Question about Sony Xplod Car Audio Amplifier XM-DS1300P5 - 800 Watts Mono Amplifier Car Audio Amplifier
What does it mean when the red protection light illuminates
    New Friend:
  • 12 Answers
Hi the protection light comes on when there is a problem within the amps. circuitry. Generally speaking the protection light normally comes on when powered up while the amp checks all of its voltage rails so that they all lie within a specific tolerance, when all have been verified to be in spec. then the protect light goes out & the power light comes on. If the protect light stays on then a fault exists within it's circuitry. Cheers, acbva.
Posted on Nov 14, 2009
2 Suggested Answers
  • 631 Answers
SOURCE: what does the orange light protection mean
The LED will illuminate when there is a fault (shorted speakers, shorted speaker wires, shorted output transistors, high temperature...).
Posted on Dec 07, 2009
2010 dodge caravan warning light red circle with exclamation mark and parentheses around it. What does it mean? My tire warning light was also on but it went off after awhile of driving.
If the red brake light remains illuminated, it means that there is a persistent problem in the brake system. When this occurs, the vehicle should not be driven. The vehicle needs to be towed to a qualified repair shop where it can be properly diagnosed and inspected. If the red brake light comes on while driving and stays illuminated, the vehicle should be pulled to the side of the road and towed to a qualified repair shop.
Dec 21, 2016 | Dodge Cars & Trucks
COLEMAN INVERTER PMP1200 JUST BEEPS WHEN TURNED ON
It is most likely the low voltage alarm. Suggest connecting when the car is running with no load (110 volts not connected). If the alarm continues turn the unit off and on to reset.
Hope this helps?
Inverter Protection Features
• Short Circuit Protection. The inverter will automatically shut down until short is removed.
• Low Voltage Alarm. An alarm will sound when the voltage from the battery discharges to 10.5 +/- 0.5 volts DC. This is an indication that the battery needs to be recharged.
• Over Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input exceeds 16.5 +/- 1 volt DC.
• Under Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input is less than 10.0 +/- 0.5 volts DC.
• Overload Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the continuous draw of the equipment being operated exceeds 1200 watts or the surge draw of the equipment exceeds 2400 watts.
• Thermal Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the circuit temperature exceeds 150° F
Sep 13, 2016 | Electronics - Others
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
When you power off the unit, it goes from bright led to low light led and shows a red light staying illuminated. Which means its STILL drawing battery. How do you turn it off completely?
Brake Hydraulic System Red Warning Light - RepairPal
repairpal.com/brake-hydraulic-system-red-warning-light
If the brake hydraulic system red warning light comes on and stays on, this indicates... and seems to come on and off depending on whether the vehicle is turning, ... if it is discovered that the light was illuminating due to a low brake fluid level.
Sep 10, 2015 | Cars & Trucks
There are 3 lights on the front of the Zanussi Freezone. The green one on the left doesn't light up. What does that indicate? The red light on the right is on constantly. Does this mean that the freezer is...
Starting the Appliance
Insert the plug into the wall socket. The green pilot light will illuminate to show that the appliance is switched on. The red alarm light will also illuminate until the freezer reaches the correct temperature.
Alarm Light
The red alarm light will illuminate when the temperature in the freezer is higher than the thermostat setting. This alarm light will illuminate if:
- The appliance has just been started.
- Fresh food has been put in the freezer.
- The lid has been left open, opened frequently or open for too long.
The red light will go out when the freezer has returned to the correct temperature
Dado
Oct 14, 2013 | Zanussi 14.62 cu. ft. / 414 liter Chest...
The light is on but the freezer is not cooling
You did not specify which lights are on?
  • The green pilot light will illuminate to show that the appliance is switched on.
  • The red alarm light will also illuminate until the freezer
  • If you press the SUPER button than you start fast freeze function and yellow light will illuminate.
I assume that the freezer is on and the green light is illuminated. This means that the freezer is on and energized.
Also, if freezer does not cooling, means that did not achieve the set temperature should be illuminated the red light (alarm).
Set the thermostat for example in position 4th and after that compressor should be start.
If compressor running but not cooling, defective is the system which circulates gas.
If compressor does not start, then is faulty thermostat, compressor or the wiring.
Dado
Apr 04, 2013 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Tc 8001 red light
on some amps there is a duel light. red and green usually. red means it is in protect mode or you didn't hook up your remote wire. if in protect mode, it could mean a number of things. did you hook it up with speakers and everything?
Mar 01, 2012 | MTX Thunder® TC8001 Car Amp
What does the orange light protection mean
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty .
.A thumbs up would be greatly appreciated if this answer is helpful to you
Dec 06, 2009 | Kicker ZR1000 Car Audio Amplifier
Sony Xplod Car Audio Amplifier XM-DS1300P5 - 800 Watts Mono Amplifier Car Audio Amplifier Logo
2,090 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
