Question about Texas Instruments TI-83 Plus Calculator
Invalid dimension error on my TI-83 plus?
How do I fix it? What is wrong with it? I was told there is something wrong with the stat points being on or something but I'm not sure how to turn them off or how to tell if they are off. Help would be great!
  • 2 more comments
  • Anonymous May 28, 2008
    i AM TRYING TO GRAPH THE FUCTION Y=-5+3X-25X AND I KEEP GETTING INVALID DEMINSION
  • Anonymous Sep 28, 2008
    hallo wen ich den rechner anstelle ist ein strich genu durch die mitte gezogen was kan man dagegen tun
  • GabbyKuz Nov 02, 2008
    I'm trying to graph 2.25X + 9.95 and 2.95X and it keeps telling me INVALID DIM. Please help. I don't know what's wrong.
  • Anonymous Jan 17, 2009
    Hey,
    I had the same problem as you. My ti-84 plus said all the time Err: INVALID DIM.
    The sign next to Y1, Y2 etc was different. It was not the ussual' /' But an arrow.
    I have reset my Ti and now it works. Thx!
    Sniper:
  • 56 Answers
This is a pretty vague problem but not much of a problem. Your actualy plotting device of your stat plot is under your "y=". But before you do that you need to hit the stat button right next to the blue apps button. Then hit edit. These are your stat data. If you are trying to add data in you should notice what list they are under. (top of the screen L1, L2, ect.) You should also make sure that the number of data adds up for your two list. Now that you have done that you can go to "2nd" then hit "y=". If you don't want to graph your stat plots just make sure they all sat plot... off by hitting enter on the one that says that it is on. Now if you want one on hit enter and make sure your lists from your data match up with your stat plot. You can hit enter and see what one you need. they are above the 1, 2, 3, etc key. Hope this works. If all else fails you can clear your calculator by pressing "2nd", "+", "7", "1", "2". This will turn off all your stat plots if you have trouble understandsing this. b
Posted on Jan 10, 2008
Over heating problem...changed radiator as i was told blockage in raditor..the problem is still happening...mechaanis says there is no themostat head cakett
Find another mechanic. T stats are automatic on any coolant problem. I could have told you up front the head gaskets were bad. Get away from these point and fix people. The aren't even shade tree mechanics. Could be this, could be that.. I say, this is the problem.
Aug 08, 2015 | Cars & Trucks
How to fix an invalid dim error on an ti 83 calculator
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If this doesn't fix it, please reply to this post and tell us what you're trying to do when you get this error.
May 10, 2014 | Texas Instruments TI-83 Plus Calculator
How to fix INVALID DIM in plotting graph
The ERR:INVALID DIM error message may occur
if you are trying to graph a function that does
not involve the stat plot features. The error can
be corrected by turning off the stat plots. To
turn the stat plots off, press y ,and
• You specified a list dimension as something
other than an integer between 1 and 999.
• You specified a matrix dimension as something
other than an integer between 1 and 99.
• You attempted to invert a matrix that is not
square.
Apr 05, 2014 | Texas Instruments TI-84 Plus Calculator
Ti-83 error message invalid dim
Nov 21, 2013 | Texas Instruments TI-83 Plus Calculator
Heat and Air run at the same time in my rv
yes, replace your stat but also make sure your wire going to y on the stat has not shorted with the wire going to the w on your t-stat. To check to make sure remove the t-stat and short the wire going to r to the y wire and the wire going to the g terminal if it has that. if cooling works with no heat it's more than likely in the stat, if heat comes on then you may have other wiring, circuit board issues
Mar 01, 2013 | Heating & Cooling
My thermostat does not turn off the air handler after the outside compressor shut down. keeps blowing and blowing
There can be a 5 minute delay after the compressor shuts off. But if after say 15 minutes its still going something else is wrong. Verify t-stat is on auto instead of on. move it back and forth to be sure. Then remove t-stat and disconnect the red wire. If shuts off now the problem is in the t-stat (likely a shorted wire or something touching something wrong. rarely a bad t-stat but possible. If furnace still running while red wire is off the t-stat there is a problem at the furnace. open it up and disconnect the red wire from the R terminal. If still running the computer has a bad relay that is stuck on. have to replace computer. If it shuts off there is a short in the t-stat wire such as mice chewing marks a nail in the wire or wire rubbed on sharp metal surface. Find and repair it or replace the t-stat wire. Good luck
Feb 15, 2011 | Heating & Cooling
I HAVE A GOODMAN HEAT PUMP, MODEL AR30-1. I switched off the heat pump at the stat and the elements seem to be running heating up the unit... Also what is the brown wire coming from the wiring harness for...
The brown wire on a Goodman is tipically for the emergency heat option on your heat pump. First thing I would check is making sure it is wited correctly. Verify your stat is heat pump capable. Many of the cheaper stats only work for ac or just a heat pump. Anything beyond that would be a more serious electrical problem and should be looked at by someone with the proper training and tools.
Feb 11, 2011 | Goodman Heating & Cooling
I have a Cozy double-wall heater model number W505D and I am not able to turn it on. The pilot is on but the thermostat does not seem to to turn on. The thermostat is new so I doubt that it is...
make sure you have a millivolt stat and not a 24 volt stat should have a MV on the stat, you can pull the wires off of stat and twist together to get the unit to turn on if it does wrong stat.
Dec 11, 2010 | Cozy (W352E) Heater
How do you fix the texas instrument calculator that does not graph. It says invalid dimension.
Nov 23, 2010 | Texas Instruments TI-83 Plus Calculator
Everytime i try to graph something, it says error: invalid dimensions. I cant figure it out! can you tell me what to do?
Aug 30, 2010 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
3,334 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
