SOURCE: washing machine error code on Frigidaire ATF6000E
thank you larkinator.. that totally fixed the problem as far as i can see right now, I am letting it "wash" a load of nothing. it was a bunch of BS how they hid the filter... I had to literally take apart my whole machine. :-) but its fixed, THANKS!!!!!
SOURCE: Frigidaire washing machine model LTF2940E
Check your outlet filters, clean out. The machine will not spin if the filter is blocked. Also check your inlet into the machine. Clean screens on both ends of the pipes. Refit carefully.
SOURCE: Pause Error - Frigidaire Affinity LTF6000ES0
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
SOURCE: How do I reset my Frigidaire Affinity Front Load
hold the start and pause cancel buttons down simultaneously should clear the error.
Testimonial: "That was right on the money. Thank you very much."
SOURCE: What does error code E59 means on a Frigidaire
Hiya
if you have pressed any of the buttons during a wash cycle then you will be given an error message on the display to change the wash options once started you must 1st pause the wash before making any changes, this i think would be the main reason for such an error to appear however you can download your operaters manual at http://www.frigidaire.com/manuals
if you do not already have it & from there you may be able to have a read & work out why you received this message alternativly from the site you will get a link to a contact us section where you may be abal to ring the customer services & then have the assistant check the code for you..
Hope this helps
Hello rdketo - Typically error code E70 indicates that the water temperatures are wrong. Often this is caused due to the hoses are wrongly connected to the valves. Check the hoses and make sure they are located on the correct faucet and valve. Confirm that there aren't any restrictions or kinks in the drain hose as well. If issue persists, it will be advisable to contact an experienced appliance repair tech to assist further.
