Question about Nikon D80 Digital Camera with 18-135mm Lens
I get a fEE on my control panel after adding a 28-85 lens in addition there is a bell sound that keeps going off? What do I do to make it so that I can take photos with this lens?
  • kakima May 11, 2010
    I assume you're referring to the old Nikon lens.
    Remove the lens, clean the contacts, reattach the lens, and jiggle the lens to seat the contacts.
    Does this help?
    Novelist:
  • 181 Answers
If your lens has an aperture ring, do note that most of these lenses require the ring to be locked at a certain position for it to work. In the course of using the lens, you may have accidentally unlocked the aperture ring and moved it out of position. This is a common problem.
To fix this error, try this:
1. Turn off camera
2. Turn the aperture ring clockwise and then lock it
3. Turn on the camera
If you still encounter the same problem, repeat the same steps but turn the aperture ring counter-clockwise. Hope this helps.
Posted on Jan 08, 2010
FEE message using Quantaray for Nikon lens
Turn the aperture ring on the lens to its smallest setting (largest f/number). You can control the aperture from the camera body, the same way as on a lens without an aperture ring.
Jan 26, 2013 | Nikon D Cameras
I can't receive and send any MMS on my phone. It keeps saying GPRS not subscribed.
You have to signup for a Data Plan through your cellphone carrier. Usually, it is an additional fee per month added to your bill.
Mar 09, 2011 | Cell Phones
I recently rebooted my computer and my friend tells me the reason i have no sound is because i have no sound driver, i havea packard bell computer : MODEL : UTOW - RIO
if your computer came with a disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control
panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 01, 2010 | Packard Bell (030069) Sound Card
When i attatch my 70-300 lens i get a flashing FEE in the box,the book says to set the minimum aperture how do i do this please.
Thanks for the additional info.
First, an apology: I misread the lens description, sorry. If you have the "AF 70-300mm f/4-5.6 ED Nikkor" then the lens DOES have an aperture ring at the rear of the lens. If this is the case, then your D50 is compatible and all you need to do is turn the aperture ring on the lens until it's at the minimum f32 setting. The "FEE" message on your D50 should then vanish. When set this way, you control the aperture setting on the lens via the camera body controls. The command wheel alone adjusts the aperture when in Aperture Priority mode, and in Manual or Shutter Priority modes you need to first press the " /-" button behind and to the right of the shutter release before using the command wheel. There's even a handy little printed icon of a lens diaphragm to remind you of the secondary function of this button.
If your lens model is the "Nikon 70-300mm f/4-5.6G" then like a G lenses it lacks an aperture ring and so can only be controlled by Nikon bodies which operate the aperture from the body alone, like yours. So if you're getting the FEE error with a G lens then there's most likely a common fault which occurs with Nikon bodies with a small switch beside the lens mount. In the picture (courtesy and copyright of Digital Photography Review), the switch is at the 8 o'clock position.
This switch is activated either when a non-G lens aperture ring is turned to the smallest setting or when a G lens is correctly mounted. It is possible for the G lens to be damaged in such a way that the switch doesn't get activated but it's rare. If the switch is broken the camera body will need a repair.
Hope this answers your question, but if not add further comments. If it has answered your problem then please let me know by rating my reply.
Sep 14, 2010 | Nikon AF 70-300mm f/4-5.6 ED Nikkor Lens
I have a peugeot 406 coupe diesel . The problem is that the diesel additive light will not go out ,even though the local garage have added 2 litres of additive. Is there a fault finding procedure ?
Have your PCM diagnosed. ( a fee applies.) IF you have a check engine light on, obtain the code(s.) This is a free service at most discount parts houses. (e.g. Autozone, Advanced Auto, O'Reilly's, and Pep Boys.) There is no additive required if you have added it already. Do not add more. I believe you have a bad sensor. Let me know, thank you..
Apr 07, 2010 | 2005 Peugeot 405
FEE message in display when using 50mm lense
The FEE message indicates that the lens is not set to smallest aperture (highest number). The camera body expects this so it will have full control of the aperture. It sounds like you may be accidentally bumping or turning the aperture ring on the lens while using it or changing lenses. There is a little slide lock to lock it at f/22 to prevent this. Turn the aperture ring to 22 and move the slider so the white dot is next to the orange mark on the lens barrel.
Feb 28, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Sound drivers
i need hp sound drivers for xp pro sp3
May 13, 2008 | Packard Bell (030069) Sound Card
Packard Bell IGo 4000 series Versa E400
If you cannot see the speaker icon in the taskbar, click on Start > Control Panel > Sounds and Audio Devices and tick place icon in the taskbar. That's if a driver has been installed for your sound device which is a creative sounblaster I think.
Jan 08, 2008 | NEC Versa SX Notebook
Belling DB3 Control Panel
Not easy. Briefly, in addition to the screws you mention, the cooker side panels need to be removed to give access to removal of the control panel side clamps. Then the indicator lamps have to be disconnected, and timer etc. buttons have to be pulled out to allow removal of the the control panel. Then the main control unit (timer etc.) needs to be unscrewed from behind the control panel.
Replacement is reversal of above.
Oct 27, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
Adjusting the f stop
Lock the aperture in F 22. This will get rid of FEE. Now control the aperture settings from the body ( control infront of shutter release )
Aug 07, 2007 | Quantaray 28-90mm f/3.5-5.6 for Pentax
Nikon D80 Digital Camera with 18-135mm Lens Logo
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
