Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Replaced color wheel on my samsung hlp5063w dlp- colors are reversed- how do I repair
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Some of these sets have a jumper plug that has to be removed when you install the newer type of color wheel.
The jumper if it has it usually causes the color to look funny blue instead of normal.
It is located on the DMD board--the metal box on the light engine where the two plugs from the color wheel are.
It will be in a small opening on the metal shield that covers it--small and rectangular in shape--it has a small metal tab across it--it jumps two pins--
if it is there with a hemostat or small needle nose pliers pull it carefully out and see what you have--The CCA adjustments are done in the TECH MENU--look to see first if the jumper is there and remove it.
A lot of places that sell the wheel do not tell people about this.
If this has helped you rate this solution, as I do this here for FREE.
sd tech
Posted on Nov 14, 2009
Colored spots on Samsung HLP5063W
The color wheel or the DLP chip itself will cause this. Parts can be had here: www.shopjimmy.com
Jun 27, 2017 | Samsung HL-P5063W 50" Rear Projection HDTV
I have A Samsung Dlp HLP5063W that starts making a
Steady buzz, squeal, rumble is probably the color wheel bad.
Apr 12, 2010 | Samsung Televison & Video
Loud hum on SAMAUNG dlp MODEL hlp5063w ABOUT7
The most common problem in this set is the Color Wheel----usually if it is going bad you will have a fan like or even grinding sound coming from the back of the set---eventually the wheel will shatter and then the set will shut down--it will detect the wheel is not moving correctly.
If this is your problem: I Googled : hlp5063 color wheel and found several sites with photos and step by step instructions with photos of how almost anyone could do this repair---The part number for this model should be BP96-00674 AND several sites including sellers on Ebay sell the part.
I have seen a lot of these sets with this type of problem---shop around and Google what I did and decide if you can do it yourself---I have had several people here who bought the part and had me come out and install it---least expensive way as a shop is going to charge quite a lot for this repair--
If you need help let me know---there is even one site that has a video of how to do this repair----I can also tell you a few things you most likely will not learn there---simple mistakes to avoid if you do this--for me this replacement of the Color wheel takes about 30 minutes.
I am here to help people.
Regards, SD TECH
Oct 26, 2009 | Televison & Video
Screen went B&W and I hear a loud humming noise from the TV...
Hi John,
If you are hearing this noises,that's your Color Wheel.
The reason fot that is because your color wheel spins 5000rpms(revolution per minute) and something that modifies the balance if the disc can cause different things.Unfortunately in order to check if your color wheel is working properly you need to open your TV and physically check out.
Grinding= Most probably the color disc is broken and you need to replace it.
Spinning / Buzzing = The bearing of the wheel is loose and is loosing its balance,eventually it will brake.
The best thing to do is to take the color wheel out and spin it ,if you feel that the disc kind of wobbles or doesn't spin smoothly you have to replace it.
You can check DM they have very good prices
http://www.discount-merchant.com/SearchResults.asp?Search=samsung%20color%20whee l?click=52978
I hope this will help,please keep us posted
Oct 05, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Adjusting color after color wheel replacement samsung dlp tv
There should be a jumper somewhere around the color wheel. I am having a problem with my color wheel, and after doing a lot of research I found that people that have the same problem as you changed the jumper setting. Try looking it up here on the net. Should solve your problem.
Mar 21, 2009 | Samsung HL-R4667W Rear Projection...
Hlp5063w 50'' DLP samsung Experiancing The Word LAMP green letters flashing for 20 second followed by clicking noise then shut off.. then repeats that same process twice then TIMER / STANDBY/TEMP/LAMP...
Sounds like you've already gotten into the repairs. The three major things that fail on DLP are the bulb, the ballast and the color wheel. If your bulb is new and you aren't getting anywhere, replace the ballast, if that is still a no go, then move on to the color wheel. If replacing those three doesn't fix the problem, you will have to whip out the multimeter and start looking for problems on the PSB. You can get a ballast on ebay for about $100. Start there. The color wheel should be very freely moving. If something is grinding and hindering the movement at all, you need to replace it. That grinding may not seem like much but it is likely enough to keep the wheel from spinning at proper speeds. The sensor then kicks in and tells the brain that there is a problem and the brain keeps the ballast from firing the lamp.
Good luck.
Feb 18, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung Color Wheel
Here's a good article on the Color Wheel
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
It says if your red and blue colors are reversed removing the jumper should fix the issue.
Aug 27, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Color is bad after installing color wheel in samsung dlp tv
Most times color does not to be reset. If you have a very ugly green or blue picture, then you did not pull the jumper on the dm board. This jumper must be removed when a bering type color wheel has be replaced with a new airless bering color wheel.
Mar 31, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HL-R6167W DLP color problem/buzzing noise
My 3 yr old Samsung DLP has the same buzzing noise, had a tech out today and he said "color wheel". Thank goodness I purchased that expensive warranty, This is my 4th repair in 3 years.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Very noisy when turned on, then shuts down, Samsung 61 inch
Color wheel defective. Replace it with the new designed color wheel. The lamp is ok.
Dec 10, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
434 people viewed this question
Jerry Greenberg
Jerry Greenberg
