Question about Honeywell Programmable Thermostat Heater
I bought a Honeywell programmable thermostat RTH2310 to replace my 10 year old Honeywell thermostat. My old thermostat is a 4 wire system but also has a jumper from Y to 1. New system does not tell me what to do with the jumper (red) wire that goes from Y to 1 (I believe it to be for A/C). The thermostat is for gas heat and central a/c. Where does the "red" jumper cable go in new rth2310?
    Guru:
  • Honeywell Master
  • 587 Answers
It depends on the type of thermostat you have.
Do you have a 4 wire or 5 wire T'stat?
The red jumper wire was for a 5 wire t'stat with 1 transformer, the red jumper actually should have been from R to 1.
So you need to trace the wires back to the furnace and make sure they go to the locations identified below.
if you have a 4 wire t'stat then you don't need that jumper, if you have a 5 wire t'stat then you do need that jumper but it should go from Rh to Rc.
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
t'stat?
Posted on Nov 23, 2009
  • 407 Answers
If all you have is a 4 wire system, then your new thermostat will be hooked up just as it was ( r,w,y,g) and if there is no jumper on the new thermostat, then you shouldn't need one. The jumper on some thermostats are used for internal controls and is just a way that that certain thermostat works.
Posted on Jan 23, 2010
Operating manual honeywell rth2310
Honeywell has the manual for the RTH2310 programmable thermostat on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH2310B.htm . The direct link to the English/French version of the operating manual is http://customer.honeywell.com/techlit/pdf/PackedLit/69-2229EF.pdf .
I hope this helps.
Dec 13, 2011 | Honeywell Programmable Thermostat Heater
Only have two wires on old thermostat,where do i hook them up on a rth2310 thermostat
More information would help but I believe that you are trying to hook up a programmable thermostat to your old heating system which is what? Oil forced air, heat pump, gas? Give me more info and I think that I can help you.
hardrocko
Feb 07, 2010 | Honeywell Electronic Programmable...
I have a new honeywell thermosat rth2310 and the heat will not go on
Did you just install it????? If not check the batteries and replace them first....check for corroding also....if you just replaced the thermostat did you wire it correctly????/Wire for Wire???? If so if you have 4 wires in your thermostat you require a jumper wire between RH & RC....if you have 5 wires...no jumper is required....is the Furnace power on???
Nov 01, 2009 | Honeywell Programmable Thermostat Heater
Wiring new RTH2310 DIY Honeywell
sounds like you've got bear wires touching at the new tstat
Sep 18, 2009 | Honeywell Focus 6300B 5-2 Days...
Household Thermostat Replacement
you have to configure the thermostat to run the fan when there is a call for heat. look at the installation instructions and they shoud ask you if it is gas or electric heat if its electric then you are gong to have to configure it to makr e the fan come on with the heat. Good luck
Jan 25, 2009 | Honeywell Electronic Programmable...
Thermostat wiring
L is for a common wire if t-stat does not use batteries then this wire will have to be connected
Jan 13, 2009 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
664 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
