types of AF lenses - with the motor in the body and with the motor in the lens, as with most newer lenses. Your camera should have a small screw on the lens mount that drives the focus motor between the lens and the camera, but I'm not 100% certain on that. Your camera can focus lenses with and without this type of coupling. BUT, if that screw/motor in the body is not functioning, you'll only be able to use lenses which contain the focus motor inside them, or manual focus lenses (you can manually focus AF lenses too).
May 19, 2011 | Nikon F80 35mm SLR Camera
I just purchased my d60 camera, unfortunately I bought it on craigslist, it came with a nikkor 50mm lense, I wanted a auto focus lense to take some sports pictures, I took it to shutterbug camera shop and...
That's odd that Shutterbug camera shop couldn't tell you everything you needed to know about that camera. I looked it up in a PDF manual because the new "small frame" cameras require different lenses as is the case here Autofocus with this camera is only supported by AF-S and AF-I lenses the lens is equipped with the autofocus motor other types of lenses will not autofocus.
The "kit" lens for this camera is the AF-S DX Zoom Nikkor 18-55 F3.5/5.6G VR.
Now if Shutterbug camera shop mounted an AF-S lens and the camera didn't autofocus then they are right in saying it's broke. I just find it strange they couldn't tell you that straight up. You need to install an AF-S lens and try it, again they may have put the wrong type on it and of course it won't work.
I take it that you don't have the camera manual?
If not go into Google search Type in Nikon D60 PDF manual and click search fifth one down on the first page is what you need click on it and download your "new" manual
Here is the link I used
http://www.google.com/#hl=en&sugexp=ldymls&xhr=t&q=Nikon+D60+Digital+PDF+manual&cp=28&pf=p&sclient=psy&aq=f&aqi=&aql=&oq=Nikon+D60+Digital+PDF+manual&pbx=1&fp=64f84e119f52b91a
See if that helps, personally I think you just need the correct lens.
Feb 14, 2011 | Nikon D60 Digital Camera
Bought a Sigma DG 70-300mm 1:4-5.6 autofocus for my Nikon D40. When the lens is attached the settings get locked on MF. Is there anything I need to adjust to fix this problem? Charles
The Sigma 70-300mm f/4-5.6 DG will not autofocus with the D40 since the lens does not feature an internal focusing motor (HSM). The D40 does not have an AF motor in the body and hence it can autofocus only with lenses featuring an integrated motor (eg. Nikon AF-S lenses, Sigma HSM lenses, Tokina DX II series etc). Unfortunately you can use the said lens only in MF mode.
Sep 02, 2010 | Sigma 70-300mm f/4-5.6 DG Lens
I'm looking to buy a digatil camera a D3000 and
See my answer to your other post.
One more addition for the D3000. Older autofocus lenses without a built-in motor will not autofocus on the D3000. Only AF-S and AF-I lenses will autofocus on the D3000.
May 07, 2010 | Nikon Cameras
Will it work with digital Nikon camera?
Yes, with caveats. First, bear in mind that this lens has been discontinued by the manufacturer. Second, the lens does not have a built-in focus motor and thus will not autofocus on the D40/D40x/D60/D5000/D3000 models. You also won't get 3D Matrix metering on those models. Everything else will work, and all features should work on other models.
Jan 12, 2010 | Sigma 28-200mm f/3.5-5.6 DL Aspherical...
I have a Nikon D60 and my autofocus has stopped working. It is not because of the lense because i have tried other lenses and the auto focus won't work with them either so it must be an issue with the...
You should check custom menu setting 2, and make sure it's set to one of the auto modes. Make sure the lenses you are using are AF-S and not regular AF lenses. The D60 has no autofocus motor, so autofocus only works with AF-S lenses.
I always suggest folks take a look at Ken Rockwell's website also, here's a link to a specific page on autofocus on the D60.
Post a comment here if none of this works and I'll see what else we can do.
http://www.kenrockwell.com/nikon/d60/af-settings.htm
Jan 08, 2010 | Nikon D60 Digital Camera
Is Sigma offering to rechip lenses for free to ensure compatibility on newer cameras?
In the uk if you have a receipt from new it will cost £5 But no receipt or second hand it will cost £33.99
Jun 23, 2009 | Sigma 28-200mm f/3.5-5.6 DL Aspherical...
Minolta SLR Lens on Sony - Does it work.
As I understand it, Sony bought Minolta, lock, stock, and barrel. Theoretically the lenses should fit and may work on manual, but I'm very sure they will not totally work on sony digital cameras. I wouldn't even try to fit them as the autofocus system on the camera may be damaged.
Mar 22, 2009 | Tokina AF 100-300mm f/4.0 II APO Telephoto...
Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Apr 19, 2008 | Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP...
Sigma 70-300mm DL Macro Super Lens compatibility for Nikon D40X DSLR Camera
Here is Nikon's specs of lens compatibility for the D40X:
Compatible Lenses*: Nikon F mount with AF coupling and AF contacts Type G or D AF Nikkor:
1) AF-S, AF-I: All functions supported;
2) Other Type G or D AF Nikkor: All functions supported except autofocus
3) PC Micro-Nikkor 85mm f/2.8D: Can only be used in mode M; all other functions supported except autofocus
4) Other AF Nikkor*â¹/AI-P Nikkor: All functions supported except autofocus and 3D Color Matrix Metering II
5) Non-CPU: Can be used in mode M, but exposure meter does not function; electronic range finder can be used if maximum aperture is f/5.6 or faster
6) IX Nikkor lenses cannot be used
*â¹ Excluding lenses for F3AF
They do not recommend 3rd party lenses, ever
Feb 01, 2008 | Cameras
Pentax *ist DL Digital Camera Logo
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
