Question about Amana ABB1927DE Bottom Freezer Refrigerator
FREEZER AT BOTTOM OF REF. COLLECTS ABOUT ONE INCH OF ICE. THAN CANT OPEN BOTTOM DOOR SEEMS TO BE LEAKING DROPLETS OF WATER FROM REF. AT TOP WHAT COULD BE WRONG?
  • Amana Master
  • 4,655 Answers
Defrost condensate line behind the rear panel is clogged up. The watter is flooding over the condensate collection tray and and through the cabinet. Click below.
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
Watch the short movie on how to get to the tray behind rear panel in freezer and if you have trouble or questions let e know, Thanks, Sea Breeze
Posted on Nov 14, 2009
Model LFX28968ST. Why is water dripping onto lower freezer drawer?
Richard, sounds like the drain plug/ hole is plugged.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LG Freezer repair French Door bottom Freezer model
Appliance Repair Forums
LG 819 739 refrigerator not cooling or water leakage how to fix repair by...
How to Unclog Refrigerator Drain Line
Mar 12, 2016 | LG Refrigerators
Water leak under freezer door
the drain should be at the very bottom of the freezer. but it sounds like ur door gasket aint sealing all the way so ur freezer is trying to over compensate for the warmer air coming in
Jan 04, 2014 | Samsung RS267TDWP 26 cu. ft. side by side...
Bottom mount Freezer Iced up
if you have frozen water droplets on everything most likely the door was left open and when the warm air mixes with the cold air in the freezer this happens,look at the top of the door or the sides of the freezer door,also up on the ceiling where the light switch is,if there's ice there the door was left open,common problem with freezers on the bottom,you can shut down the machine,and with a hair dryer blow the hot air into the vent holes in the back inside wall of the freezer and if ice is on ceiling melt that out too.good luck.
Jul 09, 2012 | Kenmore Refrigerators
Top drawer of freezer seems to work but large bottom drawer not freezing even at -5degrees. Can this be fixed?
This problem seems to be two sided. A refrigerator defrost it is supposed to take the water from defrost down a pipe located behind the freezer rear wall to a pan below the refrigerator where there is a fan blowing warm air over the water to evaporate back into your home or business. If that drain is blocked your refrigerator will accumulate a large block of ice and frost behind the rear panel of freezer and temperatures will warm considerably in fresh food compartment and freezer. Here is one site I want you to read over=> Leaking Refrigerators Just What may Be Happening and here=> Leaking Refrigerators here is a link to a service manual=> LFX25960xx Service Manual Let me know if this service manual is close enough to your model number. At this point I am looking for air blockage behind the rear panel of freezer. If air is being blocked by ice and frost you can use a hair drier to help speed you up while melting ice. If drain is blocked use whatever you can to open the drain line mentions on the links I sent you to and let me know what is found, Thanks Sea Breeze
Feb 18, 2012 | LG LFX25971ST Bottom Freezer French Door...
Bottom of the freezer keeps filling up with water and freezing solid. eventually leaks thru the door onto the floor. It takes 3 to 4 weeks for it to form thick enough to eventually leak thru the door on to...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | GE GSS25JF Side by Side Refrigerator
Water in the bottom of the fridge this unit is 15 years old
the seals or door gaskets leaking will cause fuzzy ice to grow in freezer and water to collect in frige and run alot
Dec 27, 2009 | Westinghouse WWS833ES Super Capacity Top...
CONDENSATE LOOP
Hi, A condensate loop in a refrigerator is any device that produce heat in certain areas, most commom is around refrigerator door, which are mullion heaters that produce mild heat, to prevent ice build up around doors, prevent door gasket from getting stuck, another type of condensate loop are found under or back of most refrigerator, hot gas line from compressor, sometimes are loop under ref. or other location of ref. before it is connect to ref. condenser, most ref. condensate loop are used to evaporate water collected from evaporator. to prevent clouding of glass on doors, etc, and it could be electrical, or mechanical, base on applications.
Aug 06, 2009 | Federal Industries CGR5042DZ Commercial...
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
Water collecting in refrigerator and ice collecting in freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you access to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somewhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wire around the heater( black heater right above the drain trough) and stick it in the whole maybe an inch or so. now every time the heater comes on to defrost it will prevent the hole from freezing over
Mar 15, 2008 | Refrigerators
Amana ABB1927DE Bottom Freezer Refrigerator Logo
217 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
