Question about kawasaki Quad Bikes
Klf300 bogs down and dies when you give it throttle. I put in a carb kit and adjusted the valves. Cleaned up carb. It runs fine with the choke on. Why does it die like it's not getting enough gas when you give it throttle.
  • 3567 Answers
SOURCE: kx 85 04,bike had a slight bog when throttle was
Start with setting the air and throttle screws. Turn each one inward until it GENTLY seats. Back each one out one and one half turns. Clean the air filter and starter plunger. The plunger may need to be rebuilt or replaced. Check the pilot and main jet sizes. There will be a number stamped on the side of the jets. The pilot jet should be #45, the main jet should be #140.
Posted on Aug 01, 2009
  • 13 Answers
SOURCE: Engine dies when choke is taken off or when throttle is applied.
where the valves set cold or hot? could make the world of a difference...is there intake leaks? bad floats perhaps....its a problem that will take some time cancelling out problem by problem
Posted on Oct 09, 2009
SOURCE: 05 750 brute force missing badly
to be honest with you i have the same quad and its the same age, ive just had to spend a fortune on it because the engine seized solid for no reason, i had a honda 350 before this kawasaki and im going back to honda. im NEVER going to buy another kawasaki, its been nothing but trouble from day one!
Posted on Oct 27, 2009
wayneman01
  • 301 Answers
SOURCE: when giving gas it wants to die. will not run
This is what happens when a motorcycle sits for a long time without being operated (sometimes in as little as six months of storage). Over time, the gasoline in the carburetor evaporates and leaves behind a tar like varnish which pluggs up the very small openings in the carburetor passageways and jets.
The carburetor will have to be completely disassembled and cleaned. Soak all of the metal parts in a commercially available carburetor cleaner (be sure to follow the directions and all warnings that come with it). Do NOT place any plastic or rubber carburetor parts in the cleaning solution, they'll be ruined.
Upon reassembly, be sure to blow out all of the carburetor passages with compressed air. Same with the carb jets, blow air through them and then hold them up to a light and make sure you can see through them.
Tip: I have found that Simple Green is capable of removing fuel varnish from carb parts with an overnight soak.
Posted on Nov 01, 2009
  • 4 Answers
SOURCE: won't idle without choke, turn throttle boggs out
have u checked the float hight on the carburator? also make sure ur choke curcuit i clean and free of dirt
Posted on Apr 14, 2010
Yamaha pw 50
Sounds like the carburetor needs a qualified professional to clean and set it...(its worth the time and $$)
Sep 04, 2017 | Motorcycles
163FML (CG200) bogging at low rev
Hi, Marcus and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
Bogs when open the throttle fast
Motorcycle Message Board Motorcycle USA
boging and half throttle
boggs down when accelerate aggressivly to full throttle Pit Bike Club
Why is the engine bogging under acceleration Suzuki FA50 Moped
Bike dies when you give it throttle
Mar 17, 2017 | Motorcycles
Ryobi weed eater stalls when giving it gas
check air filter and spark plug if good carb adjustment is needed or carb may be loose. could be bad fuel water in gas will cause this
Aug 26, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
2001 Yamaha XL700 Waverunner bogs down after running for 30 min
did you replace all diaphrams in carbs and fuel pump ? balanced the carbs ?
Jun 07, 2012 | Yamaha Boating
2003 yz 250 starts and idles but runs rich and bogs as soon as the throttle is applied
Hi, Anonymous and the usual suspects are:
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Intake system air leak.
4. Vacuum piston malfunction.
5. Accelerator pump leaking or no output.
6. Plugged bowl vent or overflow.
7. Fuel level in bowl too low.
8. Restricted fuel supply passages.
9. Plugged jets or passages.
10. Worn or damaged needle or needle jet.
11. The enrichner valve not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2002 yz250 idles fine but bogs and tries to die when twisting the throttle...
YAMAHA YZ250 LC Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Mar 19, 2012 | 2003 Yamaha YZ 250
I Have a Ryobi Trimmer. I cleaned out the carb and put it back together but forgot the High and Low needle settings. I have got it to start but am having trouble tuning it. I have put a carb kit in it and...
adjust the needles both all the way in until they stops. unscrew both 1 1/2 turns and start engine. slowly accelerate and if it bogs down unscrew the HIGH SLOWLY until full speed is gain. some times you have to unscrew a little the low speed too. is a matter of playing with it. be patient you will get it. if you are still having problems you may have to take the bottom of carb. out and make sure the gas inlet needle is letting pass gas into the carb. chamber.
Feb 16, 2011 | Ryobi Garden
Engine bogs down when speed is increased.
Ok I have r Royobi Tiller (30CC Gas) And last year it ran fine after rebuilding the Carb. This year it was "hard starts" Idles fine, (Tiny whisps of blue smoke in exhaust with correct ratio) Even seems to run better with the choke "on" but still...at idle only. as soon as I touch the throttle...its bogs down in tune with how much gas I give it. Little throttle? Little bog down, Little more throttle? Almost stalls, a normal throttle rev? it stalls dead! Then starts right back up again in 1 pull and idles fine again!? WTF? So after cleaning a clean carb again, (twice) and seeing no change I thought I'd go look at the original diaphragm and compare it with the rebuild kit diaphragm (which is the one in the carb.) And guess what? The replacement has a larger rivet by a factor of "2". So basically it was flooding the carb, I bent the needle tang down, better but no cigar. But I could rev it half way now. A second disassemble to bend it yet a bit further and Vrooom vroom vrooom ****! So check your needle valve even though you think its 100%. (Especially if you rebuilt the carb with a kit!)
Mar 27, 2010 | Honda 25cc 4-cycle Mini Tiller
It acts like it is flooded, starts with choke off and throttle depressed. runs until carb runs out of gas then dies
Yes, Your carburetor sounds like it needs cleaned. Or you may possibly need to purchase a carb. kit for your trimmer if the cleaning doesn't do any good. When cleaning the carb. use a Den Tek Brush, (teeth cleaning brush), to clean the small ports. Also, check the small screen in carb. Can get clogged easily.
Jim
May 28, 2009 | Garden
kawasaki Quad Bikes Logo
151 people viewed this question
Top kawasaki Toys Experts
 binay biswas
binay biswas
Gregg Mahin
Gregg Mahin
Vernon Taylor
Are you a kawasaki Toy Expert? Answer questions, earn points and help others
