Question about Behringer Eurolive B212A Speaker
After purchasing a pair of behringer b212a speakers, the clip light (red warning light) began flashing at just half way volume and bass. is there anything i can do to improve this problem such as higher quality cables, better plugs,...etc?
    President:
  • 1,851 Answers
The clip led flashes when a peak value reached the amplifier and it is no way combined with cables or jacks quality (by the condition that all the connection are not in loosing state). So there is no need to change cables or jacks if their contacts are OK. Maybe the signal you are hearing from one speaker has more peaks so the peak led flashes. Here are some tests you can try:
Change the channels. Use the monitor A in the place you were using monitor B and vice versa. Did the peak led flashes at the same monitor?
Change the signal input, if it's possible use a mono recording or enable the mono switch at the mixer, so that make sure that both of the monitors are driven by the same signal.
Reply with the results at this post.
Thanks and regards
Please kindly rate this solution
Stelios
Posted on Feb 27, 2010
Diaphragm replacement parts
Hi
Here's the list of authorized Behringer dealers which should be able to help you out.
-Steve
Find Service Center
Nov 14, 2013 | Behringer Eurolive B212A Speaker
Behringer monitor lost bass
You should check the woofer's impedance as a starting point, let me know further.
Sep 22, 2013 | Behringer Eurolive B212A Speaker
When connect power, Clip signal On and do not Sound Why this is?
Oversimplified, "clipping" is distortion. Clipping can damage speakers. You can reduce or eliminate clipping by reducing the amplifier's OUTPUT volume; or be reducing in the amplifier's INPUT signal. Excessive amounts of either can result in clipping.
Check out this video for a more in depth discussion about clipping. I hope this was helpful!
Aug 08, 2013 | Behringer Eurolive B212A Speaker
Clip light is on even when no input and when bass is plugged in input low volume and distortion at speaker output
One half of the power amp has failed. You can damage the speaker... do NOT use this until repaired.
Apr 14, 2011 | Behringer Bx4500h Ultrabass 450w Bass...
Tar like adhesive has gone sticky round speaker cones and volume has droped
The tar like sticky substance is the suspension of the speaker cone and there is nothing wrong with that. Its doping compound applied by the speaker company to damp the speaker ( Was it not always there? ) If the suspension has come off the bass notes will flutter, if not its some other problem. Play some music and put your ears near the tweeters flared horn to see if they working. Nearly 30% of your sound comes from the upper part and if you have damaged it there will be a volume drop.
These speakers are quite complicated on the inside. It has two amplifiers, one for the woofer and one for the tweeter. It also has a digital sound processor. Any thing could be at fault, even a simple wrong setting.
Mar 09, 2011 | Behringer Eurolive B212A Speaker
Behringer B215A replaced volume level knob does not respond.
You DON'T replace the board. If it is cracked, you bridge insulated wires around the cracks and epoxy them down.
Often the pads break from the traces near the pots. Look for a small crack between the pad of the pot and the circuit trace leaving it. Common problem.
Feb 09, 2010 | Behringer Eurolive B212A Speaker
I recently bought a pair of b212A behringer speakers. when i turn the volume or/and bass past the half way point the clip (red light) begins flashing. Is this a problem and what does this mean
Clipping occurs when an amplifier is pushed to create a signal with more power than its power supply can produce. The red light flashing is warning you that your are overdriving the amplifier located in your speaker cabinets. This can cause damage to your amplifier and or your speakers. You should not allow the volume level to exceed clipping.
For more information on clipping CLICK HERE
Take Care!
Nov 14, 2009 | Behringer Eurolive B212A Speaker
Clip light
It sounds like one side of the power amp has shorted. May be hazardous to the speaker so best take it to a shop for repair. If speaker stills sounds OK, probably the clip detector transistors have failed.
Nov 08, 2009 | Behringer Eurolive B212A Speaker
Output volumn low on behringer B212a
Hi...
Swap the input signals...Does the problem move to the other speaker?
If not , it will need a tech to troubleshoot it.
Mar 31, 2009 | Behringer Eurolive B212A Speaker
Behringer Eurolive B212A Speaker Logo
498 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
