Question about Brother XR-35
My brother xr 34 is not working properly. the
My brother xr 34 is not working properly. the thread under neath keep bunching up and then the machine seizes. i keep trying to adjust the tension in the bobbin by turning the little screw and that is not helping. it probably needs to be oiled and im not sure how to do that. i have no manual
SOURCE: Bicor vx1005 ...thread keeps bunching
i need needle threder lever
Posted on Aug 10, 2008
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
RickE1
  • 202 Answers
SOURCE: Thread is bunching underneath fabric
Needle in correct? Be sure your bobbin is not in upside down and turning the wrong way. Possibly the hook that the bobbicase fits in/on has been hit by a needle and caused a burr that is catching the thread as it comes around. The burr would have to be polished off or hook replaced. The machine could be slightly out of time also.
Posted on Feb 11, 2009
mohammed387
  • 1952 Answers
SOURCE: my needle thread keeps bunching and llooping on
If you getting loops on the bottom of your material, you need to re-thread the top of your machine. I say this because it is very rare when you will have to adjust the bobbin tension. But if you must, looking straight down at the bobbin as a clock- at 6:00 is the bobbin tension adjustment- lefty lucy, righty tighty. Hope this helps.
Make sure the needle is inserted in the machine properly- a good rule of thumb is the flat side of the needle should go to the opposite side of the last thread guide. Also make sure the machine is threaded correct
There is no standard tension for any machine to be set at. They start at four when they are brand new, however, after years and years the springs become compressed. You could start at four and then play around with it from there. If you are getting loops underneath the material, you are threading the machine incorrectly.
Posted on Jul 15, 2009
  • 30 Answers
SOURCE: mass bunching of thread in the bobbin compartment
it had nothing to do with the shuttle, it is the upper thread is not in the tensioner. lift the presser foot up and thread the machine even if you have to hold the thread on the top and pull on the bottom to make it go in the tensioner it will help, if a machine loops on the bottom it is the upper tension if it loops on the top it is the lower tension
Posted on Aug 22, 2009
Bobbin thread is gathering up under Neath
Sounds like birds nest or thread nests. HINT: When threading the top thread, ALWAYS have the presser foot in the RAISED position.
Birds nest under the fabric big loops of thread top side looks good...
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
May 09, 2017 | Sewing Machines
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
The bobbin on my Brother Xr 34 sewing machine won't catch Please help
try changing the needle
try a different bobbin
try turning the bobbin the opposite direction
make sure the bobbin is inserted correctly into the bobbin case
there could be something wrong with the hook and hook race
and the machine may need some adjustment
Mar 06, 2013 | Sewing Machines
I have an xl2230.today the needle broke so i replaced with new one,and now the machine wont sew properly,its banging sometimes when it sews and the thread keeps breaking at the needle end and the fabr
try another needle
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint or threads
if none of these things help then I suggest the machine get's serviced just
incase the timing is messed up
May 31, 2012 | Brother XL-2230 Mechanical Sewing Machine
Bobbin thread bunching up.
Thread the machine with the presser foot up and see if this will remedy the problem.
If not, refer to the manual to be sure the threading and bobbin are set up as they should be.
If the bobbin thread and top thread continue to not link together, it could be the timing needs to be adjusted.
In this case, take the machine to a Brother dealer for service along with a sample of the stitching.
Apr 01, 2010 | Brother XR-65t Mechanical Sewing Machine
Singer Merritt 2430
Hi!
There could be several reasons due to which the thread keeps bunching up underneath.
It may be due to tangling of upper thread. Remove the thread completely from the machine, use correct size spool cap for the size of the thread spool, re-thread the machine, now remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race.
You could be holding the needle thread too tight. Hold the thread lightly to keep the end from going down into the shuttle.
The needle could be thread incorrectly. Thread the needle eye from the front to the back.
The needle could be bent or improperly inserted. Install a new needle with the flat side of the needle facing the back.
Please rate the solution as FixYa and revert for any clarification.
Thanks
Rylee
Apr 23, 2009 | Janome 6019QC Mechanical Sewing Machine
Brother LS-2125 Upper Thread Snapping
I had the same problem and it was so frustrating! It was happening to me because I wasn't using the right size needle. Go up a couple of needle sizes and see if that helps.
Feb 12, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother xr-65 bobbin problem
insert the bobbin so the thread comes out in the middle a away from you, hold the thread end push the bobbin down with with your finger, and pass the thread securely through the thread cutting groove
Oct 30, 2008 | Brother XR-65t Mechanical Sewing Machine
Brother Embroidery machine thread keeps breaking
the needle thread tension is wrong
bunching up under the material indicates that it is too loose
Nov 17, 2017 | Sewing Machines
Sewing Machines Logo
173 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
