Question about Epson ACULASER CX11NF All-In-One Printer
Shadow/duplicate printing We have this multi-function machine in our office. When printing from a computer we occasionally get shadows on the page. It duplicates the same text or image 4 times on one page, but they are lighter than the original. Also we get a lot of excess toner on the back of each page. I tried cleaning the head, which didn't help. I also ran 3 prints with one character each to try and clean the toner issue, per the Epson user guide. Those prints were clean on the back, but had the duplication issue and anything we print with more than that singular character has the excess toner. We have already had the photoconductor replaced and it did absolutely nothing to solve the issue. I suspect it may be the 'compatible cartridges' that we are using.
  • R Jan 16, 2008
    I discovered that the issue is with the toner. The cartridge is bad.
  • R Feb 25, 2008
    Thanks for your reply.
    Unfortunately the machine itself seems to be a lemon. After HOURS of phone calls, service calls, and being jerked around, we were able to get Epson to refund us for the machine and wasted toner.
  • 152 Answers
In computer goto printer setting mode and uncheck option
toner saving mode and check out for dark or light effect
Posted on Feb 25, 2008
Samsung clp 315 printing shadow images
Ghosting appears often because of bad toner. If cartridges have been refilled, they have wrong toner in them. If drum has worn out it will usually tell you. All parts for this machine cost too much. If toner is not the problem, probably best to get a new machine rather than pay to get it fixed. Brothers are cheaper to run.
Sep 01, 2014 | Samsung CLP 315 Laser Printer
Shadow problem
Hello, you need to test your machine with a new image unit. If your shadow is gone you have solved your problem. If not you need to take your machine to service.
Nov 02, 2013 | Sharp AL Office Equipment & Supplies
86 Honda Shadow VT1100 motorcycle idles rough
Hi, Daryl and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Choke valve not seated or leaking.
9. Multi carburetors out of sync and need to be balanced.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
86 Shadow VT1100 Rough idle!topic/
Honda SHADOW VT1100 Owners Workshop Manual
Honda Shadow VT1100 Owner Manual
May 23, 2012 | 1994 Honda VT 1100 C Shadow
The black print jobs have a shadow about 3 inches down the page
I had replaced the fuser - no improvement. I removed the fuser, imaging unit & transfer roller. CAREFULLY using a vacuum cleaner I cleaned all units and the internals of the printer, rotating the roller on the imaging unit to clean all parts. (Warning Place Imaging unit on paper as toner escapes) After a few test prints the page cleared and duplicate ghosting cleared.
Apr 07, 2010 | Xerox Phaser 6360 Laser Printer
My Ricoh Aicio 1013F is showing a duplicate shadow on the copy.
This is almost always the hot roller and/or the pressure roller bushings in the fusing unit. The Hot roller in this model is rated for 90,000 copies, but they commonly fail earlier than that. The pressure roller bushings also wear as they are made of plastic. If you can drag your finger across one of your copies, and the toner doesn't stick to the paper, then you definitely need bushings.
Check how many copies you have by press the "user tools/counter" button in the upper left of the control panel. You should see the word "counter" on the display. Press the "OK" button near the display; this will show you your copy count. If you are near the 75 to 80,000 mark (or multiples there of [150- to 160,000, etc.]), I'd say it's time to replace the hot roller.
Unless you are certified to work on these machines, you would need to get a service technician to do this. These particular machines are more difficult than some of the larger models, and I definitely would not suggest anybody try this repair unless they know exactly what they are doing.
Dec 15, 2009 | Ricoh Aficio 1013F Copier
My hp officejet v40xi printer is printing my black and white documents with a shadow behind its lettering. I've ran the align process several times. The funny thing is that when it prints the instructions...
check your printer settings on the device you are using and make sure you have shaddow off or 3d off. the extras only work from the device you use, printer page from printer is basic settings.
Jul 07, 2017 | HP OfficeJet V40 All-In-One InkJet Printer
Riso GR 3770 master make shadow on it how to fix it?
check the dust or any scar in scanner (glass).
Feb 17, 2009 | Riso RZ220 Duplicator
Image blurs as the page prints
It might be your printer catridge problem. Try changing it and giving it a nozzle clean.
Feb 06, 2009 | Lexmark X3350 All-In-One InkJet Printer
Printouts with shadow
Two things - Fuser or cartridge - stop print halfway in machine, if fault occurs before paper has gone threw the fuser then it is a faulty cartridge, if print is ok before fuser (the hot bit at rear) but gets doubled up after fuser then the hear roller in fuser are faulty change fuser....but 95 % of the time it is due to dodgy refill cartridge or worn cartridge (the rubber blade inside cartridge fails to apply enough pressure against drum to clean away old image  hence duplicating itself onto your nice clean paper! Try a known good cartridge if in doubt..
Oct 16, 2007 | HP LaserJet 1300 Printer
Epson ACULASER CX11NF All-In-One Printer Logo
306 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
