Question about Microsoft Windows Vista Home Basic Edition for PC
How do I remove good.exe virus
How do I find and remove good.exe virus. A pop up appears saying GooD properties and asks to retore
  • 51 Answers
You can remove the virus using Sophos antivirus. if u cant get sophos antivirus, u try to repair the vista using vista os cd to repair at startup. It will b ok
Posted on Nov 14, 2009
Files turned into a folder name shortcut
The file shortcut is a pointer to where the file is located. When you click on the shortcut the computer will go to where the file is located and then open that file.
Mar 12, 2013 | Computers & Internet
My all folder in flash d change to be shortcut
Is this the Problem???
Don't format your Flash Drive.
Your data is still there.
Use Shortcut Virus Remover.
  • 100% free
  • Setup file to download 1.1 Mb
  • Installed file 2 Kb
It will recover your all data.
DOWNLOAD !!
http://shortcutvirusremover.blogspot.com
Oct 11, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Pop up saying you have a virus, i try to go online, or into properties and it keep saying, wmiadap.exe is infected. It always pop up to buy antivirus software.
It seems as if you have downloaded a spyware program such as a wallpaper which has caused you to have a fake antivirus 2009 running. Make an Ultimate Boot CD and run every AV tool and spyware/malware that was on the CD. After running all the tools install your XP SP2 CD to repair the installation Download and run hijack this to see if still have the virus lurking on the computer.
Jan 17, 2010 | Microsoft Windows XP Professional
GooD properties pop-up
the problem is in the registry.
1. click start => RUN (or press the windows logo + R)
2.type regedit then press enter
3. Press Ctrl + F (it means find)
4. type in "Good Properties" (without the quotes)
5. Press OK or FIND button to search the registry'
6. Delete every value that you find having the string "Good Property"
7. Press F3 to find next and delete them if you find any match
Restart your computer then good luck!
Aug 05, 2009 | Microsoft Windows Vista Home Basic Edition...
Reset secure clock
Cause and Solution to Secure Clock Error
First thing you need to do is open up your task manager by clicking control alt delete.
Select the tab "processes." In the process tab you will see a list of programs that are currently running, if you locate a file called csrss.exe it could be a trojan virus that is blocking your subscription music from communicating with your computer properly. It also effects a lot other things including hardware, personal information, security, etc. but for this post we will keep it specificly on the secure clock error. This csrss.exe trojan/virus causes your computer's internal system to not function correctly including the secure clock.
NOW WAIT! There are two different csrss.exe files, a good one and a bad/trojan one. All windows computers have a csrss.exe file on them and this "good" csrss.exe file is need in order for your computer to run propertly so don't do anything with it until you determine if you have the "good" one or the "bad" one.
You must first determine whether the csrss.exe file that is running on your computer is the "good" one that ships with the computer (inside your systems32 folder) or whether you have the trojan/virus csrss.exe file infecting your computer and secure clock.
Since the systems32 program and the Trojan/virus are both name csrss.exe you must run a quick test to see if you have the bad one or the good one or both.
First locate all fo the csrss.exe files inside your "processes" tab inside task manager (you may have more then one). The way to tell if you have the trojan or "bad" csrss.exe is by right clicking on it and selecting "end task." If you have the "good" one then you should get a windows pop up message. If you you get the windows pop up message, do NOT "end" the task, just ex out or cancel out of it. You do not want to end the "good" csrss.exe file because it is needed in order for your computer to work properly. If you "end task" on the good csrss.exe file then your computer will instantly crash (since it is needed to run).
If when you right click on the csrss.exe file and select "end task" you do NOT get a windows pop up then you may very likely have the csrss.exe trojan virus. In addition to the right click test you may want to simply look at where this file is located. If it is in your systems folder it is the good one, if it is anywhere else it is propably the bad one.
The trojan/virsu version of this csrss.exe file interferes with many of the communication hardware,drivers, software, security, etc., including rhapsody and will prompt this secure clock error message.
The only way to remove this csrss.exe trojan is to perform a system recovery on your computer returning your computer back to the original manufacturers settings. There is no way to clean, delete or remove this file trojan, you must perform a complete clean of your system by doing a system recover.
If you cannont determine whether your csrss.exe file are good one or bad ones simply back up your files and software and do a system recovery anyway, your rhapsody and mp3 player will then work fine.
May 21, 2009 | Coby MP-705 Digital Media Player
ROGUE ANTIVIRUS SOFTWARE!!
Hello
You can remove it:
Start Taskmanager by pressing Ctrl-Alt-Del
From Prosesse tab, select PAV.EXE and click End Prosess.
Next find and delete following files:
pav.exe
PersonalAntivirus.exe
PersonalAntivirus.lnk
Uninstall Personal Antivirus.lnk
After that I you are familiar with Registy Editor, find and delete
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run “Personal Antivirus
Best regards,
Zizzler
Apr 23, 2009 | E-Machines eMachines Desktop PC
I have a rundll32.exe problem
Sounds like rundll32 got currupted by the virus, this is not uncommon. Perhaps you should locate a good copy. This site seems to have a good tutorial on how to do that:
http://ezinearticles.com/?How-to-Fix-Rundll32.exe?&id=913723
Good luck
Mar 13, 2009 | Computers & Internet
Trojan virus on new computer
Do a virus scan and then remove the virus/trojan
If your saying as soon as you turned on the new pc this trojan warning appeared i would take it back
let me know
Mar 08, 2009 | Dell Inspiron 1525 Notebook
Win web security
Go here http://www.malwarebytes.org/mbam.php and download the Malware Byttes Anti-Malware Trial Application. That removes all of those Fake Virus Alerts. Just make sure you delete all system restore points aswell when the malware is removed, as otherwise it will just creep back in on the system.
Nov 25, 2008 | Computers & Internet
Microsoft Windows Vista Home Basic Edition for PC Logo
453 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
