Question about Water Heaters
Rheem energy miser. Model 81v52d c, 50 gal. Is not heating any water. I don't have the manual for it to see what troubleshooting options there are.
  • 3 Answers
The water heater was taken out to tile the floor and put back in 2 days later. It has power but is not heating the water. Can you help?
Posted on Feb 17, 2010
  • 20 Answers
If it is electric then it might be the heating coil and it needs to be replaced or if it gas then pilot light is going out. it needs to be relit
Posted on Nov 14, 2009
Rheemglas standard energy miser electric water heater model #81vr-80 gal serial #RH0501c00664. Does it have two heating elements and where are they?
it does have 2 elements they are located under the 2 panels on the heater you will find them under the covers on the front they will be connected to the thermostats follow the wiring. besure to turn off the power before working on it and use a tester to double check
May 31, 2014 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem 50 gallon Electric Water Heater 81V52D C repair ideas needed
It could be element shorted to ground through steel tank, so don't touch tank when breaker is ON.
Or you have undersized 12 gauge wire and 20 amp breaker and the heat has loosened breaker on the busbar. Breaker trips when heat exceeds breaker limit. Jiggle breaker and listen for crackling sound.
To restore hot water now:
Turn off circuit breaker, and open top cover then Push in reset button on top of heater to restore functionality. Put back insulation and factory cover.
To fix water heater: test and replace bad element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
If problems continue
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
http://waterheatertimer.org/Troubleshoot-household-electricity.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 25, 2012 | Rheem 81V52D Water Heaters FOR 220 VOLTS
Please help!! I can't find the reset button on my Rheem 81V52D C model water tank! I opened the top panel and didn't see a red reset button. Totally confused now. Please help?
if there is no reset button, you should be able to turn the breaker off for a few minutes. then turn it back on. if its an electric water heater! it should reset it. good-day !
Mar 26, 2012 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
My 50 gal elec water heater model #81v52d only stay hot during a shower for 10 min how do I make the water hotter is there a dial on it?
Remove the four screws that hold the covers on the side of the water heater and carefully spread the insulation apart to see the thermostat,reset button and heating elements. The thermostat will have a adjusting screw on it that you can turn with a small blade screwdriver.There is a arrow pointing to temperature setting that you can adjust by turning the screw clockwise to increase the temperature. They normally come from the factory set at 120 degrees so you can turn it up to 135-140 and see if that helps.
Thank you and I hope this helps you.
Jan 20, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Hello, I have a Rheem 81V52D 50 gal. residential water heater. I had the upper element short out. I replaced both the upper & lower elements with the 4500 watt 230v. My problem now is that the upper...
It's probably bad upper or lower thermostat.
BUT... new element could also be shorted.
OR ... original tank is rated 1500 watt elements look at label on side of tank.
I always replace both thermostats to save time.
Lower thermostat costs $10 at Lowes.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 16, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Our hot water has been getting much more hot than usual - we don't run out of hot water, and the hot doesn't fluctuate between really hot and then cool. We had it set to a lower temp (~125F), so can...
The first thing I would do is to turn the thermostat up and down several times,wait a few mins. and do it again. Then run hot water until element comes on. Let it run for a few mins and then turn it back to lowest setting.
I never really came up with a good reason why this works some times but I always tried to save money for my customers and quite often I was 30 or more miles to supply house and it was a cheap fix.
I think you probably will end up replaceing thermostat like your thinking so good luck. Thank you.
Dec 27, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
TRYING TO REPLACE MY OLD RHEEM WATER HEATER MODEL NUMBER 81V52D C SERIAL NUMBER RH 1297B30669 50 GAL US TANK ELECTRIC WHAT IS THE UPDATED VERSION?
I would say your water heater is from the fury series; new model number 82V52-2. I've included a link with my solution that you should take a look at. You could also look at water heaters of a different brand if this one isn't available in your area. Kenmore, GE, and Hotpoint are all very good brands of water heaters.
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
May 25, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rheem 50 Gal two 4500W heating element - not enough hot water
one element is off peak and one is boost could be thermostat or ripple controller in fuse box or one dead element
Apr 19, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
3,063 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
