Question about AudioBahn A4125HCQ Car Audio Amplifier
A2300hct draingin battery firm wiring outside but still isnt right cuz if i drop water or something on it it would catch fire
  • m_good2 Nov 15, 2009
    guy that looked at it says possibly sater inside amp possibly came off.mad power is on amp outside which looks like poor grounding but it s not.it s something inside amp,y'know?is it someone to send amp to to look at it?amp on drains battery in 3 days or so.disconnected then all is good.
  • Michael Kovalik III
    Michael Kovalik III May 11, 2010
    amp or ?? what sizzels water droplets ?
  • 37 Answers
HEAT
Posted on Mar 17, 2010
I just changed spark plugs and coil wires on my 2003 rendezvous and something still isnt right. It wants to idle funny, ride fine and dies when you go to park. Any suggestions?
Double check to make sure you didn't accidentally swap two plug wires. It is easy to do. Get the firing order and make sure the wires hit the cylinders in that order.
Oct 30, 2016 | Cars & Trucks
Car has trouble starting (starter cranks well, battery is great)
i wood check that the belt from the stareter moter is not sliping
Apr 07, 2014 | 1997 Volkswagen Jetta
Chevy wiring schematic
Fix the injectors first or the engine could catch fire.
Dec 16, 2013 | Vehicle Parts & Accessories
Car wont start if there is moisture
If the starter cranks without the engine responding there is presence of moisture in the electrical or even water in the fuel.
Since you have established that the engine runs when it is dry or warm, the fault can be that there is some moisture that can accumulate with dirt on the igntion system and switch off the firing.
A proper cleaning of the HT wires and the ignition unit along with protection to the fuel tank and possible water leak into the hood must solve the issue. Finally make sure that the battery had good charge overnight , check the leads from the battery to be firm and tight. If charge is low then a cold start will need a good coil,good spark and a perfect starter motor.
Nov 07, 2011 | 1987 Ford Crown Victoria
I have a LG Chocolate Touch... It had been working fine, I recently put a lock code on it... I still remember the password but now my touch screen isnt working... It hasnt been dropped nor fell in water so...
Hard reset SHOULD work:
Settings (and tools on some phones)--->Phone Settings--->Security Setting--->Master Reset (it may be called something else, but it will be clear).
Jul 05, 2011 | LG Cell Phones
Cigarette lighter is not working, and it isnt the fuse.I have bought a new one and i am going to wire it straight from the battery , how will i do it?
It could be that the coil of the lighter itself is burned out-test the socket out with a car charger for a phone and see if the socket lights it up.if that doesnt work check to make sure that its grounded properly and if you absolutely must run it directly off your battery you only need 1 lead for the power straight from the positive to the rear of the socket.You SHOULD fuse near the battery it cuz if it ever shorts on you its going to catch stuff on fire bigtime.
Dec 11, 2010 | Car Audio & Video
Kenmore Washer will not drain
Hi, When the the water is suppose to be draingin, do you hear the motor humming at all?
It could be that something is plugging the pump. You can tip the washer toward the wall and look underneath. The pump is right behind the front panel and easy to get to. You can try lowering the drain hose into a bucket and see if the water will release.
Please let me know if this helps you or if I can assist you further.
Vic
Jul 09, 2009 | Washing Machines
Wierd stopped working audiobahn a2300hct
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up normally, the wiring and speakers need to be checked. If it still shuts down, the amp likely has blown output transistors.
Apr 05, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Audiobahn A2300HCt wont work
you might not have enough power pushing the amp.... I have two batteries and two caps running
Apr 02, 2007 | AudioBahn A2300HCT Car Audio Amplifier
AudioBahn A4125HCQ Car Audio Amplifier Logo
26 people viewed this question
Top AudioBahn Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jerry Naidoo
Robert Rankin
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
