Question about D-Link AirPlus DI-524 Wireless Router
Have a d link di 524 how do I secure the wep password I set a year ago
    Brigadier General:
  • 10,406 Answers
Change the password, monthly.
Use a mix of upper-case, lower-case, and digits.
Or, try the the first letter of a common-phrase:
I J(ust) W(ant) T(o) R(ock) A(nd) R(oll) A(ll) N(ight) --> I J W T R A R A N
or
A(ll) W(e) A(re) S(aying) I(s) G(ive) P(eace) A C(hance) -> A W A S I G P A C
Posted on Nov 14, 2009
I need the WEP security key code for my router in order to hook up a new wireless blue ray, and i dont have a manual
You can get the manual for free from D-link http://www.dlink.ca/products/?tab=3&pid=DI-524&rev=DI-524
Below are my router suggestions:
Wireless Router
It is usually easiest to run the install wizard, but be sure to be ready to set the items listed below.
Things to set:
Note: Routers are intended to be set by geeks. You have to SAVE EVERY page, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes.
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue.
2. Set a recognizable system ID.
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping to bottom of the router. Physical access is not the security issue.
4. Check that your router is set to broadcast its' presence.
Nov 21, 2010 | D-Link AirPlus DI-524 Wireless Router
How do I secure the network
The securing process in your wireless router is set by choosing the "Wireless Settings" (with my Netgear, anyway) screen. The bottom portion of the screen lets you set various things re. security, like WEP, WPS-PSK (TKIP), WPA2-PSK (AES), and on. Different levels of security demand different types of passwords as well.
Nov 01, 2009 | D-Link AirPlus DI-524 Wireless Router
I want to put a password on my D1-524 router
then you need to login on your router. connect to it with the routers ip address and login with usr: admin and pwd admin, then go to system and change password.
Oct 12, 2009 | D-Link AirPlus DI-524 Wireless Router
How do I set router to secured??
First connect your router to computer with ethernet cable.
Then you can access it with following link
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then go to wi fi security set your WEP code it is your password to connect wi fi network.
Let me know if you need more assistanse.
Thanks
Sep 18, 2009 | D-Link AirPlus DI-524 Wireless Router
I want to make my wireless router secure so need to set password?
Here's the manual:
http://www.dlink-me.com/ftp/wireless/DI-524/DI-524_manual.pdf
Page 13 is what you need.
Open the web browser
Type in the IP Address of
the Router (http://192.168.0.1)
Type admin in the User Name field
Leave the Password blank
Click OK
Once in the router interface
click the 'Wireless' button
Mar 15, 2009 | D-Link AirPlus DI-524 Wireless Router
Wireless Cood
You can put in your wireless code by connecting to the DI-524 using the LAN cable. Open you web browser (Internet Explorer) on your computer, and type in the address http://192.168.0.1 This should take you to the sign on screen for your DI-524. user ID will be "admin" and password is blank unless you have changed it. Go to the "Wireless" button on the left. There you can specify the type of wireless security you want and the secret code. The most simple security is WEP, with 64bit WEP encryption, and "Open System" authentication. Enter a 10 digit numeric code in "Key 1". You don't need to fill our the other keys. NOTE the number down for future reference.
Jan 09, 2009 | D-Link AirPlus DI-524 Wireless Router
Securing my wireless connection
Hi ladynb,
Open the DI-524 window by typing 192.168.0.1 into internet explorer address bar, and press enter.  Fill in your password, and press enter.  Click on the  Wireless button. This should open the Wireless Settings window for the 524.  Set SSID broadcast to  Enabled. Set Security to WEP.  Set Authentication to open system.  Set WEP Encryption to 64bit.   Set Type to HEX. Click and select radio button next to KEY1.  Enter a 10 digit number that you can remember, like 1234567890, or 1111122222.   Now click the Apply button at bottom of the screen.
Now any device that you wish to link  will will need to use this Key.   Scan for the router, connect and use Infrastructure mode, Type in the 10 digit number you were suppose to remember, and off you go.
Oct 09, 2007 | D-Link AirPlus DI-524 Wireless Router
Cant connect
Hi purplegarion,
hook up the router per instruction in manual and your particular internet connection.  With the Di524 powered up, use the end of a paperclip to depress the reset button located in a little hole beside the power connection.   open internet explorer and type in 192.168.0.1 and press enter.  The password is admin. once th screen appears, click on Wizard.  Follow the wizards directions carefully.
For simplicity of security click on the wireless button while in the  wireless screen.  Set radio to on.  Enter a SSID like purplegarion. Set to open system.  Set Security to WEP.  Wep to HEX.  64bit.  Enter into Key one a 10 digit number you can remember like 1234567890.  Click apply.  Change your password to a personal password other than ADMIN.
Any device that attaches will need to enter the WEP 64 Bit hex Security key 1234567890, or whatever 10 digit number you put in the router.
Internet connection will require powering down you modem, and the DI-524 router.  power up the modem first and let it go through the start up, then power up thte DI 524.  you may need to make sure your DHCP is set to Automatically assign an IP address.
Oct 07, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
128 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
