Question about HP LaserJet 3030 All-In-One Printer
Where do I find the HP 3030 Toolbox software ?
Where do I find the HP 3030 Toolbox software for Vista and how do I install it ? I've installed the driver for Vista but I do not get the toolbox for faxing and scanning
    Master:
  • HP Master
  • 956 Answers
If memory serves me correct, your printer came/comes with two/three disc's. Each for diff prods.
Do you have the setup disc's. if so, load disc/menu/extra facilities to load.
If not, got to www.hp.com Find were to enter you printer details, you will be able to download updates, be patient, con tak a little time, a lot of bytes.
Good uck!
Posted on Nov 14, 2009
Hp laserjet 3050 all-in-one printer software will not load on my windows 7 64 bit laptop.
It Depends on if the Fax is available for your region, Roll back all driver and start the installation afresh and be sure the option of Choosing Fax is highlighted.
Dec 10, 2012 | HP LaserJet 3050 All-In-One Printer
SEW-3030 Software does not install from CD.
Try the following to download the Windows or Mac drivers needed to run the SEW-3030:
http://www.samsunghomesecurity.co.uk/downloads.html
I've used to connect the monitor to my Mac. The package (for Mac) also contains Mars Camera, a software that can operate the camera when the monitor is connected to the computer. It was developed by Mars Semiconductors Corp, which I guess is behind the chip needed for the monitor and camera to communicate.
Feb 10, 2011 | Samsung Wireless Security Monitoring...
I have a hp LaserJet 3030 and I have misplaced the disk and now I cannot scan. When I press scan to it says - not setup in computer and when I press start scan it says - Waiting for pc. Please help
Access the manufacturer's web-site: http://support.hp.com
Enter '3030' and select your printer.
Click 'Software Downloads'.
Select your Operating System (Mac? Vista? 7?)
Download the device-driver.
Install the device-driver.
Scan.
Jan 23, 2011 | HP LaserJet 3030 All-In-One Printer
I dowloaded driver for Hp laserprinter 1320 and I just can intalled the driver but not it toolbox. Tell me how I can install toolbox to adjust the quality print out like set on or off the economic mode. My...
well it depends on the O.S the most current supported by this printer it's windows xp
going back to the issue, right after install the software it will give you another menu and on that menu there is always an option that says install more software by hitting that option it will install the toolbox right away.
if you have the software installed already and you skip that part just insert the installation cd again on the pc and hit the install sw option this will give you the install more software option and will not not affect the existing software and it will install the toolbox as well.
let me know it works!!
Jul 30, 2010 | HP LaserJet 1320 Printer
I have canoscanlide 30 i canot install the toolbox to my pc windown vista whay can i do
two possibilities...
1. the toolbox software may need to be installed as administrator and in compatibility mode
2. it may not be installable if your pc is a 64 bit pc and your toolbox software is 32 bit... this is a common issue...
Dec 23, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Unable to scan,, unable to find toolbox software
First you need the software to scan. If you do not have it go to this link and select you operating system (ex: Win Xp, Vista, etc). This is needed for XP, Vista should auto find it and install itself. If not down load the print driver option and Vista should do the rest.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=378058&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=378056
For XP (anything else ask and I'll try to help, Vista see above paragraph) Scroll down to "software" Click on the one for America, download and follow promts.
I would recommend on the first screen after you download it to tell it to extract to a fold (default is c:/3xxxam), not the temporary directory or you will probably have to come back and re extract it again to a real directory. (I already went through that issue, that why I am recomending the c drive directory option, not the tempory directory). Just follow prompts, it is a slow process.
You did not say if you added it to a network or not (I am guessing no, since you couldn't find software, which means you probably do not have an external network print server, which is required to add directly to the network for this model). I am going to go with it is a direct connect via USB, so just follow the direct connect options when you get to that point and once your done, check your start menu for the hp folder, that is where you should find the scanner software.
Jun 26, 2009 | HP LaserJet 3030 All-In-One Printer
HP PSC 1210
HP PSC 1210 software wont work with vista. That is the software that comes with the printer containing photo disk ,toolbox etc. HP tells me to get a new printer but its the program that needs attention.
Apr 29, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP LaserJet 3030 Message: Scanning error cannot connect
I had the same problem on XP and Vista and it turns out that if your don't have the HP Toolbox Running/starting up with pc this caused my problem. Once I lunched it to startup with I am able to scan using the Scan To Button on my Scanner.
-Cepedare
Apr 04, 2008 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 3030 All-In-One Printer Logo
1,398 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
