Question about Emerson MS3108 Shelf System
My Emerson MS3108 door keeps randomly opening. All CD music stops when it opens and it opens within seconds of the previous openings. Is there something I can do?
    Problem Solver:
  • 6 Answers
It is a leaf switch that senses that the door is closed. A C-clamp in the upper left hand corner clamping the door closed will make it work. If you remove the clamp, it will randomly open again. The correct fix is to open up the unit and bend the leaf switch to make it activate earlier and fully close when the door is closed.
Posted on Apr 01, 2011
How do I change the frequency of a garage door opener 139.53930ODM?
Hi... You have to "erase all codes" (you can read that section of the manual and teach the opener to use the remote using a new code. You can get the manual at the Craftsman site, page 35. Essentially you do this: access the reset button n the back right of the motor, press and hold the 'learn' for 6 seconds or more,until the learn light goes off. TO reprogram it, press the learn button until the light goes on, then within 30 seconds, press and hold the desired button of the remote. Voila!
Dec 26, 2014 | Chamberlain Liftmaster 355LM 315MHz Garage...
How to change the pin on Zebra Electric Push Code Safe from Justice.
1. Door has to be opened using previous code or the default "0000".
2. With door open hold the * button down. Both green and red lights will flash.
3. Within 15 seconds, enter your new 4 digit passcode while holding the * button. Press # when finished to store new code. Both lights will stop flashing.
4. Release the * button.
Jul 28, 2014 | Home Security
Keyless control not work
here ya go follow the steps exactly and it will work and dont forget to rate me please,
* Remote programming
Start with drivers door open, unlocked, and no key in the ignition.
Insert and remove the key from the ignition switch twice within 5 seconds.
close and open the driver door twice within 40 seconds.
Then insert the key into the ignition key cylinder and remove it.
Close and open the driver door twice within 40 seconds.
Then insert the key into the ignition key cylinder and close the door.
Turn the ignition switch from LOCK to ON and back once and remove key
Locks should cycle once.
Within 40 seconds press the LOCK and UNLOCK switches on the transmitter switch simultaneously for 1.0 – 1.5 seconds.
Within 3 seconds after the previous operation, press either one of the switches for more than 1.0 seconds.
Within 3 seconds after the transmitter switch has been turned OFF, the LOCK–UNLOCK operation will be automatically performed once if the registration of the recognition code of the transmitter is completed correctly.
In case the LOCK–UNLOCK operation is performed twice, the registration of recognition code has failed.
Perform the registration procedure from the beginning once
Feb 03, 2009 | 2005 Toyota Camry Solara
200 cd changer door will not open
TRY TAKING IT APART AND LOOK FOR A RUBBER BAND ITS PROBIBLY JUST SLIPPED OFF THE WHEEL
Jan 04, 2009 | JVC XL-MC222BK CD Player
The rubbing Emerson CD player
hello, is this a carosel type loader? they have other internal parts that rotate it for selecting cd,s i understand what you mean.
the reason i say to open the case is incase there is something obstruction the mechanism from going in to the right return position
if you allready checked for this and theres nothing blocking the return cd holding part. then you may need to check this cage assembly for internal broken loose screws or jammed parts.
some plastic parts sometimes break or wear out and cuase the return cage to not load the cds properly. this is a loader issue
your on the right track, it is something with the returning cage
also at times the rubber shock resistant booties on the cd reader & motor assembly they are missaligned or come apart
if a cd dosent sit properly it pushes the drive motor and thats when the rubber mountings can come apart. reader assembly & motor mounts. check for this also.
good luck with your player.
happy holidays
Dec 19, 2008 | Emerson MS3108 Shelf System
Emerson 3 CD Player MS3108
Yes, your expert told me there was no fix and to return it to the manufacturer, which I did. I don't believe I would now try your premium assistance program after that first session which did nothing for me.
Aug 02, 2008 | Emerson (CKD2330) CD Player
Why does my key fob only open drivers door
this how a dealer does it:
DOOR CONTROL TRANSMITTER
REGISTRATION
1. REGISTRATION OF RECOGNITION CODE
HINT:
 The add mode is used to retain the already registered codes while registering a new recognition code.
This mode is used when adding a transmitter. If the number of the registered codes exceeds 4, the previously
registered code will be correspondingly erased in order, starting from the first registered code.
 The rewrite mode is used to erase all the previously registered codes and register only new recognition
codes. This mode is used when exchanging the transmitter or the door control receiver for new one.
 The prohibition mode is used to erase all the registered codes and cancel the wireless door lock function.
Use this mode when the transmitter is lost.
 The confirmation mode is to confirm how many recognition codes have already been registered before
an additional registration of a recognition code.
 All the following registration procedures must be performed in order continuously.
(a) The vehicle should be in the following conditions.
(1) The key is not inserted in the ignition key cylinder.
(2) Driver’s door is OPENED. (The other doors are CLOSED)
(3) Driver’s door is UNLOCKED.
(b) Perform the following operations to select the desired mode.
(1) Insert and remove the key from the ignition switch twice within 5 seconds.
(2) After the above operations, close and open the driver door twice within 40 seconds. Then insert the
(3) After the above operations, close and open the driver door twice within 40 seconds. Then insert the
(4) Turn the ignition switch from LOCK to ON and back to LOCK at approximately 1 second interval 1
to 5 times to select a mode.(2 times for rewrite mode) Then remove the key from the ignition key cylinder.
(5) After selecting a mode, the integration relay automatically performs the power door
LOCK-UNLOCK operation within 3 seconds to inform the selected mode.
(c) Register the new recognition codes :
(1) Within 40 seconds after the add mode or the rewrite mode has been selected, press the LOCK and
UNLOCK switches on the transmitter switch simultaneously for 1.0 - 1.5 seconds.
seconds.
(2) Within 3 seconds after the transmitter switch has been turned OFF, the LOCK-UNLOCK operation
completed correctly. In case the LOCK-UNLOCK operation is performed twice, the registration of
recognition code has failed. Perform the registration procedure from the beginning once again.
(3) If the multiple transmitter to be registered, repeat step (c) within 40 seconds after the previous registration.
this is why the dealer charges for this
Jun 19, 2008 | 2003 Mini Cooper
Cd tray door keeps opening!
How does a DVD camcorder have a CD tray ?
Aug 03, 2017 | Sony Handycam DCR-DVD105 DVD Camcorder
CD door
try cleaning the mode swith that opereates the dorrs it sounds like its dirty
Nov 15, 2006 | Emerson MS3100 3-Disc CD Changer
Emerson MS3108 Shelf System Logo
128 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
