Question about Whirlpool Dryers
Dryer will not dry clothes after 60 minutes in the dryer clothes still wet just like they had just come out of the washer.
  • Michael McQuay
    Michael McQuay May 11, 2010
    Is there no heat at all? Or do you feel heat and just not drying?
    Scholar:
  • 50 Answers
The reason you are not getting the cloths dry after 60 minutes and are just as wet is airflow or rather the lack thereof.
First verify that you dryer is actually starting, (I know... you're thinking, duh!) but simple things first. Let the dryer run on high heat for about 2 minutes and open the door. See if there's actually heat coming out of the door. If there is, that's a good sign. Did the drum seem to be tumbling? if yes, this also is a good sign.
Next turn the dryer to fluff/no heat and turn it on. Go outside and check the dryer vent (if possible) and see if there is a reasonable amount of airflow coming out. Most likely it will be weak (since your cloths aren't drying.) Now that you have checked that, go inside, disconnect the dryer hose on the back of the dryer. Compare the airflow from the outside vent. If it is considerably stronger than outside, your ducting needs cleaned. If it is about the same and still weak, something is blocking airflow in your dryer.
Here's a decision point. If you feel you don't want to try to fix the dryer yourself, get someone qualified or take it to a qualified maintenance shot for the dryer. If you feel up to the task, FIRST unplug the dryer, then you'll have to disassemble the dryer (can't give you specifics without the model number) and find the clog and remove it. Once the clog is removed (very likely lots of lint and maybe even a sock or two) reassemble the dryer, hook the vent hose back up, plug it in, try to dry your cloths.
Hope that helps
Posted on Nov 14, 2009
2009 Kenmore Dryer. Wondering why it seems to only work on 1 drying cycle? Everytime I try to put it on another cycle all the lights flash and beep...and nothing...
sounds like the washer might not be spinning the water out of the clothes good enough . 1 60 minute cycle should dry them more than dry enough .
Oct 18, 2015 | Kenmore 8804 5.8 cu. ft. Electric Dryer
Drying machine not working, the clothes always wet.
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
Oct 03, 2014 | LG DLEX2550W 27" Front-Load Electric Dryer
My whirlpool AWZ510E washer dryer - the dryer doesn't seem to be working - it goes through the cycle but the clothes are still as wet as before. I am using the same cycle as I always have which used to...
there are 3 reasons for a dryer not doing the job yet running through the motions. 1st, the heat is not being produced and only cool room temp air is circulating. this can be a burned-out electric element or an over-heat sensor, or in0line safety fuse. ( if gas, can be ignitor or gas valve coils).. It could be that the washer is not ringing (spinning) dry the clothes verywell and there is too much moisture stiil in clothes which would double the dry time from 50-60 minutes to 2 hours. 3rd, could be clogged vent line and the hot moist air cannot leave the dryer so the clothes get hot by the moisture stays.
Apr 28, 2010 | Whirlpool Washing Machines
Dryer heats up but does not dry clothes completely after 60 minute cycle
try giving them an extra spin in washer I do this all the time extracts a lot more moisture out of your clothes and cuts dryer time as well
Dec 18, 2009 | Whirlpool LEQ9858P Electric Dryer
Frigidaire Gallery Dryer Needs Two Cycles to Dry Clothes
A dryer needs to exhaust properly in order to dry no matter where it's situated. Insure that the venting is not crushed at the back and that it has a good strong air flow outside
Jun 21, 2009 | Dryers
Thin twin stacked washer/dryer...dryer won't stay on
My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
Nov 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
How do you DRY with the Haier washer/dryer
Have you tried lengthening the dryer cycle or running it at a higher temp? The usual culprit for wet clothes is not running a dryer long enough or hot enough. (I remember some stand-alone dryers (coin-operated with a fixed drying time per coin) that needed two cycles to dry stuff.
Jul 12, 2008 | Haier 14.3 lb. Washer/Dryer Combo
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Dryers Logo
130 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
