Question about Honda Maxus Pressure Washer MX5222
The pull start broke off when I was starting the pressure washer. I bought a new coil w/handle but I can't figure how or where to attach it. We took off the face guard and I'm staring at this big circular silver thing which I'm assuming starts the engine. How do I get that off and what do I attach the sting to. Thanks!
  • jim gleason May 11, 2010
    can you tell me what engine is on it?Briggs? Honda?
  • 1383 Answers
SOURCE: pressure washer stalls
Pressure washers work under very dirty conditions, no wonder they encounter engine problems. Here are a few pointers from a former pressure pump tech. The unloader is a source of engine overloading however this can easily be checked with a pressure guage attached to the gun with a tee fitting having the guage and the normal tip used for the unit. The pressure should never rise over rated pressure. The pressure should drop considrably when trigger is released. The life of the pump and engine can be increased by setting max pressure to 75% of rating. Most engine problems are from following conditions:
Leaking or misadjusted valves; clogged muffer /spark arrester; weak spark coil that is about to fail completely; kill switch/oil sensor wiring and or sensor mal function; gas cap not venting properly causing vacuum in tank and wet or dirty air filter.
All these problems easy to check, fastest repair is to disconnect oil sensor wire to check oil safety system. Then temp replace coil with known good coil. Loosen muffer bolts to check for clogged muffler. Temp run engine without gas cap to check for vacuum. Finally if everything fails, run the engine with carb cleaner spraying directly into the intake. If the engine continues to run with carb cleaner then the problem is fuel delivey and faulty carb. enjoy
Posted on Dec 01, 2008
  • 10865 Answers
SOURCE: honda powered gx160 model pressure washer wont start
Buy a new plug, drain out all of the old gas and put in new gas, and take a look at the air cleaner. If the air cleaner is dirty replace it. There you now have a good spark, good fuel and good air. The engine should start. If it doesn't get some carberator cleaner spray and some starting fluid spray.
Posted on Apr 12, 2009
motorhead427
  • 24 Answers
SOURCE: Pull cord is loose on my Honda 2500 Pressure
complete pull rope units are available for appx $23
Posted on May 30, 2009
  • 151 Answers
SOURCE: Pressure washer with Honda GX160 5.5 HP OHV-Starts easily but...
what about the linkage between the governer and the carb. Is that working and not binding?
Posted on Dec 24, 2009
jmgldsmth
  • 1869 Answers
SOURCE: Honda engine pressure washer won't start
Remove the sparkplug spray isoproxyl (rubbing) alchohol in the cylinder and on the sparkplug this will "dry out the engine" reassemble and, start the engine.
It should start as a "wet with gasoline" sparkplug can not spark nor, will liquid gasoline ignite
Posted on May 23, 2010
Pull starting rope Broke
Most recoil assemblies are easy to fix...but not in an obvious way. Remove the recoil asembly from the small engine housing/flywheel cover. Usually three bolts hold it on. 10mm on Honda's. Pull the remaining rope thru the exit hole if possible. Otherwise, fish remaining rope thru the hole by turning rope winding pulley as if pulling handle was still attached, lining up any remaining rope end and pushing thru the exit hole in outer recoil housing or backing it out the inside pulley. Continue to wind rope winding pulley in a counterclockwise ( facing pulley...not outer metal) untill it will not tighten any further. Remove any more old rope. Line up pulley hole and exit hole. Melt end of new rope into a tapered shape..if not supplied that way. the pulley can be held in place by inserting a screwdriver thru the both the pulley and the metal housing spokes. Thread the new rope thru the exit and pulley hole. Tie the rope end sticking thru and draw tight. Cut 6 feet of rope...if not using a presized pull. Release screwdriver from spokes and rope should draw up onto the pulley. Tie off opposite end of the rope to keep from losing that end into the exit hole. put the handle on the rope and tie a knot in the end to retain the handle. Untie the tie-off and allow the handle to fully retract. If handle does not fully retract you may shorten the rope so that it does...as long as you have plenty of pull lenght
Oct 21, 2012 | Mi T M Mi-T-M WP-2403-3MHB NA 2400 PSI 5.5...
