Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
I have a DI-624 connected via ethernet to a Mac G5 and an XP Desktop PC and an XP laptop via wireless. In the browser, I can get to the router by typing in the address from the desktop PC, but not from the Mac. I log in as admin, and it just does not seem to connect.
  • pliebfried Nov 14, 2009
    No proxies being used. Safari is the browser and it used to work with this Mac and the same router at a different location/DSL provider.
    Brigadier General:
  • 10,406 Answers
Check the web-browser settings on the Mac -- "disable" any usage of a proxy-server.
Or, try a different web-browser, in case the web-browser on the Mac cannot properly handle the web-pages that the DI-624 is sending.
Posted on Nov 14, 2009
DI-624 ROUTER INSTALL WITH OUT CD
Disconnect your modem and other devices from your wireless router and connect your laptop/PC to your wireless router through ethernet port ( keep your ip settings to automatic in network settings of your Laptop/PC) then type the ip number 192.168.0.1 in your web browser's address bar.
Here you are you will get the login page of your router.Default login id is "admin" and password is "password" if this password is wrong then try with the password "admin".
After logging into the page you will find the wireless security tab.in that you can find your security key.
May 12, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Unable to get PC to recognize wireless connection with DI-624
Which is it? PC cant connect or not able to setup wireless? If the router came with a setup CD, run that from your pc... Make sure you have a crossover Cat5(ethernet) cable connected between the router and a PC just to set it up initially... within the router can enable or disable wireless function... But to really narrow your device down, i need to know the hardware revision number... its on the same label as the MAC address on the outside of your router
Apr 03, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Router does'nt work . I can get online when I connect directly to the cable service and bypass the router, but when I plug the the ethernet cable into the router, I can't get wireless service.
Dear Werstellar,
Try resetting the router back into default, you can do that by holding the reset button on the back of your router for 30 seconds the uplug the power,
Once done connect a cable from a LAN port to your PC and connect the Ethernet cable from your modem to the WAN port of your DI-624.
Open your internet browser and type 192.168.0.1 the log into your router.
you can either run the wizard or go straight to manual configuration.
for manual configuration connection type : choose DHCP.
and then click on clone my Mac address. once this is done click save and reboot.
then log back to your router by typing 192.168.0.1 into your internet browser and go to wireless set up under encryption choose WPA as it is more secure and then type your network ID (This will be a password for your wireless network and it has to be a minimum of 8 DIgits or letters or a combination of both.
once done go to system from the menu and choose save and reboot.
Now unplug the power for both modem and router, then plug the power for your modem first wait few minutes until all the lights on your modem are up then power up your DI-624 give it few minutes and you should be able to go online on both wired and wireless connection.
any more help just ask
Mar 03, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Can I piggyback a wireless router onto a hard-wired router?
Yes, you can connect the DI-624 to your exitsing EBR-2310, you just need to connect the a cable from port 4 of the EBR-2310 to the internet/wan port of the DI-624, then after that you can already use now the wireless to your laptop and also the wired router to your desktops.
But I may suggest you to just replace the EBR-2310 with the DI-624 so you will only be using 1 router that can cater your laptop and also your desktop, Just connect the cable from your modem that is conencted now to your EBR-2310 to the internet/wan port of the DI-624 then run the setup CD that should be it.
Hope that helps...........
Aug 30, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Dlink solutions
you just cleck dlink, then properties, then cleck advance check the computer internet
Jun 18, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-link DI-624
Hello, 192.168.0.1 is usually the default address. If the router is connect to the PC or Laptop with a straight through ethernet cable, browser should connect. The only reason is the default has been changed. The easiest thing would be to set the router back to default. Push reset on back of router for 5-10 seconds. Then try to access with default address. Username is "admin" leave password blank. Hope this helps.
Mar 21, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
Dlink Router not assigning IP to NAS
DI-624 (Update to FW 2.70+)
See: http://www.infrant.com/wiki/index.php/Hardware_Compatibility_List_-_Network_Switches/Routers#D-Link
Dec 28, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
Setup Question
no if your pc is connected to the router, then that one has its connection which i assume will be either usb connected or ethernet connected. You laptop will connect via the wireless connection to the router, not your pc, so as long as your laptop has a wireless adapter then it will independantly connect to the router, your other pc does not have to be switched on as your router is connected to the net as long as it is switched on.
May 28, 2007 | D-Link DI 514 Wireless Router (DI-514)
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
111 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