Pull rope broke. attached back but cant figure out how to make the rope recall work
The recoil spring has to be pre-loaded about 5 turns, even when the rope is fully returned. When you pull out the rope, you increase this tension, but if you are starting from zero, there won't be enough spring tension to fully recoil the rope. Wind the rope on the spool, then rotate the spool about 5 turns in the direction that would "push" the rope out through the hole. Now put the rope through the hole and put the handle on it. If you got the tension right, it should be sufficient to easily hold the handle up against the hole.
Nov 18, 2010 | Honda Garden
I have honda gcv160 5.5 pressure washer, after sitting over winter, I went to use it, and I can't even pull the cord to try and start it. What are any reccomendations as to what I can do to fix this?
My power washer started doing that after the pull-cord mechanism broke.
I took off the hoses to make sure there was no back-pressure caused by the pump.
And pull rope was still frozen.
We took off the pull rope cover on top of the machine.
The cover came off easy.
After that we lifted out the spring-pulley where the rope is attached the spring unwound and we couldn't get it back together so I bought another one.
We should not have lifted it out ... we should have tried to get it to move first without lifting it up.
In any case the washer worked fine after the replacement.
When you store a power washer, be sure to drain the water and disconnect the hoses.
Don't leave any gasoline in the engine or it will gum up the carburetor.
Never turn a gasoline engine on its side or upside down or the oil will run into carburetor, and carburetor will need work.
Nov 09, 2010 | Garden
With pump removed engines runs fine. When new pump is installed it is very hard to pull with water flowing but will not start. Engine was just tuned up late year.
Chances are that your new pump is generating good pressure. Because of this, the engine is trying to turn over against the pressurized system. Try pulling the handle on your wand when pull starting the engine to see if this eliminates your problem.
Jul 01, 2010 | Briggs & Stratton Prosumer 20324 Gas...
Water fill problem on Hotpoint Dish Washer Deluxe Model DF 31
Pl check the small filter fitted near the water inlet hose. Probably you may have to pull this filter as this is housed in the threaded pipe attached to the body.
Remove the hose from the machine and try flushing. see whether you get sufficinet pressure from over-head tank!
Clean the filter with tooth brush or reverse clean. Do no for get to fit rubber washer.
Mar 30, 2010 | Hotpoint 24 in. DF55 Free-standing...
I have a Briggs and Stratton power washer Quantumpower 5hp water driver series 1750 PSI 2.0 gal min model # WGV1721 . I got it used and it was always a bit hard to start but always started. Pull cord...
Spray well with WD-40 or similar, and take a small chisel, on it's edge, and hit hard enough to allow chisel to dig in to head of screw, making a "V" like slot in the head, then angle chisel slightly and start tapping in direction of loosening(counter clockwise.) Once it loosens enough to get a pair of visegrips attached to head, use them, and spin them out. Make sure you replace them with new screws.
Jan 08, 2010 | Briggs & Stratton Pressure Washer...
Pump with upgraded pump only getting half power
if you bought a new pump make sure its the correct type
then check for a unloader the adjustment part like a handle or an Allen screw on the head of the pump
dismantle grease up and replace
Aug 02, 2009 | Honda Pressure Washer PSI 3000
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
Pull cord broke
if you have not replaced cord you will need to do this,when you fit the cord turn the pulley 4 or 5 times full circle the same way as if it was pulling cord,then feed cord through pulley and out of housing to fit handle when this is done you can let pulley recoil and you should have correct tension,hope this helps
Mar 10, 2009 | Honda Pressure Washer PSI 3000
Pressure washer stalls
Nov 15, 2008 | Honda Pressure Washer PSI 3000
Honda Maxus Pressure Washer MX5222 Logo
166 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
